JUICEDMOTORSPORTS
Old 02-12-2010, 02:06 PM   #1
miltp
Jim Pappas
miltp's Avatar
Drives: Rally Yellow 2SS/RS,Auto,G/X
Diablosport Tune
When you do a tune in your camaro does it automaticly shut off the AFM and do torque management calibrations or is it somthing you have to do with a custum tune within your Diablo sport tuner. Thanks For the help, Jim
miltp is offline   Reply With Quote
Old 02-12-2010, 02:21 PM   #2
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
I have the diablosport but also have a LS3...so what i can tell you is that there is a tune built into the diablosport and when you install it, it will give you some choices right before it loads the tune to your car.....one of these items is the AFM......on mine...it let me choose to turn of the skip shift. If you want to talk to somebody with great prices and a wealth of knowlege, pm or Call Jannetty Racing.....Ted is great to work with! Plus if you buy from him, and you decide to change something, he can help with remote tuning!
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 02-12-2010, 02:27 PM   #3
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
You have to turn it off manually. It is an option in the "modify tune" section. They call it DOD not AFM.
EDIT: There are NO torque management options other than to shut it off completely (IIRC). They state they have "optimized" them as part of their tunes.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 02-12-2010, 02:49 PM   #4
06MonteSS
Drives: 2006 Monte Carlo SS
correct...
under Modify Tune, there is an option for the DOD where you can go in and disable it...
as for torque management, there are no end-user adjustable parameters for that - the engine TM is already reduced/removed in the tunes...
06MonteSS is offline   Reply With Quote
Old 02-13-2010, 02:47 PM   #5
miltp
Jim Pappas
miltp's Avatar
Thanks alot guys,just one more question though.Do you Manually put in the the changes you want first then put in the Diablo sport tune. Thanks for any help.
Old 02-13-2010, 02:57 PM   #6
tony1
tony1's Avatar
Drives: 2SS/RS Vortech/L99
if Torque management is removed does this cause any issues with the Tranny down the road or is this safe??
tony1 is offline   Reply With Quote
Old 02-13-2010, 03:03 PM   #7
06MonteSS
you can do it when you initially install the tune, or afterwards, doesn't matter...
if you want to make changes/adjustments after you've already installed one of the diablo tunes, you simply connect to your car, select the same diablo tune that you installed before, and then - instead of selecting Install Tune - you select Modify Tune... then scroll through the parameters to get to the parameters you want to modify... select the parameter menu/submenu, make your adjustment/change, press the Enter/Center button to save the change, then press the ESC button a few times to back out of the menus, and it will prompt you and ask "Install Tune Now?"...
answer/select YES, and it will install the diablo tune with the adjustments/changes you made to it...
Old 02-13-2010, 03:05 PM   #8
06MonteSS
None of the TM is removed/reduced in the tranny/TCM...
it is only reduced/removed on the engine-side of the tune so that you get the most allowable power available sent to the tranny/wheels...
and yes, it's safe...
Old 02-14-2010, 03:41 PM   #9
miltp
Jim Pappas
miltp's Avatar
Thanks alot MonteSS ,you answered all my questions.Its people like this that make these forums so great. Thanks again Jim
Old 02-14-2010, 06:44 PM   #10
06MonteSS
cool...
np man, you're welcome...
Old 02-17-2010, 08:52 PM   #11
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I just installed my Predator Tune on my 2010 Camaro LS3. I only had two options, Diablo Tune and 91oct tune. Which one should I pick? I have a Airaid CAI, and Muffler delete.
Thanks for the help.
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Tinted 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 02-17-2010, 09:44 PM   #12
steeleshark2
steeleshark2's Avatar
Diablo tune is 93 octane tune.
Old 02-17-2010, 10:01 PM   #13
06MonteSS
correct... what Steele said ^ ^ ^
the Diablo Tune is made for 93 octane gas... and then there's the 91 octane tune...
so, if you have access to, and use, good 93 octane gas in your car, install the Diablo Tune...
but if you're area is like California and only has 91 octane gas available, then install the 91 octane tune...
Old 02-17-2010, 10:11 PM   #14
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Thank you, I live in AZ, so I am good with the 91 oct tune, how do I take out the skip shift? Is it the CAGS On/Off setting?
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 Yesterday 12:30 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Diablosport Trinity: New Lower Price $599 @ BMC Performance Kris@BMCPerformance V8 Bolt-Ons & Tunes 11 02-18-2010 08:00 PM
which vendors will INCLUDE a custom tune with purchase of diablosport predator? Mustang Killa Tuning / Diagnostics -- engine and transmission 7 02-11-2010 09:41 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
