| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Nov 2009
Question Involving 4.10 gears & Bushings
Hey all,
Sorry if this question is obvious but I'm still learning here. I did a bunch of research on the Richmond gears using this forum (thanks for all the posts guys, extremely helpful) and ordered a set from ZZ Motorsports. Excited, can't wait to get them. I'm not the most experienced mechanic, so I plan on having them installed. Which leads to my question: What's this deal with the Pedders/PFADT busings? Is changing the bushings something that is necessary or preferred when changing to new gears? The only reason I ask is because a few posts here people seem to have gotten them done at the same time. It may be a coincidence, but I would be pretty stupid if I didn't use the great resource that this forum is to just ask the question and see what the reason is. Just trying to figure out whether I need/should get those bushings before I do install. Thanks in advance for all the help. |
#2 | ||
Drives: 89 IROC 350 Join Date: Mar 2009
I have them installed
I have the gears installed in my SS. Picked it up last night. ![]() ![]() First you need to read my review... http://www.camaro5.com/forums/showthread.php?t=65529 Second, you are going to want to have them installed FOR SURE. This is NOT a job for the novice. Quote:
They will need to remove your pumpkin to do the gear job so the bushings are right there in your face. You might as well do it. Its one of those things, they are cheap, the install is cheap if the rear end is out... just do it. It will protect other parts from snapping due to wheel hop. You will LOVE the 4.10s. Not sure ehat else you have done to your car but also pair the 4.10s with a good short throw shifter and a tune and it is like driving a totally different car!! |
| Thread Tools | |
| Lowering springs and rear gears V6 information | macwest | 5th Gen Camaro SS LS LT General Discussions | 12 | 04-30-2010 10:58 PM |
| Richmond Gears V8 and V6 - Group Buy | ZZcamaro | Transmission / Driveline | 175 | 04-30-2010 12:29 AM |
| Richmond 3.73 & 4.10 Gears On Special! | Jason 98 TA | Transmission / Driveline | 14 | 02-24-2010 11:03 AM |
| NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 10:36 AM |
| any 4.10 gears out for the V6? | camaro guy | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 06-07-2009 12:06 AM |
