Old 02-21-2010, 08:20 AM   #1
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
brakes losing power assist?
I went autocrossing again yesterday. It was actually a school for it. One part was an acceleration and braking test. It was back to back hard starts and stops, some starts spinning some not. In the braking zone some times the brakes felt like they were losing their power assist. The pedal was very hard and the brakes took 10 to 20 feet longer to stop and I could still feel the ABS pulsing. Other times the brakes were fine and because I was anticipating the longer stop I then stopped 15 ft short of the spot I was shooting for. I was wondering if the common brake and clutch fluid reservoir may have had something to do with it. I know what the ABS pulsing feels like, it was not that. The pedal was rrreeeaaalllyyy hard and the brakes were horrible. Maybe over heated the fluid or something. Ten minutes later they were fine and stopping like a champ. Anyone else felt this?
BTW I ended up with the FTD fastest time of the day beating a bunch of sweet cars, lotus, audi, bmw, miatas, minis, g8, genesis, mustang, and a bunch of others. I love my car
1977and2010 is offline   Reply With Quote
Old 02-21-2010, 09:15 AM   #2
Ghost of Vincent Price
Banned
Drives: 2010 Camaro
Brake fade? I wouldnt think it would have to do with the clutch fluid. The problem there lies in the fluid boiling causing the slave cylinder to starve for fluid. Do you have headers and prehaps removed some heat shielding? Then I think that may be possible. But I would say get some better pads and try again.
Ghost of Vincent Price is offline   Reply With Quote
Old 02-21-2010, 05:10 PM   #3
1977and2010
does brake fade make the pedal effort really hard, this is the first time I've experienced this?
Old 02-22-2010, 12:37 AM   #4
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Yes brake fade makes the pedal effort seem harder.
You have found the limitations of the stock braking system.
I think you know what you need to do if you want to keep driving your car like that.
First off, don't attempt that training exercise again, the brakes need airflow across them, other wise they will be trashed soon and your car will sound like the mail carrier's (squeak sqeak)
Secondly, change the brake fluid to that expensive stuff all the track guys use. It's the Castrol stuff I believe, has a higher boiling point.
two_wheel_mayhem is offline   Reply With Quote
Old 02-27-2010, 08:04 PM   #5
tyler20c
tyler20c's Avatar
Drives: Black 2010 Camaro SS/RS
where near tampa did you do the autocross school?
tyler20c is offline   Reply With Quote
Old 02-28-2010, 10:34 AM   #6
1977and2010
It is at the St Pete college, brooksville airport, and somewhere in lakeland. It's through wedrivefast.com
Old 02-28-2010, 05:31 PM   #7
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
As was said earlier, you have found the limits of the factory Camaro brake system. Just because it says Brembo doesn't mean it can autocross or roadrace. Many others have learned its limitations the hard way as you have. Aftermarket packages are out there to be had. You will pay well for a high quality system and do upgrade to stainless lines and brake fluid.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
