JDP Motorsports
Old 02-24-2010, 08:26 AM   #29
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Originally Posted by CaliEMT View Post
I know I'll sound nooby but how will the diff octanes affect the car?
And are there any downfalls to using higher octanes on the Camaro? The dealer told me to use regular always.
research "Engine Knock" http://en.wikipedia.org/wiki/Engine_knocking
then read the "fuse pull" thread http://www.camaro5.com/forums/showthread.php?t=38964
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 03-01-2010, 08:05 PM   #30
06MonteSS
Drives: 2006 Monte Carlo SS
Originally Posted by Ohten View Post
I just picked up my Diablo Sport and the speed shop I purchased from installed the tune.The reason I purchased the D.S. was to get rid of AFM,I asked him if AFM would be turned off with just the tune alone and he said it disables it automatically.Who is correct here and can someone tell me exactly what was changed with the tune.I did a search and came up empty,I have owned my car for only a month,so maybe I missed that thread.
no, the AFM/DOD is not disabled automatically when you just install the tune... you have to go in and set it to off, then install the modified tune with that change...
hook up to your car... select the same diablo tune that was installed before, and then select "Modify Tune"... select the AFM parameter, and select/highlight "OFF", press the center button on the predator to save your change, then press the ESC button a few times to back out of the menu, and it will ask you, "Install tune now?" - answer/select YES and it will install the modified tune with the AFM/DOD turned off...
06MonteSS is offline   Reply With Quote
Old 03-02-2010, 06:47 AM   #31
06MonteSS
you can just unplug it... good to go...
Old 03-02-2010, 07:01 AM   #32
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
A while back you guys said you were working on TCM tune... what's the status now?... did it ever happen?
Old 03-03-2010, 09:43 PM   #33
brtaus
brtaus's Avatar
Drives: None
Originally Posted by tom692010 View Post
if load the 91 octane tune do I them have to go into modify tun to disable the skip shift?
I didn't have to....
brtaus is offline   Reply With Quote
Old 03-04-2010, 02:02 AM   #34
chevyss
SS/RS
chevyss's Avatar
Drives: 2010 SS/RS IOM w/blk stripes A6
I purchased my Preditor last year. I have yet to install it because the car was put away for the winter. Are there any updates to the tune that is installed in it from last year??
I'm a real weenie when it comes to all this electronic stuff. I'm still looking for someone to help me install the tune.
chevyss is offline   Reply With Quote
Old 03-04-2010, 08:43 AM   #35
Mike@DS
Drives: 99 Z28
The latest revision is 9r14, would not be a bad idea to update it if you have not yet used it.
It is super simple to install, go for it!
Mike@DS is offline   Reply With Quote
Old 03-04-2010, 10:14 AM   #36
06MonteSS
power it up - and once it boots up and is at the main menu, there's a number at the top of the screen - that's the revision number...
what's that number?? that will tell you what revision it's already on...
Old 03-04-2010, 10:41 AM   #37
06MonteSS
hahahhaa... he's B.S.-ing you man....
can't tell...
hahahahaa... that's funny...
well, let me rephrase that... maybe you can with some of the other tuners/programmers that are out there... but not if you use a diablo predator or trinity... heh...
Old 03-04-2010, 10:43 AM   #38
mlee
www.CamaroFest7.com
mlee's Avatar
Old 03-04-2010, 11:05 AM   #39
06MonteSS
it's in the process of "happening"...
tcm's are on the bench being tested with the flash process...
Old 03-04-2010, 12:21 PM   #40
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
OK so I have read through the tread, I have a L99 with 3000 miles no engine mods yet, plan on a CAI and exhaust next couple of months, maggie end of the year (oh and its a CA car 91 octain). My question is do I do a tune now or after the mods (I want the AFM gone) and if its before do I have to change it as I make changes? It sounds like the Diablo is the best one out there, not familiar with these at all and that they are sort of just plug and play. Does it hold multiple tunes so that I can switch back to factory so as not to void warranty when taking it in for service? Thanks
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 03-04-2010, 12:32 PM   #41
mlee
www.CamaroFest7.com
mlee's Avatar
Do the tune now... It holds your original tune in storage along with other tunes you can get done by Jannettey or the Diablo guys. Super easy to install the Diablo 91 octane tune right out of the box. Catback and CAI work great with the Diablo... Once you get into headers you might want to get a custom tune for your Diablo to tune out O2 codes. Once you are at the Maggie level then you will get a different tune altogether. Check out their website and forums for more info.
Thanks... I'll leave you alone and go back to eating popcorn again...
Old 03-05-2010, 07:17 PM   #42
Ripptide56
Drives: 2010 2SS/RS
Does the predator change the shift points and pressures in the tranny?
Ripptide56 is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3340 04-20-2017 10:24 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Diablosport Trinity: New Lower Price $599 @ BMC Performance Kris@BMCPerformance V8 Bolt-Ons & Tunes 11 02-18-2010 07:00 PM
which vendors will INCLUDE a custom tune with purchase of diablosport predator? Mustang Killa Tuning / Diagnostics -- engine and transmission 7 02-11-2010 08:41 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
