02-11-2010, 07:13 PM | #1 |
Drives: 2010 Camaro RS/2SS Join Date: Jan 2010
Build your own cai, no codes.
This is a bit old but had some intrest so I decided to update the thread. I have not had it run on a dyno yet but have not had any codes or
issues for almost a year. I did add a lid bc I had trouble matching the hood angle. I may add a plexi window too. It sounds amazing also. The air temp studies are not exact data by any means, because of different driving temps and conditions. The stock box does a very good job maintaining temps, it just flows like crap! Here is the list of parts needed. I left out prices because they may change. Overall I was under $100. 2010 Camaro CAI Parts List... IntakeHoses.com #90L40 Rubber Elbow 4" ID X 90 Degree #AL4X12 Aluminum Intake Tubing 4" OD X 12" Long, will need cut and polished. #94100-0450 T-Bolt Clamp for 4" ID Black Rubber Intake Hoses 3 SummitRacing.com THE-14610 Heat shield backing mat. McMaster-Carr or hardware store. Edge seal, about 7 feet #12335A14 Paint is from, AutomotiveTouchup.com Ebay or fav store. K&N Filter # KNN-RF-1034 Misc hardware. 20 gauge sheet metal 24x36 Lid was made from Alu. 3/8 x 18" fuel or vacuum line 3/8 barb splice fitting. Last, a little blood sweat and tears! Build video HD. Stock Air Temp study I did HD. CAI Air temp study. This also proves why a lid or good seal to the hood is important! After sitting for a long time the 100+ temp under the hood can be sucked into the car. Pics
1100, Preliminary order accepted (01/30/2010)
6000, Delivered to the customer (02/27/2010) YA, she came that quick! $IMJAYBIRD$ Last edited by Imjaybird; 02-27-2011 at 09:53 PM. Reason: Added Pics from under side |
02-12-2010, 11:21 AM | #2 |
It the toybox 4 winter
Drives: LSA 68f100 pickup/2010 rs/2ss abm Join Date: May 2009
this is what we did for my cousins caddy cts-v, if you read it , it lists the parts required and then has photo's to show you what we did! it sounds absolutely rediculous but looks just like a storebought one. they use crappy plastic or aluminum heatshields anyway, and this one truly fits tight to the hood. datalogging revealed that the intake air is alot cooler then with the stock airbox. don't laught, it works well and nobody can tell! heres the link
http://www.trafficjams.ca/Performanc...Air_Intake.htm |
02-12-2010, 01:54 PM | #3 |
Drives: Black SS/RS Join Date: Nov 2009
That is a pretty sweet write up for the caddy
Black SS/RS - Magnaflow Comp Series, Eibach Suspension, Roto-Fab Intake
02-12-2010, 03:22 PM | #4 |
Ya, I built my own for my GTP and had no issues except envy for the supercharger sound. My only concern is companies say they design the tube to get the most horsepower. I say it is crap as long as your getting the most volume and coldest air possible. If it sounds like a straw then you could just increase the tube or filter size. Also I can do my own welding and polishing or cermic painting.
Anyone else see any issues here please inform me...
6000, Delivered to the customer (02/27/2010) YA, she came that quick! $IMJAYBIRD$ |
02-12-2010, 03:40 PM | #5 |
Great work on the catie, I seen one of those on a dyno and they are sick!
02-12-2010, 07:23 PM | #6 |
02-12-2010, 09:10 PM | #7 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Here's a good place to start, replace that ugly factory intake tube with this.
http://www.emblempros.com/inc/sdetail/4493 Only $89.95
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
02-24-2010, 09:26 AM | #8 | |
03-19-2010, 07:45 AM | #9 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I did a DIY FWI on my 04 Monte Carlo SS. It was inexpensive and worked like a champ. I plan on doing something very similar to my Camaro. I just ordered 6ft of 4" ABS for $18. I'm going to use a trash can like in the write up for the heat shield. That shouldn't run more than $5. The filter runs $49. The fittings shouldn't run more than $10 so, that brings the total for a CAI to roughly $85. Once I get all the parts in and do this I'll take pics and post a write-up.
03-19-2010, 07:58 AM | #10 |
"That Guy"
Drives: Camaro SS...........what else? Join Date: Apr 2009
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
Nice work on the caddy!
03-20-2010, 11:57 PM | #11 |
Complete
03-21-2010, 09:04 AM | #12 |
Darth Martel
that looks fantastic Imjaybird. Did you do that yourself?
03-21-2010, 09:38 AM | #13 |
Thanks! Ya all me.
45 for the elbow, tube, seal, and clamps, 45 for the K&N filter. 7 for the metal and 20 for the reflective heat mat. So about $120 plus 7 hours labor, mostly getting the dam heat sheild to fit good.
03-21-2010, 10:05 AM | #14 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Thread Tools | |
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
My small and mini review of the New Era CAI on my newly purchased SS. (pics inside) | bumblebeecamaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 01-24-2010 05:27 PM |
axle back and cai questions | larietrope | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 01-07-2010 08:49 PM |
"Resetting" the MAF vs. CAI install ... where's the hp coming from? | LS 1st gen | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 07-03-2009 08:42 AM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
