JUICEDMOTORSPORTS
Old 09-07-2008, 09:59 PM   #1
redriverchevy
Drives: 2007 Chevy Silverado
rear end clunk PLEASE HELP!
Ok i just purchased a 2002 Camaro ss. I have had the car now for a week and a half. Today I drove the car to church and to lunch. As i was going to see a uncle of mine this is when a big problem occurred. As I turned into his subdivision going about 10 mph i noticed a loud clunk sound. My wife stated that I night have ran over something but I did not. As I slowed down it occurred again. So I stopped the car to take a look. Nothing seemed abnormal so I got back in and drove real slow to his house. Every time I would apply the brake, and the car would have to go front then back it would do it again. When I got to his house i pushed down on the back of the car multiple times and the sound reappeared again. My uncle said it might be the u-joint. It defiantly sounded like its coming from the drive shaft. I need HELP! If this has happened to anyone please respond with any solutions you might have.
redriverchevy is offline   Reply With Quote
Old 09-07-2008, 10:11 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
check your u-joints.
what do you mean the car would have to go front then back? forward then reverse?
also (not saying this is what happened) if it isnt the driveshaft, be prepared as you might have busted the spider gears in the diff.
I piss excellence
and fart awesomeness
Old 09-07-2008, 10:13 PM   #3
redriverchevy
it is for sure hitting something on the outside. It is to loud for it to be an internal problem.
Old 09-07-2008, 10:47 PM   #4
Zieke
Camaro Deprived
Zieke's Avatar
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt
Send a message via MSN to Zieke
on my 78 i heard a loud clunking that turned out to be my exhaust rubbing on the body. only happens on harder right turns at speed. check to see if there are any clearance problems anywhere
a few zip ties fixed the problem for now. when i have the time and money after i get done with boot camp and 'A' school im going to fix as much as i can on her.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it.
Joined Active Navy: 10-28-08
Zieke is offline   Reply With Quote
Old 09-08-2008, 07:37 AM   #5
CamaroSpike23
Truth Enforcer
well, what are you doing on here? go out and find out what it is.
sounds like a driveshaft or u-joint problem. go find out.
I piss excellence
Old 09-08-2008, 08:57 AM   #6
redriverchevy
Hey bud I was just trying to find out what it could be. I had it towed to my dealership yesterday. I am going to have it looked at today. Thanks for the input. I think it might be something along those lines.
Old 09-08-2008, 09:00 AM   #7
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
I see two possibilities, both I've experienced:
1) Most likely a tranny mount. The best way to check this is pop the hood and put it in drive and reverse. If you see the back of the engine shifting up and down it's the tranny mount(s) and you're hearing the trankky shift into the floorplan from the torque. My brother took the liberty of getting airtime in my '91 vert and breaking my mounts, so I know exactly how loud that knock can be.
2) Bad rear end. When the pumpkin died in my IROC, it made an awful sound, but it did so mainly when turning (the differential had locked up on it's way out) and you didn't mention that. However it was a loud banging and it something I'd check.
U-joint is a possibility but not likely. Rarely do they make banging noises, usually they will "click" but not for long...they generally fail without much notice.
MerF is offline   Reply With Quote
Old 09-08-2008, 09:15 AM   #8
CamaroSpike23
Truth Enforcer
i was thinkin trans mount too, but he said it happend when going slow on a corner....
tho if it is a trans mount, get a polyurethane one and never worry about it again.
I piss excellence
Old 09-08-2008, 10:27 AM   #9
redriverchevy
The thing is is that it is drive-able. Keep in mind that this is a six speed car. What I ment by the car moving back and forth is the surge when you slow to a complete stop. That is when it is most noticable. Or when the car kind of jerks when you are in first gear and it gives you that slight surge forward then back, the noise again appears. I hope that this gives you a better idea of what I am talking about.
Thanks,
Nick
Old 09-08-2008, 10:27 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Check the torque arm busing too. If it's the original one, depending on the previous owner and conditions the car was driven through, that rubber bushing maybe just bad. I've seen some to where there was no rubber in the bracket anymore and the torque arm was free to smack around under there.
Good luck and keep us posted
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 09-08-2008, 11:08 AM   #11
CamaroSpike23
Truth Enforcer
yup
ive seen times where the clamshell outer portion came off. but the bushing was still there... not doing a whole lot, but still there.
check the tq arm bushing, and the trans mount, with the trans mount, you might not be able to see it outright unless you push up on the tailshaft of the trans. and check the d/s and u-joints as well for safe measure.
I piss excellence
Old 09-08-2008, 07:23 PM   #12
MerF
Go Rays!
MerF's Avatar
I'm anxious to see who is right. Hehe.
Old 09-08-2008, 09:18 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
X2 LOL! This is kinda' fun
Old 09-09-2008, 12:02 PM   #14
CamaroSpike23
Truth Enforcer
ive been pming a mod or two about putting up a tech/how-to section on here for troubleshooting guides, manuals, etc. its up in the air right now, but ive been compiling a donkey buttload of information if/when it does get put up. so if you got some extra idea, pm them to me and we'll add them up after proper review.
I piss excellence
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
Corvette C6 GTR TFord General Automotive + Other Cars Discussion 3 08-06-2008 10:26 PM
1985 Z-28 (Not IROC) Rear End aga6943 3rd Generation Camaros 3 04-22-2008 05:16 PM
Rear end ratios chevys Wheels and Tires Talk Sponsored by The Tire Rack 15 03-22-2008 11:47 PM
Preproduction Rear Photo Indicates Complete Redesign? sbg 5th Gen Camaro SS LS LT General Discussions 42 01-17-2008 04:09 PM
