Old 02-12-2010, 10:07 PM   #1
2010SSRSM6
2010SSRSM6's Avatar
Oil change scare
So, I took my baby in to my dealers for an oil change, get the loose screws taken care of that are rattling around my deck lid and a general check up at the 12K mile mark. I get a call from the dealership expecting to hear "come pick her up, she's all done." instead I get a call saying "Houston we have a problem."
I ask what it is thinking a stubborn nut is lodged in the structure of the deck lid giving them fits, only to hear that my baby has sprung a leak. Not just any leak, but an oil leak that my service advisor calls a 9 out of 10, with 10 being the worst.
"Oil leak? What do you mean oil leak. I don't have so much as a drip spot on my garage floor. Are you sure you’re looking at the right car? I'm on my way!"
I get to the dealership and I'm taken straight to the repair bay's where my baby is perched up on the lift. I walk under her and that oil has spewed out of her onto the oil pan, tranny, and a couple of other places.
This is completely weird. Oil pressure and level are fine. It is a VERY SLOW leak of some sort that hasn't dropped the level in the pan to even be noticeable on the dip stick. I had them clean up the oil with some degreaser just to make sure it's not residual from the last oil change. (You never know if someone was a bit careless and some spilled out while they were filling her back up.) I'll be keeping a close eye on my garage floor over the next couple of days and she will be back at the shop on Monday for a follow up.
They tranny and oil pan are scheduled to get dropped and everything will be gone over looking for what could have caused the leak. The oil pan gasket is the culprit as of right now.
I hope I'm the only one with this issue. Like I said, I've got over 12K miles on her so maybe it’s just loosening up a bit and needs a good once over. My baby is a 2SS with a manual tranny. (just missed the great tranny scare of '09) VIN is just over 21,000.
I'll update you all on Monday evening when I get to bring her home. Here are a couple of iPhone pic's so the Suburban’s can stay in the garage.
Old 02-12-2010, 10:24 PM   #2
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
There is a bulletin for 4th gen LS motors for oil leaks.
#05-06-01-034J : Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure)
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 02-12-2010, 10:48 PM   #3
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
When I was under mine last week installing the Pfadt engine mounts, I noticed that mine was wet with oil in the same spots. When installing the Vortech 3 months ago it was the same way, we tightened the oil cooler bolts and the leak stopped, they were very loose from the factory. That stopped the leak(more of a seep). But now it has started up again, seeping around the oil cooler mounting. I'll be talking mine in next week also.
Have the dealer put dye in the oil and clean it very good. Then when it seeps they can pin point the leak. Personally I think it's the same as mine and coming from the cooler.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 02-12-2010, 11:23 PM   #4
2010SSRSM6
2010SSRSM6's Avatar
I'll ask them to check that too. Thanks for the info!
Old 02-17-2010, 12:05 AM   #5
2010SSRSM6
2010SSRSM6's Avatar
Oil cooler was ok, it was the gasket. It appears that it was installed with a kink in it and failed. She should be back together first thing in the morning. They had to pull the entire front section off the car to get the oil pan out. I was too traumatized to take pic's of the deconstruction.
Old 02-17-2010, 12:09 AM   #6
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
At least they are putting her back together for you and she will be 100% again. Best wishes.
Scrappy Doo is offline   Reply With Quote
Old 02-17-2010, 12:36 AM   #7
Madcat0911
Madcat0911's Avatar
Drives: 2010 Camaro 1SS/RS
Camaro 1SS/RS, Manual Transmission, BA package, Transformers package
Madcat0911 is offline   Reply With Quote
Old 02-22-2010, 08:05 PM   #8
2010SSRSM6
2010SSRSM6's Avatar
I mis-spoke earlier, Both the oil cooler AND oil pan gaskets were bad. Just went through my paperwork again.
Old 02-22-2010, 11:08 PM   #9
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I had bad oil pan gaskets also.
FLYNNZL1 is offline   Reply With Quote
Old 08-24-2010, 11:37 PM   #10
slick rick
SoCal Mayhem
slick rick's Avatar
Hey Rick, do you have the part numbers for the gaskets?
Thanks
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Oil Capacity LS3 Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 77 04-21-2014 11:19 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
3,000 Miles - No "Metal Shavings" - Anyone Else? FNKNSTN 5th Gen Camaro SS LS LT General Discussions 48 10-06-2009 12:46 AM
