Gen5DIY
Old 02-09-2010, 06:08 AM   #1
2010CamaroOutlaw
Drives: CGM 2SS/RS
low tire lights
damn almost every day in the am i get a low tire pressure light, its annoying, I know they are normally inflated and just reading low because it is cold, you would think they might have factored in the cold with this sensor
2010CamaroOutlaw is offline   Reply With Quote
Old 02-09-2010, 07:18 AM   #2
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
You should add some air. In cold temperatures, air contracts and tire pressure decreases. You also can lose pressure over time. A lb or 2 a month is not uncommon.
Recommended pressures are calculated for cold tire pressure. Your gauges are doing their job. Ignoring them could put you, your passengers, your tires and your car in jeopardy. Just saying!
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 02-09-2010, 06:30 PM   #3
Black LS3
Black LS3's Avatar
Drives: 2010 Black 2SS LS3
Hi Guys,... I just picked my car up on Jan 27 2010 and when I picken mine up the tires were at 42-44 PSI from the MFG.
I live in Florida,... What is the Recommended PSI for these Tires anyway?
Most tires I've had were like 35-37 PSI.
OnlineAutorama.US - A Camaro Parts/Accessories Site for Dealers & Vendors.
Muffler Delete. ( See Videos - Vid 1. - Vid 2. )
Stock Resonators & H-Pipe Removed.
Magnaflow 2.50" Tru-X X-Pipe.
AirAid Cold Air Intake System.
11.21.09 1100 Order Accepted At Dealer - 11.24.09 2000 Accepted At GM - 11.25.09 2500 Preferenced - 12.03.09 3000 Production Control Notes: 01/11/2010 - 12.17.09 3400 Order Broadcast - 01.13.10 3800 Order Produced VIN # 2G1FT1E - 01.25.10 4000 Available to Ship from Rail Yard by Truck - 01.27.10 5000 Delivered to the Dealership - 01-27-10 6000 Delivered to Customer.
Black LS3 is offline   Reply With Quote
Old 02-13-2010, 07:32 PM   #4
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
The recommended pressure for the Pirellis is 36 psi.
For every 10 degrees drop in outside temp, a tire will drop 1 psi.
My tires are at 36 psi when checked with a calibrated guage, but my TPMS sensors are reading 32 psi. So that being said, the tpms sensors are not very accurate. Mine are 4 psi off. If I inflate by the tpms readings then I will be at 40 psi actually in my tires.
Do not trust the tpms readings in the DIC, it is just a guideline. Use a good calibrated tire guage. Then you can see what the DIC reads and know what is normal. Now that I know that I'm at 36 psi when the DIC reads 32 psi, I now just look at the DIC when I get in the car and if it says 32 then I'm good to go.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 02-24-2010, 10:19 PM   #5
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
find somewhere that will fill them with nitrogen. then you wont have a temperature fluctuation.
LT1Jeep is offline   Reply With Quote
Angel Eye Mod (93-97 Camaros) CamaroSpike23 4th Generation Camaros 105 05-12-2014 03:17 PM
Tire Sealant Kit - Warranty Issues jbreed Wheels and Tires Talk Sponsored by The Tire Rack 38 09-14-2011 02:18 PM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 10:58 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 03:45 PM
