Cold Air Inductions
Old 02-04-2010, 11:53 AM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
DIY Marriage-saving muffler delete
OK, we all know it looks like GM welded two garbage cans under the rear end of our cars and I like so many other wanted to get rid of them. One problem for me... my car is parked in the garage right under my master bedroom and the wife already says the car scares her to death when I fire it up in the morning leaving early for work. So this is the compromise I have made for the immediate future, the marriage-saving muffler delete a.k.a. spray painting the stock cans. I know this has been done by some other members but here is mine.
I had the car up on jack stands installing Pfadt sway bars so I used the opportunity to black out the garbage cans at the same time.
A couple view of the stock cans...
My blackening weapon of choice, Rust-Oleum high heat flat black, can says it is good until about 1200 degrees and there is no need to prime the surface. I picked it up at my local Lowes for 5 bucks...
I first did a light rinse and wipe-down of the cans and then hit them with Meguiar's All Wheel Cleaner which you can get at a Pep Boys or AutoZone for about 6-7 bucks, I let the cleaner sit on the mufflers for about a minute before scrubbing them down and then rinsing them off. Once dried I sanded them a bit just to scratch up the surface a little bit, nothing crazy and I didn't really worry if I sanded every nook and cranny, just a rough sand around the whole area I was going to paint. I blew them off with an air compressor and then draped some newspaper around the surrounding areas to catch any overspray...
I coated pretty much any part of the muffler I could see from the rear and sides as well as what you could see through the exhaust tip openings which is why the tips are taped off as I was spraying into the opening around the tips to get to that part of the muffler...
Two coats in....
All cleaned up after a third coat and ready to go, they blend in very nicely and don't stick out like a sore thumb now...
This will keep things quiet for a little while and satisfy my wanting to get rid of the otherwise obvious garbage cans hanging out from under the car. Unfortunately (for my wife), I have some Kooks Long Tubes on the way so things are about to get louder, once she gets over the fact that it is going to be loud after the Kooks, in come the Magnaflow Competition Catback ... By then I'll be sleeping in the shed anyway so it probably can't get any worse, unless she makes me roll the car out of the garage in neutral out into the street before I start it . Funny thing is, my kids like it when I rev it up and it gets loud, they say it sounds angry, my 2yr old says it sounds like a T-Rex... The Jurassic Camaro!!!
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 02-04-2010, 12:36 PM   #2
brtaus
brtaus's Avatar
Drives: None
Looks nice; if I weren't installing my new exhaust this weekend, I would consider doing the same thing.
brtaus is offline   Reply With Quote
Old 02-04-2010, 01:09 PM   #3
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
Looks good. But man, if the stock exhaust scares her... She must have VERY good hearing because you can barely hear the stock exhaust standing BEHIND the car. LoL
BlaSSt Off is offline   Reply With Quote
Old 02-04-2010, 01:17 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
cheap 99cent walmart black will work just fine too, only near the headers does it burn off / turn white
Been painting my exhaust black for years for similar reasons.
I freshen them up yearly, works best when the exhaust is medium hot, instant stick that wont come off.
I do similar when welding stuff now, paint is easier to remove then rust and fresh weld can rust up fast.
2ndgenz28 is offline   Reply With Quote
Old 02-04-2010, 01:43 PM   #5
robertway
robertway's Avatar
I say the same thing, it is not so much when the car is just idling but when it first fires up and revs a little bit before settling down, if a fly goes by and farts she can hear it so you could say she is a LIGHT sleeper... Luckily all of my kids could sleep through a SCUD missile attack so there is no worry in waking them up...
Old 02-04-2010, 02:23 PM   #6
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Actually, your pictures are a good guide for locations of placing jack-stands. Thanks again!
HeavyD is offline   Reply With Quote
Old 02-04-2010, 03:18 PM   #7
robertway
robertway's Avatar
Here is a better shot for that, I did not set the car right down on the jack stands on the pinch weld, I cut a 2x8 into 2.5" wide lengths about 6 inches long and placed them along the pinch weld so the car is resting on the wood which is resting on the jack stand. Even if the wood compresses enough so the pinch weld touches the jack stand, at least the full weight of the car isn't right on that weld.
You can kinda see the jack stand and the block of wood on top of it off to the right of this shot...
Old 02-04-2010, 04:08 PM   #8
jcamere94z28
jcamere94z28's Avatar
Drives: None
awesome...
I can't wait until my 1.5 year old start saying things like that.
looks good btw...
those wheels look nice.. do you have pic of the car with all the wheels on?
jcamere94z28 is offline   Reply With Quote
Old 02-13-2010, 06:20 PM   #9
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
If it were me I would put the car in neutral, back out into the driveway, then start the car. What you did looks good though.
Silver Ice is offline   Reply With Quote
Old 02-14-2010, 04:06 PM   #10
bluman
bluman's Avatar
Drives: '10 Corvette GS/'13 Mustang
I did this when the car was 2 hrs old in my possession
2010 Camaro SIM/CGM RS/2LT VIN #310 SOLD
2010 Corvette Grand Sport
bluman is offline   Reply With Quote
Old 02-19-2010, 07:02 PM   #11
My2SS/RS
My2SS/RS's Avatar
Drives: 2010 2SS/RS M6
Very nice! That looks 10x better than stock!
My2SS/RS is offline   Reply With Quote
Old 02-20-2010, 02:49 PM   #12
tom692010
Drives: 4 wheels
Hey rolling the car out of the garage ain't so bad. That's what I used to do with my Harley's when I went to work at 5am. The only bitch was the time or 2 it didn't start. I have a pretty slopped driveway so there wasn't any pushing it back up.
Nice job on the cans though. I put on QTP cutouts so I have his and her mode. Loud when my son and I are driving and quite for when the daughter and wife are in it.
tom692010 is offline   Reply With Quote
DIY: GFX Outlets add Wire Mesh and Paint, Muffler Delete Li0nel1234 Camaro DIY & HOW-TO instructions & discussions 25 01-07-2017 08:36 PM
Muffler Delete or Aftermarket? JohnForeman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-01-2009 12:46 PM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 07:32 PM
Considering a Muffler Delete, Straight Pipes or NOS in Ontario? Matster Canada 18 08-29-2009 04:41 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 03:09 PM
