Emblempros
Old 07-28-2011, 07:38 PM   #841
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
I need one of these like I need a hole it my head, but after driving Russ's around the neighborhood I think I really do NEED one now...
You definitely don't want to let the Valet park it...
Old 07-28-2011, 07:49 PM   #842
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
... Ferris Buehler's Day Off comes to mind...
Old 07-28-2011, 08:17 PM   #843
Darth_Emma
Darth_Emma's Avatar
I'd love a full review of this tranny...
Old 07-28-2011, 08:20 PM   #844
mlee
www.CamaroFans.com
mlee's Avatar
Exactly...
Old 07-28-2011, 08:29 PM   #845
mlee
www.CamaroFans.com
mlee's Avatar
The shift pattern goes like this (If I remember right)
P
N
R
4th
3rd
2nd
1st
So from park you pull back twice to Reverse... then you ratchet back 6 times to get to 1st... no need to count because you feel the 7th pull is stopped.
Then just ratchet forward one at a time as you go up in gears and pull back to downshift... (No mercy you push or pull and it goes) Once you get to 6th it won't push forward until you push the red lever forward. So if you pull up and stop in 3rd gear you would have to push forward twice and then flip the lever to tap back up to park.
Hope I got all that right... as you can see I'm pretty excited about Russ's new toy also...
Old 07-28-2011, 08:51 PM   #846
Darth_Emma
Darth_Emma's Avatar
P
N
R
6th
5th
4th
3rd
2nd
1st
So you can't accidentally go from 6th at 80 mph into reverse?
How natural does it feel to shift? Do you think it shifts faster than the stock auto tranny?
I guess I want to know all the advantages (and disadvantages) of this new tranny.
Old 07-28-2011, 09:00 PM   #847
mlee
www.CamaroFans.com
mlee's Avatar
Very natural shifting (I had to think about it, but I'm sure it's 2nd nature to Russ by now)... and it's way faster than the stock tranny. I think his is wired or will be wired to display the gear in the DIC like w/ paddle shifters.
Owen explained it to me this way... it's like lining up 6 gears on a rod.. then slide them all the way to the rear and just slapping one right up next to the other... one at a time. Very smooth shifting too.
Old 07-28-2011, 09:26 PM   #848
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Thanks. Traveling this week, but I'll try and put something together when I get home.
No clutch pedal. Click forward to upshift...back to downshift.
Manumatics are so cool - very nice Russ !!
Just don't forget to put it in first when you come up to the light. Also, I assume the converter can't lock in the lower gears.
A blast to drive. Nice.
Old 07-28-2011, 09:31 PM   #849
mlee
www.CamaroFans.com
mlee's Avatar
The Thumb button is set to lock the converter. I think it will lock in lower gears..(could be wrong) Also notice the switch by the cup holder... that's a converter lock for the highway.
Old 07-28-2011, 09:34 PM   #850
jrpxxii
jrpxxii's Avatar
Just curious as to what made your decision to go with this setup instead of a built 4l80e auto with a trans brake if you ever decide to run it at the track? I just took my manual out and am swapping to a built 4l80e with a trans brake. Not saying it is bad but just curious as to how you made your decision as I loved driving a manual but for my setup the auto setup was best for me. Sweet ride by the way. You will love the LSX 427, it is a true beast and absolutely insane with alot of boost.
Old 07-28-2011, 09:48 PM   #851
mlee
www.CamaroFans.com
mlee's Avatar
One of the cars Owen did (Madd600) has the same tranny w/ a controller that does all the shifting so it's fully automatic. Russ has the option to do this also.
Old 07-28-2011, 11:58 PM   #852
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
P
N
R
6th
5th
4th
3rd
2nd
1st
Corrections (only 4 gears):
P
Space
R
N
4th
3rd
2nd
1st
You can go into neutral from 4th gear, but you have to use the release to go into reverse.
Exactly...it's for safety. Since this transmission is completely manual, you could also technically start it in 1st. To prevent this, Owen set it up so it won't give me the key back unless the car is in park or neutral.
The shift feels great, and took me about 5 minutes to get used to. The shift is instantaneous.
I really wanted a manual car originally, but didn't want to have to ride a clutch every day in traffic. This gives me the fun of shifting without it. I can stay in boost through every gear, and it should handle all the power I throw at it.
I also figure it will be a good theft deterrent, since they probably won't know how to drive it. If it ever comes up stolen I'll just send the cops to Mlee's house.
The only disadvantages would be shifting (if you don't like that), and no more valet parking.
Shifting is very natural after a few minutes. My car doesn't show me which gear I'm in, but it will tell me when I'm in reverse.
It will actually roll in 2nd, but it obviously bogs and let's you know to shift back down.
What he said.
I will be running it down the track, but have decided to wait until the 427 goes in. I really love shifting, and will enjoy the challenge.
Correct...just chose not to.
Old 07-29-2011, 10:05 AM   #853
mlee
www.CamaroFans.com
mlee's Avatar
Bout time you showed up... I was having a field day in your thread...
Old 07-29-2011, 10:52 AM   #854
10spokess
Wild and Cammed
Drives: 2002 Camaro SS
You have convinced me to get this set up for my car I actually just found one I can't wait to get it in man. Sorry if I am stealing your idea I just wanna have fun lol
10spokess is offline   Reply With Quote
Taylor's 2010 Camaro SS [COTW 12/13/10] TaylorRyanSS Member Car Journals 555 05-24-2014 03:54 AM
2011 SS Detnews review - 2011 Camaro SS Fits In With Classic Cruisers Johnnyma45 5th Gen Camaro SS LS LT General Discussions 21 09-05-2010 02:15 AM
SS: 1SS and 2SS The_Blur 5th Gen Camaro SS LS LT General Discussions 86 03-12-2010 12:12 AM
Review of my Camaro SS (Rental from Avis) clan0013 5th Gen Camaro SS LS LT General Discussions 19 02-15-2010 06:10 PM
Anyone with an HHR SS or Implala SS caverman 5th Gen Camaro SS LS LT General Discussions 1 02-06-2010 06:45 AM
