Old 02-13-2010, 08:03 PM   #1
francone13
francone13's Avatar
Drives: 2010 Camaro 2LT/RS
Side Gill Install Help
I was wondering if anyone can help me with this. Now i have never dealt with vinyl. I am ordering these side gills http://www.ridergraphix.com/2010_Cam...lackoutIIa.jpg and i would much appreciate if someone game me a step by step on how to install properly
francone13 is offline   Reply With Quote
Old 02-13-2010, 08:46 PM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Clean the surface thoroughly with a non wax cleaner. Dish soap and water comes to mind.
1. Get some painters' tape (blue stuff that comes off really easy)
2. align the vinyl in the gill slit and tape the vinyl in place about halfway down
3. pull the top part away from the car and separate the backing from the vinyl and cut it off
4. while holding the top end of the now backless vinyl and keeping it inline with the gill slit, press into place from the middle where you have the tape
Worked like a charm for me!!
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 02-13-2010, 09:06 PM   #3
francone13
francone13's Avatar
i heard something about using soapy water on the back of the vinyl what is that all about?
Old 02-13-2010, 09:18 PM   #4
dragom
2G1FB1EV3A9121989
dragom's Avatar
Drives: Rally Yellow RS Coupe
makes it easier to move the vinyl around till you get it where you want it
dragom is offline   Reply With Quote
Old 02-13-2010, 09:19 PM   #5
hypurone
hypurone's Avatar
It is called a "wet" install. It allows you to move the piece around to line it up. This requires that you squeegee the mix out from under the piece and if done incorrectly can cause scratches and tearing etc.
This is usually reserved for large items like my front valance blackout shown here that would be hard to get aligned the first shot:
Old 02-13-2010, 09:20 PM   #6
TripleB
SoCal Mayhem
TripleB's Avatar
Drives: 2010 2SS/RS ABM Camaro A6
That will make it so you can move it around...you'll need to squeegee it out once it's set in place. I know a good video for installing them..I'll link you in a bit when my wife is off the computer.
Old 02-13-2010, 09:23 PM   #7
francone13
francone13's Avatar
Thanks a lot guys
Old 02-13-2010, 09:35 PM   #8
TripleB
SoCal Mayhem
TripleB's Avatar
Old 02-15-2010, 09:00 PM   #9
francone13
francone13's Avatar
Thanks great video....were can i buy that squeegee and rapidtac?
Old 02-15-2010, 09:13 PM   #10
Wileytrigger21
Wileytrigger21's Avatar
Drives: 2010 CGM 2LT / RS, Blk 1SS/RS
here:
http://www.autotrimdesign.net/items_6906.html
Wileytrigger21 is offline   Reply With Quote
Old 02-15-2010, 09:58 PM   #11
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
I installed the the vinyl fade to black vent gills. I like them, here my vents.
Bone
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 02-20-2010, 08:07 PM   #12
jrcbandit
jrcbandit's Avatar
Drives: 2013 Camaro 2SS/RS
I think I will try a dry install since it doesn't look too difficult from the youtube video.
However, I have some questions about the wet version. I tried a "wet" install on my previous car for some headlight overlays, and recently I tried the wet install for the rear and front chevy bowties. In both cases, the results weren't very pretty - there are lots of micro bubbles that almost look like trapped dirt particles. I did clean the area beforehand with alcohol. I'm afraid to try the wet method with my side gill overlays because I don't want the same tiny bubble effect. A needle does help reduce the bubbles some, but there are too many really small bubbles to eliminate them via needle; for the headlight overlays the bubbles never went away even 2 months later before I eventually removed them for looking like crap. Any advice on what I did wrong or are all wet installs prone to this? Does the spray one uses really matter? I was using water with a little bit of baby shampoo for the install.
jrcbandit is offline   Reply With Quote
Old 02-20-2010, 08:40 PM   #13
dirtydogg
Drives: .
i don't think the type of soap, but the anount of soap to water ratio does. usually only a couple of drops to an average size spray bottle. i always use dawn soap.
dirtydogg is offline   Reply With Quote
Old 02-24-2010, 01:01 AM   #14
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
Originally Posted by hypurone View Post
That's a great pic
Chevyg1rl is offline   Reply With Quote
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 66 01-18-2017 01:47 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Passenger Side Air Leak or Side Mirror? Icntdrv55 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 10-21-2009 10:22 PM
DIY: Here it is Dashboard ambient lighting ABL Tecca Camaro DIY & HOW-TO instructions & discussions 356 09-03-2009 11:46 AM
Side Gill Proposal kdoske Cosmetics and Lighting Modification Discussions 3 06-22-2009 01:00 AM
