Caryle Racing
Old 02-09-2010, 08:14 PM   #1
11flat
11flat's Avatar
Drives: 2010 camaro ss/rs m6
cutting bump stops? pfadt
What is the point of cutting the bump stomps when installing pfadt drop springs? Is this what actually lowers the car?
11flat is offline   Reply With Quote
Old 02-09-2010, 08:53 PM   #2
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
No it isn't what actually lowers. It must be cut as to not bottom out before it normally would.
At least that's the way I understand as the purpose. But I know it isn't what lowers. If that were the case, you wouldn't need the new springs. lol
Old 02-09-2010, 09:03 PM   #3
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
It provides your factory shock with a bit more travel before bottoming out. When you lower a car and keep the factory shocks, it reduces the available shock travel. Cutting the bump stops (they are inside the shock dust cover) gives a little more travel back.
Here is my how-to article on the Pfadt springs. You will see pics of the bump stops, they are the yellow-ish rubber things.
http://www.planetlsx.com/tech/How_To...010_Camaro/131
Fquick.com/NineBall
Old 02-09-2010, 09:44 PM   #4
PQ
Booooosted.
PQ's Avatar
GREAT write up. I printed and used it. Right down to the last tool needed.
Old 02-09-2010, 10:38 PM   #5
11flat
11flat's Avatar
Thanks Guys!!
Old 02-15-2010, 03:50 PM   #6
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi 11flat,
Very sorry for the late response. Sounds like you got everything taken care of already. I'd like to explain why we reccommend cutting the bumpstops in our procedure. Our Pfadt drop springs provide a 1.25" drop approximately. As a result of this change in static ride height, the usable region of the damper travel is offset, to be approximately 1.25" lower. The Camaro has a very limited amount of bump travel to begin with, before contacting the OEM bumpstops. We recommend to trim 1" from the bumpstop in our installation procedure to give you back that 1.00" of damper travel, that is not influenced by the added spring rate of the bump rubber. We leave some bump stop in place to give a rising rate on big hits. Because dampers function by resisting the shaft velocity, this offset operating region has no negative effects on the component durability, or performance.
This conclusion was made from testing, and experiencing harsh bump characteristics that some have mentioned, who have not cut them. This of course, is just our position in regards to our own product installation. I hope that helps clarify the reasoning.
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 10:31 PM
cutting the bump stops Alain Suspension / Brakes / Chassis 9 01-21-2010 05:55 PM
PFADT - Drop springs & Balance bars (Pics inside) CRUSHER2SS Suspension / Brakes / Chassis 12 01-05-2010 10:12 AM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 06:41 PM
