Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
Thank you Oshawa/St.Cats!
Drives: 2010 2LT RS 2G1FC1EV4A9103434 Join Date: May 2009
will Sport Edition ST4 Rims be OK with SS Brembo Upgrade - coaching welcomed
A little help - to replace the 2LT OE brakes I am about to order the SS Brembo Calipers, Stillen Slotted & Drilled rotors, Hawk Cermaic pads and Goodridge Stainless Steel brake lines - I know these will fit the 20" RS rims but want to be sure my winter rims - Sport Edition ST4s will work OK with the SS Brembos - they're 20"x8.5", 34mm off-set, and 6.18" back-spacing. The stock RS wheels are 20"x8* front/ off-set +35mm (front), and 20"x9" rear / off-set +40mm (rear)
Unsure by changing the rotor and adding the SS Brembo calipers will I have enough clearance from the edge of the caliper to the edge of the winter rim. You guys see any issue with the winter rims? Can you even tell with the rim measurements I provided? Thanks.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5 Last edited by tjd24; 02-04-2010 at 04:01 PM. |
Thread Tools | |
Tjin Edition RoadShow Chevy Camaro SS to debut at SEMA show (sneak preview) | Tran | 5th Gen Camaro SS LS LT General Discussions | 59 | 10-19-2011 01:03 AM |
Do you want the Z28? | ChrisB | Camaro ZL1 Forum - ZL1 Specific Topics | 1616 | 09-04-2010 11:49 PM |
2010 Camaro Brembo Sport Disc Brake Upgrade available from INTENSE | Todd @ INTENSE | Suspension / Chassis / Brakes | 2 | 11-24-2009 10:30 PM |
Camaro SS vs Evo X | MAROobsession | Chevy Camaro vs... | 275 | 08-28-2009 03:49 PM |
Camaro does the Nurburgring test track in 8:20 | 2sharp | 5th Gen Camaro SS LS LT General Discussions | 45 | 07-23-2008 03:17 PM |
