JDP Motorsports
Old 02-11-2010, 12:09 PM   #1
DSteck
Drives: 2006 Corvette Z06
defeating the fuel pressure control module... how are you doing it
Seeing as how the stock pump runs out of steam, and it's not possible to get a BAP functional... how have people defeated the FPCM? The fact that it only allows 12V to the pump, regardless of input voltage, kind of hinders things, combined with the pulse width modulation. For boosted guys, what have you done to supply the fuel needed to keep going? I've heard of some people using a second pump on a hobbs switch to feed the rest of the fuel, but I'd like to avoid a rich spike when hitting boost. I'm interested in setting up a return-style system using a second pump on a hobbs and a vacuum referenced FPR to try and stabilize the pressure delta over the injectors, but I don't know if this will interfere with any diagnostics or if the PCM actually measures rail pressure. With the rail seeing lower pressure during manifold vacuum and higher pressure during manifold boost, I don't know how the PCM or FPCM will respond.
So... anybody have experience with a good, stable setup?
DSteck is offline   Reply With Quote
Old 02-11-2010, 02:06 PM   #2
Mike@DS
Drives: 99 Z28
Hmmm...I'm pretty sure we had a 2010 Camaro with a BAP on it here, I know it did NOT work properly at first, actually causing pressure to drop, but after the builders did their homework on the vehicles wiring, they figured something out and made it work, I'll see if I can find out...
Mike@DS is offline   Reply With Quote
Old 02-11-2010, 02:23 PM   #3
jrpxxii
jrpxxii's Avatar
BAP does work but still not best option. I have the BAP as well but I also went ahead and did the dual fuel pump by Fastlane and has cured all pressure issues.
Old 02-11-2010, 03:59 PM   #4
pnyklr
Drives: A Gift From My Wife
Uhm, guys, how about some English for the rest of us?
-Funk
pnyklr is offline   Reply With Quote
Old 02-11-2010, 04:17 PM   #5
Mike@DS
Drives: 99 Z28
-Funk
BAP-Boost a pump.
FPCM-Fuel Pump Control Module
FPR-Fuel pressure regulator
Old 02-11-2010, 04:49 PM   #6
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Fastlane sells a dual fuel pump module that just runs 2 pumps off the cars FPCM and uses the existing returnless style system, this probally not what u need.
IPS motorsports is working on a duel intank setup that will not use a FPCM but work as a return fuel system so u could use a map reference regulator, you might want to call them to confirm this but I do not think the ECM cares whether there is a FPCM hooked up or not.
There is a DTC that the FPCM request everytime I blew the fuse to mine but it could obviously be tunned out if needed.
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 02-11-2010, 07:59 PM   #7
DSteck
I'll speak with Brandon at IPS tomorrow. The vehicle doesn't NEED to be converted to return style, but I'm definitely not against doing it. If the dual pump setup is stable and won't produce pressure spikes, then it'd be fine. I just want realiable and predictable operation. The SD 60s will work great either way.
Old 02-11-2010, 08:47 PM   #8
ADM PERFORMANCE
Drives: 2016 CAMARO SS
It is alot of work,I think we have mastered it pretty well.The complete system with labor was over $3000.00(Mostly labor).Well worth it in the end,on a dry nitrous system we were 11.9 afr at 6600rpm at well over 1000hp at the engine.
Fpcm can be kept or deleted..your choice.We also recommend a Kennebell Boostapump,They do work when installed properly.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 02-11-2010, 09:58 PM   #9
Mike TexaSS
Drives: 454 LS7 Camaro SS
Andy
Yes they do!
Mike TexaSS is offline   Reply With Quote
Old 02-12-2010, 07:35 AM   #10
DSteck
Sounds like eliminating the FPCM is the best bet.
This isn't my car, but one I'll be tuning, and I just want to know that it will not have weird problems or run out of fuel.
Old 02-18-2010, 09:49 PM   #11
Petersimov
Drives: 2ss
can anyone tell me how to wire a kb bap on the camaro
Petersimov is offline   Reply With Quote
Old 02-19-2010, 10:18 AM   #12
FLP
FLP's Avatar
Drives: 2010 FLP/Nickey Twin Turbo Camaro
Lonnie's Performance now has a plug and play drop in 2 pump system for these cars.
He is going to be building us a 3 pump system for ours... :-)
2010 FLP/Nickey Twin Turbo Camaro 427ci, 10psi, 801RWHP 775RWTQ... More boost to come!
FLP is offline   Reply With Quote
Wiring in a KB Boost a pump R8cerX Forced Induction - V8 56 12-01-2010 02:54 AM
Wanted: 2010 V8 fuel pump module CarlC V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 02-21-2010 07:34 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 03:42 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
