sjm autoprod
Old 09-09-2008, 09:47 PM   #1
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Paddle Shifters & the L99- Help
Ok so i was wondering if some one could elaberate and or answer a few what maybe stupid questions I had in reguards to the paddle shifting for the 2010 L99.
1) I have heard there will be a "mode" you have to be in such as "m" on the shifter. Can you go in and out of this while driving or only while stopped?
EXAMPLE: for instance... if you where driving... say 30mph and you wanted to activate this "mode" how would you go about shifting up to third while in motion? My thought is if you must shift up to third through the paddles... wouldnt the car enage into first and second (while your driving) as you make your shifts?
2) Will there be a paddle to downshift or will the car auto down shift for you (as I heard some cars do)?
Also i have a general "?" about the L99 system and its AFM system
I heard that this entitles the car using less cylinders when not needed? and if true wouldnt this promote uneven engine wear?
5th_GEN_SS is offline   Reply With Quote
Old 09-09-2008, 09:52 PM   #2
skipj3
Go Gators Baby!!!
skipj3's Avatar
Drives: '11 2SS M6
http://www.camaro5.com/forums/showth...ighlight=micah
this should take care of the paddle questions
Oscar Wilde - “When I was young, I thought that money was the most important thing in life; now that I am old, I know it is."
The Department of Redundancy Department
skipj3 is offline   Reply With Quote
Old 09-09-2008, 09:55 PM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
thanks for the link Skipj3.
Old 09-09-2008, 09:57 PM   #4
skipj3
Go Gators Baby!!!
skipj3's Avatar
Drives: '11 2SS M6
glad to help
Old 09-09-2008, 09:58 PM   #5
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
thanks 4 the link! still curious if you can just shift into manual mode while driving tho.. sounds like it? maybe?
Old 09-09-2008, 10:02 PM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Yes. And to get out of manual mode, you shift back to 'D'.
It sort of works along the same lines as shifting into 3,2, or 1. ('I', and 'L' on some) on a conventional Auto. Except there's no gear changes when you click the shifter down on this one. It just turns on alternate programming: The 'sport' mode.
Old 09-09-2008, 10:04 PM   #7
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
o ok! thanks! i was gona get the 6 speed manual but i thnk i gonna go 4 the auto the paddle shifters sound nice.. fast perfect shifts.. cant beat the comp lol
Old 09-09-2008, 11:33 PM   #8
tsg1391
Drives: 79 formula 'bird, 5th gen soon
the afm shuts down 4 cylinders, then after 9 min(i think) it fires them back up then alternates which cylinders are shut down
tsg1391 is offline   Reply With Quote
Old 09-10-2008, 12:49 PM   #9
AirGoya
AirGoya's Avatar
Drives: 2012 Camaro SS
Really? Wow thats really interesting. My dads impala ss has this feature and i always wondered if its the same cylinders that deactivate. I thought to myself wouldnt those cylinders wear more than the others. This makes much more sense.
-Tim
AirGoya is offline   Reply With Quote
Old 09-23-2008, 03:42 PM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
wrong, it is always the same cylinders that are shut down when afm/dod kicks in:
straight from the gm service manual:
To provide maximum fuel economy under light load driving conditions, the engine control module (ECM) will command the cylinder deactivation system ON to deactivate engine cylinders 1, 7, 6, and 4, switching to a V4 mode. The engine will operate on 8 cylinders or V8 mode, during engine starting, engine idling, and medium to heavy throttle applications
Old 09-23-2008, 04:55 PM   #11
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Is this the case with all AFM engines? Does GM do anything to add protection to those cylinders?
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 09-23-2008, 08:13 PM   #12
Mr. Wyndham
What protection would be needed?
Old 09-23-2008, 08:17 PM   #13
The_Blur
Jayhawk USN
The_Blur's Avatar
I figured there would be some sort of warranty or physical protection of the cylinders. I guess they aren't really likely to shoot out of the hood because they'll be hitting at substantially less RPM than usual. I was just wondering if GM designed AFM in such a way that it would need no maintenance of shop support.
TO: Camaro5//
warn 145:155 ban
Old 09-23-2008, 08:52 PM   #14
Mr. Wyndham
They did...that's how it works...I guess I'm not following you...
When AFM is on -- the valvetrain, spark, and fuel for the dedicated cylinders are shut down. But the pistons themselves still move up and down like normal. There's no increased load, or extra wear that would require an extra warranty, or some sort of protection.
Video: Kelley Blue Book Drives 2010 Camaro V6 Micah Camaro Photos | Spyshots | Video | Media Gallery 78 09-10-2008 12:33 AM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 03:07 PM
Paddle Shifters or Clutch?? Congoman775 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 06-25-2008 11:38 AM
Dragoneye’s Birth Day KILLER74Z28 Off-topic Discussions 34 04-15-2008 12:07 AM
Couple Of Random Questions * Paddle shifters Navy Blue General Automotive + Other Cars Discussion 32 03-07-2008 01:21 PM
