Gen5DIY
Old 02-08-2010, 03:25 PM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
GM Publically admits Odo in ECM on Camaro...
For those of you wondering.
Symptoms of Module Swapping
A variety of symptoms may appear in a Global A vehicle containing one or more control modules swapped from a like vehicle. Depending upon which control modules have been swapped, possible symptoms include:
· The VIN read by GDS and SPS does not match the vehicle.
· Current DTC B3902 - Incorrect IMMO ID Rec. set in IPC, SDM, ECM, HVAC, Steering Column Lock Control Module (if equipped) or BCM. There are no warning lamps or DIC messages and this DTC cannot be cleared.
· IPC module displays (- - -) for odometer and trip odometer values.
· Vehicle will enter power mode only if the key fobs that match the donor vehicle BCM are included in the swap.
· BCM and/or ECM has current DTC B389A - Environment Identification. There is a Service Theft System message on the DIC, the Security MIL is illuminated and this DTC cannot be cleared.
· ECM odometer value is incorrect for vehicle.
· Radio displays Locked
http://www.sandyblogs.com/techlink/2...l-modules.html
whole article
http://www.sandyblogs.com/techlink/index.html
I piss excellence
and fart awesomeness
Old 02-08-2010, 04:12 PM   #2
Partick
Partick's Avatar
Drives: 2010 Camaro 2SS
Rut-roh
Partick is offline   Reply With Quote
Old 02-08-2010, 04:21 PM   #3
CamaroSpike23
Truth Enforcer
Originally Posted by Partick View Post
Rut-roh
I've been trying to tell people this.
for those wanting to swap ecm's to keep a stock tune on one and a performance tune on another, then swap before going to the dealership.
it will be found when the odometer in the ecm doesnt match up.
I piss excellence
Old 02-08-2010, 04:25 PM   #4
Partick
Partick's Avatar
Decided not to mess with mine when the previous threads went on and on and you could tell no one really knew for sure, just not worth it. CAI and exhaust and she runs like hell anyway.
Old 02-08-2010, 04:38 PM   #5
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
So Spike, can you explain what this means and how it's related to tunes and reflashing before warranty work.
Robert91RS is offline   Reply With Quote
Old 02-08-2010, 05:10 PM   #6
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Does this apply to the v8 cars only? The tech at my dealership stated in no uncertain terms that they cannot read histories of the E69 pcm if it's been reset. Not like there is a tune completely ready for the v6 cars just now anyway, but just curious.
PacMan
mrray13 is offline   Reply With Quote
Old 02-08-2010, 05:21 PM   #7
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Wow... this is lame... "The radio in Global A vehicles cannot be swapped due to the inability to alter the VIN in a radio once it has been learned."
UCF w00t is offline   Reply With Quote
Old 02-08-2010, 05:28 PM   #8
CamaroSpike23
Truth Enforcer
I edited my previous post. (working on too many threads simultaneously ).
Basically, there was a discussion a while back about people buying a spare ECM and having a tune installed on it then if they had to go to the dealer, they would just swap ECM's. however, the mileage of the car would not match that of the stock ECM if one swapped back and forth..... unless they swapped once a week and drove the same amount of mileage.
as for reflashing/retuning, obviously, you are using the same ecm recording mileage so that wont be an issue. However, GM can see tunes on cars. whether the dealer can or whether a tuner says they are using the same scanner as GM to prove you cant see it. GM can.
but it goes back to the old, "you gotta pay to play".
for the V6 ecm, I honestly do not know. I know that Trifecta performance is working on a tune for the v6. I'll see what I can find out.
I piss excellence
Old 02-08-2010, 05:41 PM   #9
tstpierre
Drives: 2010 Rally Yellow 2LT
trifecta certainly has tuned v6s. *staring at his stock and custom tune files*
Mods: Hennessey CAI, MBRP Exhaust, Stainless Works 1 5/8 Long Tube Headers and High Flow Cats, Trifecta Tuned
tstpierre is offline   Reply With Quote
Old 02-08-2010, 06:46 PM   #10
toehead93
Drives: 2014 2SS/1LE
This is for an ECM swap, what about re-tuning to stock?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 02-10-2010, 01:37 PM   #11
GaryTucker
Drives: 09 Vette GT1, 06 350Z, 82 MSE
Spike,
Thanks for pointing this out. I know this has been some folks standby and obviously it isn't going to work.
GaryTucker is offline   Reply With Quote
Old 02-10-2010, 10:31 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
This also has been over before. Some dealers say that will be fine but it won't.
There are check digits in the factory tunes. These check digits are set up and programmed so that they can not be saved by a tuner so if you revert back to the factory tune, your car will have the stock tune but not the check digits. The dealers can not see if these digits have been tampered with or removed but when they send in the tune to GM as they are required to in order to do any engine warranty work, GM will see the check digits missing and deny the warranty work.
There are a couple of tuners that claim to have the ability to save the check digits but since dealers software don't really have anyway to determine whether the check digits have been tempered with, there is no way to validate the claims unless you send it off to GM.
Old 02-11-2010, 12:44 PM   #13
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
I'm not sure this is all correct. From my understanding there is a Cal ID and a CVN (Cal Verificatin Number), both of which are displayed on the dealer's handheld Tech II. I've never heard of check digits.
They look up what the car should have for those two numbers, compare to what the Tech II is displaying... and they either match or they don't.
Then another factor is you really can't make a blanket statement that covers all tuning devices/companies. There are differences. Best to ask a specific tuner a specific question and they will tell you the straight poop as it relates to their products.
Old 02-12-2010, 02:33 PM   #14
mrray13
mrray13's Avatar
And on anything other then the original ECM swapped tune, no gains have stuck on the v6 cars, save the transmission shifts better. Unless you have dyno/track proof otherwise?
Okay, back on topic, lol.
PacMan
