Solo Performance
Old 02-13-2010, 12:41 PM   #1
wbdinger
wbdinger's Avatar
Drives: NSMNJW=2010 CGM 2SS/RS LS3
DIY OIL SEPERATOR
This is a build your own
Total cost $15 for fittings and clamp
Pic#1- an old a/c dryer
#2-cut dryer in half to see whats inside
#3-found a cone,desacant bag,micron filter, this is in all a/c dryers
#4-both dryers, rh one is used for the bottom and left for the upper section. discarded both ends with a/c sevice valves on them
#5-cross drilled tube for upper half of seperator,both of those micron screens cover alll the holes when installed
#6,7-pics of lower part with tube removed to install drain valve
#8-first test fit of two halfs with a aluminum plug installed at the end of tube
#9-close up shot of micron screens covering holes.ps the lower half below the cone will also have some #0 steel wool just to help oil seperation.
More pics to follow once the aluminum fittings for the hoses and other stuff(below) come in.
The two halfs are held together with a stainless "mj" clamp used in plumbing.
A bracket must also be welded onto the lower half.
DYI Oil Catch Can, DYI dash ABL, DyI fender "V"emblems, ACC Plasma DRL, DYI Painted red SS on steering wheel, DYI CGM painted bowties on wheels, DYI Clearcoated Brake Calipers, Eibach pro 1" lowering springs, GM Heratige grill, GM skipshift eliminator, GMPP 92206992 Exhaust, 2-10" Kenwood subs w/350watt pioneer amp, RiderGraphics hood spears/gill outlines, 9x20 wheels-custom silver,weather tech mats, ARH 17/8 headers and cats. Tuned by Davenport Motorsports.
wbdinger is offline   Reply With Quote
Old 02-15-2010, 05:31 PM   #2
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
Can you explane what this is for and how or why you intend to use it?
itsadryheat79 is offline   Reply With Quote
Old 02-16-2010, 05:54 PM   #3
wbdinger
wbdinger's Avatar
This is for the Engines PCV system to prevent oil in the crankcase gases from entering the intake manifold. I had a couple of A/C dryers off old cars and figured I could make a PCV Oil Seperator better and cheaper than what I've seen online. I should of waited till I was done to post pics but.... also it can be painted or polished being aluminum. more pics when done.
Oh and I'm still waiting on the car as it should be here mid April and wanted to start making/buying parts.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
