JUICEDMOTORSPORTS
Old 02-15-2010, 09:18 PM   #1
Rick2010
Chevrolet's & NY Yankees!
Rick2010's Avatar
Drives: ALL CHEVROLET'S
SS LINES
ALSO.......
ARE YOU HAPPY YOU DID THE LINES?
Rick2010 is offline   Reply With Quote
Old 02-15-2010, 09:44 PM   #2
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
..... seems your question in post #1 changed? Anyway, yes very happy with SS brake lines - firmer feel, no fear of temperature problems, and look sporty too. As far as bleeding the clutch question...... I installed a separate clutch fluid reservior so fluid swaps could be done. Clutch fluid needs changing more often than the brakes.... unless doing alot of road courses. As far as bleeding the clutch, it gradually cycles back into the master cylinder. If not separating reserviors, make sure reservior is mostly your new fluid of choice (I too used the Motul RBF600), then pump clutch about 50 times. Suck fluid out, refill, and pump again until 3 complete fluid swaps. You'll use less fluid if clutch is separated....and avoid getting the clutch dust into the brake system, like the vette guys have already experienced and proven. Link below describes in detail:
http://www.rangeracceleration.com/Clutch_Care.html
Name:  clutch reservior.jpg
LPE Brotherhood
Old 02-15-2010, 10:01 PM   #3
Rick2010
Rick2010's Avatar
Attachment 94327
Yeah.....I'm confused. I meant it to be in the same post.....
so.....am I emptying the reservoir.....changing the lines........bleeding the brakes.......then do the the 3 refills on the slave cylinder?
Thank you for helping out......APPRECIATE IT!!
Full SS brake setup for sale. nak3dsnake Suspension / Chassis / Brakes 24 05-28-2010 05:50 PM
Will the SS tires and rims fit on a V-6 car? copterdoc Wheels and Tires Talk Sponsored by The Tire Rack 7 07-28-2009 10:48 PM
Question About SS w/out RS Package Pope Designs 5th Gen Camaro SS LS LT General Discussions 7 06-11-2009 08:18 AM
Question for SS owners jdanza 5th Gen Camaro SS LS LT General Discussions 34 05-28-2009 03:02 PM
Question about grey leather SS interior... MidlifeZ28 Cosmetics and Lighting Modification Discussions 21 04-12-2009 07:45 PM
