tandtperformance.com
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 02-09-2010, 07:25 PM   #1
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
removing the chrome taillight bezels
just wondering, if i were to remove the chrome taillight bezels on my car will water or anything getting into there cause any damage to the taillights or anything?
LosXC451 is offline   Reply With Quote
Old 02-09-2010, 07:39 PM   #2
RCLapCar
RCLapCar's Avatar
Drives: 2010 2LT/RS A6 IOM/IO
Nope, those things don't seal the lights as far as I can tell.
2010 2LT/RS A6 IOM/IO - 2G1FC1EV9A9180784 - Airaid V2 - Solo Catback w/ J-Pipes
RCLapCar is offline   Reply With Quote
Old 02-09-2010, 07:51 PM   #3
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
The chrome bezels do absolutely nothing other that to cover there own hole slots and to fill the gap around the lights... They do not stop water from running behind the lights. If fact. If you open your trunk lid. On each side where the black plastic covering is. Water in channeled behind it and down behnd the light sockets. So, if you decide remove the bezel. For what ever reason. You can paint them, or remove them and leave them off. Although you'll see the gap around the lights and also the hole slots for the bezels. Most of the users are painting them either black or there car color and reinstalling them. A few of us have left them off. I left mine off and used a marine/auto black gasket to fill the void around the tail lights. To each his own! Mod away...
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 02-09-2010, 08:07 PM   #4
LosXC451
LosXC451's Avatar
ok thanks
Old 02-09-2010, 08:26 PM   #5
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
They just look funky without them.
vs
Old 02-09-2010, 08:28 PM   #6
LosXC451
LosXC451's Avatar
vs
yea im considering painting them black too i havent decided yet, i wanna take them out first and then decide whether i like them like that or not, but i cant figure out how to pop them out i can get to them fine but just getting them completely off is a problem for me lol
Old 02-09-2010, 08:48 PM   #7
scythezo6
scythezo6's Avatar
Just gotta work at them. I pried the top 2 tabs, and the top side-tabs loose then just pushed out on the tabs. Think of trying to push the bezel out of the housing from the inside. If you push on the tabs evenly then the whole thing should pop out (even without out loosening the hard to reach ones). Be prepared to have sore finger tips.
Old 02-09-2010, 09:02 PM   #8
Bone
Bone's Avatar
I've posted this previously. I removed my bezel and installed a marine/auto black rubber gasket around the light housing. Rememer, the bezel does nothing. so its not an issue of sealing up water tight. Check out these pics of my RJT 2SS LS3 rear end. (see don't mind)
Comment welcome. If anybodies interested in this mod. I'll give it up. Easy DIY.
Old 02-09-2010, 09:07 PM   #9
LosXC451
LosXC451's Avatar
looks good, a DIY would be nice if you could.
Old 02-09-2010, 09:08 PM   #10
LosXC451
LosXC451's Avatar
thanks ill try that out and see how it goes for me
Old 02-09-2010, 09:28 PM   #11
masterofpuppets
Pulling your strings
masterofpuppets's Avatar
Drives: My girlfriend crazy with car talk
What did y'all use to paint them? Just a fine light sand and paint?
masterofpuppets is offline   Reply With Quote
Old 02-09-2010, 09:47 PM   #12
Bone
Bone's Avatar
Very true...
Old 02-09-2010, 10:20 PM   #13
midnight2010camaro
Drives: 2010 camaro 2SS, 2004 GMC sierra
i odered some from this webpage http://www.cleancutcreations.com/catalogpage3.html
if you send them yours then its not as much.
midnight2010camaro is offline   Reply With Quote
Old 02-10-2010, 06:23 AM   #14
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
To save your finger tips.... Once you get the top loosened up, take a flat head screw driver wrapped in a towel and stick it in the gap between the bezel and the taillight and just turn the screw driver slowly to work the bezel out. Work the screw driver from the middle to the bottom and it'll pop out.
amanc96 is offline   Reply With Quote
Old 02-11-2010, 08:51 AM   #15
CPanther95
Drives: Rally Yellow 2SS/RS
Give it up.....please.
That's the best look I've seen for the taillights. Was going to go black, but that looks so much cleaner.
CPanther95 is offline   Reply With Quote
Old 02-11-2010, 09:32 AM   #16
Bone
Bone's Avatar
Yes, I can that do that. I prefer this look too. I will upload a pic of the Rubber gasket with the brand name too. I will post a brief explanation on how to do it later this evening, I'm at work now. If you already have the lights out of the bumper. Its very easy to install and just takes a few minutes. And It only cost me $7.99 + tax for the gasket. Also, You will need a little 100% silicon. If you wish to PM. w/ph#. I can call you later this evening and explain in detail.
Old 02-11-2010, 09:55 AM   #17
ttexxan
Drives: 2010 Camaro SS/RS
There is a utube video out on this and didnt see the guy using silicone
ttexxan is offline   Reply With Quote
Old 02-11-2010, 10:04 AM   #18
Bone
Bone's Avatar
I didn't see the video. The gasket has a sticky tape on the backside. But I used a little silicon because the stick tape doesn't really adhear to the rim of the light housing very well. It does stick. But I wanted a little better hold. I would imagine you really don't have to use it. I also used it the seal the two ends where the rubber come together. You probably don't need it there either. This is the way I did it. But you can improvise...
p.s. Do you have the link to the video? Might help others...
Old 02-11-2010, 11:54 AM   #19
mattbaer
Bone, Like the look. looking forward to the DIY
mattbaer is offline   Reply With Quote
Old 02-11-2010, 12:00 PM   #20
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Looks amazing on black cars, mine were off the day I bought the car. theyll never go back on lol.
THUMPER20X is offline   Reply With Quote
Old 02-11-2010, 12:37 PM   #21
LosXC451
LosXC451's Avatar
I took a pic of my taillights with one bezel off and the other on, will try to put the pic up later. IMO it looks better with them than without them on SIM bc you can see the gap clearly.
Old 02-11-2010, 12:52 PM   #22
ttexxan
You have to put the black gasket between to look better I will find the video and post in a sec
Old 02-11-2010, 12:53 PM   #23
ttexxan
Here ya go this is part two of video...show putting trim in
Oh and this is one guy put together about removing but I have heard you dont have to take apart the bumper
Old 02-11-2010, 01:02 PM   #24
LosXC451
LosXC451's Avatar
yea you dont have to remove the bumper to remove them
thanks for the video this will help alot
Old 02-11-2010, 01:08 PM   #25
CPanther95
That looks simple enough.
PAINTED and BLACK CHROME TAIL LIGHT BEZELS!!!!!!!!!!!! orange10s.c. Exterior Parts & Accessories 394 05-01-2013 07:34 PM
Pic Request: Painted Taillight Bezels SamSS Camaro Photos | Spyshots | Video | Media Gallery 7 04-02-2010 12:17 AM
Blacking out my tail lights bezels. zsuns Cosmetics and Lighting Modification Discussions 13 02-02-2010 08:56 PM
removing gfx chrome bezels? jeffny09 Cosmetics and Lighting Modification Discussions 20 11-30-2009 08:04 PM
Thought this was strange. . Chrome Taillight accents franknbeans 5th Gen Camaro SS LS LT General Discussions 83 07-21-2009 08:16 AM
