| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
Synthetic?
Just wondering if anyone knew if it was going to be coming w mobile 1 like the vette or someting else? Also is the ss going to rec. 91 on gas or are the sayin 87 will be alright thanks
#2 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
more than likely it will come with mobil 1 and be recommended for 91, but ill be changing the oil after teh first 1000 miles anyway to Royal Purple, and i dont put anything less than 93 in my cars.
![]() Drives: 2004 GTO Join Date: Jul 2007
If it doesn't I will switch it. I always did a dino change at 500 and then a synthetic change at 1000 anyways.
More human than human
I will only put in Amsoil and donaldson filters
So is it a good idea to change at 500 or 1000 miles or is that just personal preference.
#6 |
![]() Drives: 2010 2SS/RS & 04 silvy Join Date: Mar 2008
Ill be changin it at 500, 1500, and 3000. then after that every 3000. It's just personal preference for me. You can never change the oil too much. But unlike the others i will be staying with the mobil one synthetic. I run it in my 71 chevelle, my 04 silverado, and i ran it in my 02 camaro ss before it was stolen and ive never had any problems.
#7 |
![]() Drives: 2010 GTI Join Date: Jun 2008
The reason new cars needed changed early was the "break-in" period. engine assembly/machining tolerences have gotten a little better in the last 30-40 years. I will most likely change at 500 miles then go longer on the intervals. If I changed every 3-5,000 I would have an oil change due every month. I go about 10,000 on the VW with synthetic. I would go longer but it only has about 4.5 qts in it.
#8 |
Chevrolet For Life!!
Drives: 07 Chevrolet Silverado Classic Join Date: Jan 2008
I plan on running Royal Purple in it after the break in period and it will probably knock on anything less then 91
When You're Really Good In A Past Life, You Come Back As Yourself!
Future Plate: PNYHNTR Camaro of Choice: 2010 SS 6.2L 6M IOM Current Ride: 2007 Silverado Classic Ext. Cab 5.3L DBM |
#9 |
![]() ![]() ![]() Drives: Aggressive Join Date: Jul 2008
Nine quarts for the LS3, going to get expensive if you use the good stuff.
Black 2SS RS LS3 Inferno Int. Plastidipped 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: Diabloed by Jannetty Racing: PFADT Stage 2, Trailing arms, Tie Rods:
#10 | |||||
The Jalopy Jedi
yeah, but why cheap out on one of the most vital necessities in the motor?
#11 | |
SS Lightning
Drives: An SRT8 Join Date: Feb 2008
Heres how I like to do it, its different with Hemis
3000 miles on synthetic or every 3 months, which ever comes first I used Q horsepower and had great results I like it but now I'm running Royal Purple and mobile 1 filters and don't think I'll go back to Q
![]() Quote:
#12 |
![]() Drives: 1981 Z28 Camaro Join Date: Nov 2007
You are correct AMSOIL is #1 in synthetic oils many test have proven this , after all they were the first to produce synthetic oils years ago and have the most experience with it , using synthetic oil will improve your MPG plus give you a little more HP and of course increase the longevity of your powertrain it is a no brainer .
#13 | |
I heard lower then 91 puts a knock in corvettes
#14 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
Have a look at this site:
http://mototuneusa.com/break_in_secrets.htm There's a lot of good information and this chap emphasizes NOT using synthetic during break-in. Whether-or-not you agree with everything, I think it has a lot to think about. ALSO, check out "Patman" on LS1tech. Try searching "oil analysis." I can't find the post I was originally thinking of, but I thought he had made a spreadsheet, of sorts, that had a lot of comparisons between several brands with the results of lab testing on his engine oil. It was very interesting. Ooo... I found this too: http://www.bobistheoilguy.com/
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#15 |
Car Garage
Drives: 350z,A4,SRT8...see sig Join Date: Feb 2008
you clearly know nothing about dodges... if you do infact av an srt8... and its new... like you say... dodge will change the oil for you every 5000 km... for free with full syn recommended... i have a charger and a viper and soon a challenger srt8
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes Yes I Supercharge Everything On My Ipad Xbox McLovin1515 Ps3 McLovin1555 Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707 New Autos:2012CamaroSSRS,09ChallengerSRT8 Past Autos:....too many to list "i told you it was gettin' an LS3" Go down deep enough into anything and you will find mathematics. Dean Schlicter B.Sc. Hons. Mathematics |
#16 |
OK I'll bite....What do other engine builders have to say about break-in?
#17 | |
Petro-sexual
#18 |
Synthetic oil should be used in not just the engine but the tranny and rear end to get the MAXIMUM benefits ...
#19 |
Dang, thats a lot. IDK where the vette LS3 and Camaro LS3 differences page is but will they have the same oil pan for all that oil? If you think about it the Camaro could hold more oil since the engine will be higher off the ground, hence bigger oil pan.
#20 |
![]() ![]() ![]() ![]() Drives: Muscle Join Date: Apr 2008
what would you suggest using? i havent really found one that stands out above the rest? ive heard good things about Royal Purple and Q horsepower, but i havent had a chance to use them... any suggestions?
#21 | |
They have also ran amsoil in big rig trucks for 80,000 miles while only changing the filter.The motor had no sludge in it,There was no viscosity breakdown,and oil analysis shows that there is less wear metals in the oil (after 80,000 miles). To me its worth the money |
#22 | |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
I would not worry about synth during a break in. I have one of the first ones broken in with it (early 1st year LT1 in my vette, mobile 1) and it's doing fine. But do change it early to get out contamination.
#24 | |
REMEMBER AMSOIL WAS THE FIRST TO SELL SYNTHETIC OILS IN NORTH AMERICA SO THEY KNOW HOW TO MAKE IT THATS FOR SHURE I personally wouldn't use ANY other brand... |
#25 |
Petro-sexual
Did Germany first develope sythetic lubricants in WWII? I thought I read/saw that somewhere.
| Thread Tools | |
| first 24 hrs | boxmonkeyracing | 5th Gen Camaro SS LS LT General Discussions | 61 | 04-17-2009 04:25 PM |
| Octane Booster and synthetic oil | big_bank5000 | 5th Gen Camaro SS LS LT General Discussions | 25 | 05-14-2008 03:32 PM |
| New car maintenance | AerospaceGuy | General Automotive + Other Cars Discussion | 4 | 04-08-2008 06:44 AM |
| To break in or not to break in? | Emu the Foo | 5th Gen Camaro SS LS LT General Discussions | 68 | 03-15-2008 07:12 PM |
