sjm autoprod
Old 09-03-2008, 04:22 PM   #1
brotherben
brotherben's Avatar
Drives: 1994 camaro 6 cil. all stock
you guys look smart.
Hay guys, well today someone almost backed into me I have a 94 camaro. When I went to use the horn it did not work also I have power locks and the power lock does not work on my drivers side door but it does on my passenger side door (i have to lock the car on the passenger side) But on both side the unlock works. So I don't know if they are tied together ,but I would like to know what you guys think. Thanks in advance.
brotherben is offline   Reply With Quote
Old 09-03-2008, 05:48 PM   #2
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
I would suspect seperate problems here. Check the fuses first, then the horn relay, then the horn contact under the steering wheel. You can also try supplying 12v direct to the horn and make sure it isn't burned up. And replace your door lock switch.
Robert91RS is offline   Reply With Quote
Old 09-03-2008, 05:53 PM   #3
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
I've had several electrical things that didn't work when I bought mine. Check the fuse panel under the hood. Pull each fuse and circuit breaker and replace. Seems its common for the contacts to loose connection after a while. Removing and replacing seems to fix most of the problems.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 09-03-2008, 06:00 PM   #4
-RO- Upgrade
-RO- Upgrade's Avatar
Drives: 3.4 v6, black CamaRO
Send a message via Yahoo to -RO- Upgrade
Sup everyone, I got a question but u might not be able to help me with this one...lol See I am rebuilding my 95 camaro & can't wait till its done but I am putting a lambo door kit on it & its going to be gas powered but my question is " IS IT GOING TO WORK WITH A 130 DEGREE INSTEAD OF A 90 DEGREE " well if u kno please message me back or post, I would be very greatful cause this shit dont come cheap....lol
HELP
-RO- Upgrade is offline   Reply With Quote
Old 09-03-2008, 08:08 PM   #5
brotherben
brotherben's Avatar
Hay guys I already checked the fuses inside. Tomorrow when I get home from school I'll check the fuse box under the hood and the other stuff mentioned. I'll get back to you and let you know how it's going.
Old 09-03-2008, 08:28 PM   #6
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
looks are intimidating
Old 09-03-2008, 09:41 PM   #7
Angrybird 12
6 year Cancer Survivor.
Angrybird 12's Avatar
Drives: 12 CAMARO, 13 Encore, 07 Colorado
If not a fuse or the switch, I hate to say you may have some broken wires in the boot that is between the door and the body.. Had the same thing happen to an old Astro van I had.. Many years of flexing will break those tiny wires in there and you may not even be able to see where untill you grab each wire and flex it individually, If you have power windows you may have a problem soon with those wires also..
the horn should have nothing to do with the power door locks, more than likely the relay or horn it's self.
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
Old 09-04-2008, 03:53 PM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
hold on a min... im getting all the info and pics you guys need.
I piss excellence
and fart awesomeness
Old 09-04-2008, 04:04 PM   #9
CamaroSpike23
Truth Enforcer
ok ben. go out to your car, remove the bottom plastic pnl on the pass side, (#20 in this pic: http://shbox.com/1/ftbumper.jpg )
to access your horn.
check the wiring on the horn itself
you can see the horn and the connector in this pic: http://shbox.com/1/ft_signal.jpg
there should also be a vacuum line on the horn as well
clean the connector and make sure its on good.
check the horn, if that doesnt work, check the relay on the audio control module
http://shbox.com/1/flashers.jpg
might just be the relay or fuse for the horn, or the horn might be bad. mine went out on me, checked the fuses and relays, and it turned out to be a bad horn. 180k on it. so i swapped it out with a new one.
as for the door locks, your drivers side switch is probably bad.
I piss excellence
Old 09-04-2008, 04:06 PM   #10
CamaroSpike23
Truth Enforcer
which way are you wanting to open them 130*? upwards? as long as the actuator and hinges are capable of supporting the weight of the doors, then yes it should work, but be careful as the mirror might come in contact with the front fender when the door is raised that way. also, you might have to extend all the wiring to the power windows/door locks/mirrors/etc so that it will reach without snagging when you open the doors all the way up.
I piss excellence
Old 09-04-2008, 07:44 PM   #11
brotherben
brotherben's Avatar
Thanks I'll try tomorrow I don't have any tools. my friend does but its to late to bother him. By the way I checked the horn relay fuse in the fuse box and it was bad, I put a new one in and the horn is more like a light buzz than a horn, its barely hear-able (I make up words ). Also with my door lock problem when I use my key chain lock remote to lock the car the lights flash like it locks but you dont hear the lock click but the unlock you do hear it. So you said that its the driver side switch thats bad, hopefully when I replace it it will work.
Old 09-04-2008, 08:02 PM   #12
brotherben
brotherben's Avatar
I was wondering when you said "ok ben. go out to your car, remove the bottom plastic pnl on the pass side, (#20 in this pic: http://shbox.com/1/ftbumper.jpg )" is that in the car passenger side or under the hood? It looks like under the hood but the cut away pic is a little confusing. thanks
Old 09-05-2008, 11:39 AM   #13
CamaroSpike23
Truth Enforcer
sorry, pass side. didnt even realize there were two 20s in the pic.
I piss excellence
Old 09-05-2008, 11:40 AM   #14
CamaroSpike23
Truth Enforcer
so is it still locking when using the remote?
I piss excellence
What do you guys think of these wheels? RODTANA Wheels and Tires Talk Sponsored by The Tire Rack 29 10-01-2009 01:37 PM
So what are your guy's choices? 16yearoldcamarodriver 5th Gen Camaro SS LS LT General Discussions 160 09-09-2008 06:42 PM
I saw Get Smart Dave McFly Off-topic Discussions 5 07-01-2008 05:09 AM
GM Achieves Breakthrough with Smart Materials TAG UR IT Off-topic Discussions 7 03-29-2007 10:51 PM
