JDP Motorsports
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 02-12-2010, 07:22 PM   #1
Camaro21
Camaro21's Avatar
Drives: 2010 2SS/RS M6
The Plug & Play Harness for RS DRL & Fog Light are Ready
Adaptive Performance has the Plug & Play harness available to turn the RS DRL's into Fog Lights at night. I just bought mine. $38.50 & Free Shipping..
Here is their website..
http://www.adaptiveperformance.com/camarodrl.htm
I will post up pics when I get them installed..
Camaro21 is offline   Reply With Quote
Old 02-12-2010, 07:36 PM   #2
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
I just order minds thanks for the link.
Busy_Boi is offline   Reply With Quote
Old 02-12-2010, 07:40 PM   #3
monstertodd
Allyourbasearebelongtous
monstertodd's Avatar
I knew I should have waited before I cut up all my wiring.
Oh well.
Old 02-12-2010, 07:48 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I will need very detailed instructions on where and how this plugs in. I would love to get this if it's easy to install.
Old 02-12-2010, 07:51 PM   #5
IROCanSS
Drives: 89 IROC 350
it plugs in on the right side behind the bumper. You need to either go under the car or remove the wheel and inner fender.
Does this jumper prevent backfeed to the PCM?
Old 02-12-2010, 07:56 PM   #6
Darth_Emma
Darth_Emma's Avatar
I sent an email to the company and asked for instructions before I buy. I'll let you know what they say.
Old 02-12-2010, 08:01 PM   #7
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
Drives: 2010 Camaro 2LT RS
I was waiting for someone to do this so I would not have to. Ordered and on the way. Thanks Camaro21
Top Thrill is offline   Reply With Quote
Old 02-12-2010, 08:04 PM   #8
fireresq157
fireresq157's Avatar
Drives: 1997 SS & 2010 2SS/RS
Personally I think the yellowish DRL lights on at the same time as the RS white lights will look wrong. Theres a reason GM chose to do it the way they did, anyhow with the high intensaty RS lights there should no need for fogs. Let me know how it turns ot post some pics.
fireresq157 is offline   Reply With Quote
Old 02-12-2010, 08:23 PM   #9
Flynnaz
"Roll Out"
Flynnaz's Avatar
Drives: 2010 2SS/RS
Send a message via MSN to Flynnaz Send a message via Yahoo to Flynnaz Send a message via Skype™ to Flynnaz
I tested this harness, its easy to install. I ordered the LED lights for the DRL so it should look just fine.
Here is a link to my post #108;
http://www.camaro5.com/forums/showth...t=62386&page=5
Ordered on 3/31/09
_________________
1100 Preliminary order accepted 03/31/09
2000 Order accepted by GM 05/21/09
3000 Order accepted by production control 05/27/09
3100 Order available to sequence ???
3300 Order scheduled for production TPW 06/29/09
3400 Order broadcast 6/19/09
3800 Order produced 7/13/09 at 12:57pm vin 24881
4B00 Bayed 7/17/09
4200 Shipped 7/20/09
5000 Delivered to the dealer 8/6/09
6000, Delivered to the customer 8/7/09
Flynnaz is online now   Reply With Quote
Old 02-12-2010, 10:09 PM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: 2012 SS LS3
Can't ever turn them off, I think Ill wait for something a little smarter.
two_wheel_mayhem is offline   Reply With Quote
Old 02-13-2010, 01:35 AM   #11
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
I was just going to inquire about running a switch off that harness, should be pretty simple. Find which is the power and wire in a switch . The hardest part would be running the wire into the cabin.
daphatgrant is offline   Reply With Quote
Old 02-13-2010, 08:19 AM   #12
Flynnaz
"Roll Out"
Flynnaz's Avatar
Drives: 2010 2SS/RS
The harness is so easy to put on, you could easy take it off if you want. I believe it also has a diod built in for feedback issues. I have used it for a week now, no issues.
Ordered on 3/31/09
_________________
4B00 Bayed 7/17/09
Old 02-13-2010, 09:25 AM   #13
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Agree, but not sure I want to wait that long. If the hot wire to the DLRs can be intercepted, just running an intercept kill switch using a nice led light with your choice of light color could blend with interior nicely. Switches are $5 or under and could be wired "normally open" in off position, and "normally closed" in on position w/LED iluminating or vice-versa with LED illumination when lighting "killed". A second matching switch could control footwell lighting tied in with the dome lighting as a primary power source so always on with dome, and an override to turn on by themselves with power source just before door switching device and diode inline.
Wiring the DLRs this way would be good for those times you don't want to draw attention to your car at night to say "pull me over - here I am!"
I'll post when I get this far, but car is currently away and lots to do when it returns.
707 RWHP 655 TQ @91,TVS2300 10/14 OD 2.75/NW 102mm,RDS
NLP spoiler/GM splitter/Torq HE & fans/oil & tranny coolers
LPE Twin Pump,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions
StreetSlayer BC3,MTI Shifter & Trans mt/Hotchkis CB/Elite CC/SJM LineLock
PFADT Coil Overs,Bushes,Sways/Links,Engine Mounts,SF Bushes,Camber Kit
LPE Brotherhood
Old 02-13-2010, 01:20 PM   #14
Darth_Emma
Darth_Emma's Avatar
I agree. But, I have have installed the white LEDs to replace the OEM DRL bulbs and they look great. They match the halo/headlights very well. So, I'd like to be able to have the DRLs on with the halos.
Old 02-13-2010, 01:32 PM   #15
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Seems expensive for just a harness, but looks like it's well made so I'll probably bite .
TommyTSquared is offline   Reply With Quote
Old 02-13-2010, 06:19 PM   #16
Caution
Caution's Avatar
Drives: 2SS/RS 6M
ordered mine
Caution is offline   Reply With Quote
Old 02-13-2010, 09:30 PM   #17
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300
Mine will be on its way Tue
BUMBLEB is offline   Reply With Quote
Old 02-13-2010, 10:36 PM   #18
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: '12 370Z, '69 Camaro coming soon!
ordered one! I am not good at DIY stuff so I am glad this is available
2010 CAMARO SOLD! JOURNAL: http://www.camaro5.com/forums/showthread.php?t=119635 | FACEBOOK: http://www.facebook.com/taylor.ryan.apt | GRAPHIC DESIGN: www.aptdesigns.net
Old 02-13-2010, 11:00 PM   #19
cybercoaster
cybercoaster's Avatar
Drives: '12 ZL1 AGM
Where did you get the white LED?
Plasma DRL, footwell LED, Technostalgia taillights
cybercoaster is offline   Reply With Quote
Old 02-13-2010, 11:11 PM   #20
Flynnaz
"Roll Out"
Flynnaz's Avatar
Drives: 2010 2SS/RS
DRL LED replacement;
http://www.automotivelightstore.com/P13W.aspx
Ordered on 3/31/09
_________________
4B00 Bayed 7/17/09
Old 02-14-2010, 12:03 PM   #21
Darth_Emma
Darth_Emma's Avatar
And here is the thread about them with lots of pics:
http://www.camaro5.com/forums/showthread.php?t=53193
Old 02-14-2010, 05:04 PM   #22
Yellojacket
Yellojacket's Avatar
Drives: 2SS/RS Inferno Orange
Do we know if it has a diode built in to prevent backfeed to the PCM and we only need ONE harness correct to plug in on the passenger's side light for both to work?????
Yellojacket is offline   Reply With Quote
Old 02-14-2010, 06:01 PM   #23
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Yes, the diode question was already answered, it has it built in.
BigBOSS is offline   Reply With Quote
Old 02-14-2010, 06:49 PM   #24
seddon
seddon's Avatar
Drives: RED JEWEL 2SS
Just ordered the harness and the LED's
Elite Design Concepts NY5THGENPedderized SS
seddon is offline   Reply With Quote
Old 02-14-2010, 07:26 PM   #25
Flynnaz
"Roll Out"
Flynnaz's Avatar
Drives: 2010 2SS/RS
One harness will work for both sides, it plugs into the passenger side
Ordered on 3/31/09
_________________
4B00 Bayed 7/17/09
To fog light, or not to fog light. Xanthos Cosmetics and Lighting Modification Discussions 6 02-07-2013 04:35 PM
DRL (Now fog lights too) always on thebrainhart Camaro DIY & HOW-TO instructions & discussions 149 01-17-2013 02:18 PM
How to convert DRL to hid fog lights on your RS Camaro FI4T0MCAT Cosmetics and Lighting Modification Discussions 29 08-30-2010 12:11 AM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 01:07 AM
