Old 02-16-2010, 04:13 AM   #1
sting808
Drives: 2010 SS RS
Diagnostics/tuning for dummies?
What type of tuner packages offer what level of information and customization? (handheld vs EFI/HP laptop based for SS RS 6M)
I don't mind spending money, but don't want to accidently screw stuff up with a poorly designed software/interface, either. I hope these systems have failsafes for applying changes or writing to non-volatile ram/flash memory. In my profession, I've used good and bad interfaces in that include GUI or CLI so I don't mind learning anything.
I got my car back from the dealer for potential HID ballast problems and the service sheet said:
"... perform diagnostic system check. found numerous BCM DTC stored due to customer replacing various lights with LED bulbs, not relevant to this condition. check left headlight circuits, ok..."
My "old-school" troubleshooting with a trip to the parts department came up with a bad ballast possibility, too. I wish I could buy the service manual with schematics. (maybe available late 2010)
The new OBDs actually sense open circuits in various lighting systems? Holy crap. When I pulled my battery ground for my PDIM problem, mechanic saw tons of log messages for sudden shutdown of systems. It took him awhile to sort through log messages to see if anything was relevant. I guess I made it harder for him. In the end, bad PDIM and HID ballast, on back-order.
To be honest, I haven't kept up with all the handhelds, EFI live and HP tuner updates for the camaro.
Any insights or suggestions from professionals that used different products?
(I hate to call the manufacturers and get the HEAVY PR/MARKETING speech)
Thanks in advance.
sting808 is offline   Reply With Quote
Old 02-16-2010, 07:33 AM   #2
69lt1bird
69lt1bird's Avatar
Drives: 1969 Pontiac Firebid
The tuning software, EFI Live and HP Tuners is just that, Tuning. They do not do Body Control Module, ABS, etc. OBDII is powertrain based diagnostics, not body/chassis.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler
1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
69lt1bird is offline   Reply With Quote
Old 02-17-2010, 04:07 AM   #3
sting808
Drives: 2010 SS RS
Thanks. I did quick checks with handheld obdII scanners and they don't say if it supports 2010 GM OBDII DTC, too. I guess a mid-priced tool that does everything is unrealistic. The pro tools are a little overboard and don't even get into the tuner realm, too. Need to do more reading.
Old 03-02-2010, 10:13 PM   #4
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Suggest you look at DiabloSport Predator.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
