BORLA
Old 02-22-2010, 05:48 PM   #1
venice17517
venice17517's Avatar
Drives: 2010 Camaro
Subject:Rattle Noise Under Vehicle - May Be Engine RPM Related
#PI0027: Rattle Noise Under Vehicle - May Be Engine RPM Related - (Feb 3, 2010)
Models:2010 Chevrolet Camaro SS
Equipped with 6.2L V8 Engine
Please Refer to GMVIS
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#ss1-2393338">Condition/Concern
Some customers may comment on a rattle noise from under the vehicle. This noise is mostly reported when the vehicle is cold and may go away completely when the engine is warm.
It is possible that the internal baffles may be loose in the mufflers on vehicles produced before September 15, 2009 or the resonators on vehicles built before December 1, 2009.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#ss2-2393338">Recommendations/Instructions
To diagnose loose baffles in either component, use the following method.
  1. <LI type=1>Lift and suitably support the vehicle. <LI type=1>Locate the muffler at the rear of the vehicle. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#oth3-2393338">Muffler Rattle Diagnosis Tap Points
    <LI type=1>Using a rubber mallet, strike the exhaust pipes in the bend just ahead of the mufflers as shown. If loose baffles are present, you should hear them rattle when tapping with the rubber mallet. Replace the exhaust system to correct this condition. Important: You must only tap on the exhaust pipe at the positions shown. Tapping further away from the mufflers may cause other reverberations that do not indicate a need to replace components.
    <LI type=1>Locate the resonator at the mid-point of the vehicle. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#oth4-2393338">Resonator Rattle Diagnosis Rear Tap Points
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2393338&from=sm#oth5-2393338">Resonator Rattle Diagnosis Front Tap Points
    <LI type=1>Using a rubber mallet, strike the exhaust pipes both in front of the resonator and behind the resonator as shown. Important: You must only tap on the exhaust pipe at the positions shown. Tapping further away from the resonator may cause other reverberations that do not indicate a need to replace components.
  2. If loose baffles are present, you should hear them rattle when tapping with the rubber mallet. Replace the exhaust system to correct this condition.
venice17517 is offline   Reply With Quote
Old 02-23-2010, 07:52 AM   #2
don0fthedead
don0fthedead's Avatar
Drives: Black 2SS/RS
Thanks for the post!
Looks like I'll be getting this...
"Replace the exhaust system to correct this condition."
don0fthedead is offline   Reply With Quote
Old 02-23-2010, 07:56 AM   #3
Does GM or the dealership have to fix this, is this like a recall?
Old 02-23-2010, 09:02 AM   #4
don0fthedead
I brought my car in the dealership the other day for a noise and I was told that the muffler I have is no longer used. They had to order the parts for it, but they said once it comes in, they'll replace it for me. I was told it shouldn't cost me anything, but once I go in to get it replaced, I'll see for sure.
Old 02-27-2010, 08:22 AM   #5
gtc352
Gtc352
gtc352's Avatar
Drives: 2010 2SS Camaro 2010 GMC Sierra
Finally!
I've been looking for that rattle for months. I've torn the whole trunk down, checked every heat shield and lost alot of sleep. I'm in the dealership now (3rd time) having them check it out. Great info, I showed the service guy what to look for. Hopefuly this is the problem and I can get some sleep at night!
gtc352 is offline   Reply With Quote
Old 02-27-2010, 11:45 AM   #6
gtc352
Gtc352
gtc352's Avatar
Yep. I was the muffler baffles. They are ordering a new exhaust for me. Should be in this week. All covered by the warranty. Thanks for the post VENICE17517!
Old 02-27-2010, 08:47 PM   #7
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
I have a similar rattle but more at low speeds (almost stopped) or when reversing and it sounds like it is right under the tranny??
Could this be a heatsheild possibly?
Thanx for any advice.
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 02-28-2010, 10:56 AM   #8
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Had the same noise on my 2LT. Then it just disappeared, right after 2 trips to the dealer. The mechanic could replicate the noise and moved some of the heat shields slightly. I assumed that did the trick....
Now it's back again after nothing for about 3 months. Hmmmm. Wonder if it applies to the V6 too. Noise is right under the trans, very faint and slows down/speeds up with the car's movement.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 02-28-2010, 12:21 PM   #9
Wvallediego
Wvallediego's Avatar
Drives: Inferno Orange 2010 RS SS
Is this the noise you hear when you are decelerating on gear? The noise that almost sounds like your car is running too rich?
Wvallediego is offline   Reply With Quote
Old 03-02-2010, 06:41 PM   #10
don0fthedead
So I had my car taken in for this, they replaced my exhaust. I previously had this sort of high-pitch clicking noise that would happen when I'd let off the accelerator and continue for a few seconds. It never happened when the car was at a stand still, and was hardly noticeable at first. If the radio was on or even if the AC was on, if you weren't specifically listening for it, you probably wouldn't hear it.
Once I heard it the first time though, it was really bugging me. Now, with the newer stock exhaust, the car sounds fine!
Old 03-02-2010, 06:53 PM   #11
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I developed one on my Saturn Sky, it would happen only at certian RPMS also and found out a piece of gravel had gotten caught between the heat shield and the body, and sometimes it would sound like the whole underneath of the car was going to fall out... Scared the crap out of me...
The Bird is the word!
Old 07-19-2010, 08:42 PM   #12
dpetramale
2SS Jewel Red / Old Timer
Drives: 2SS Jewl Red
Rattle noise under Vehicle
I seem to hear a similar Rattle/vibration when I down shift or the engine strains a little before I down shift to pickup speed. Temperature doesn't seem to be a factor. Sometimes starting off in first gear i hear the rattle/ vibration. I have a Jewl Red 2SS. Dose this seem to be the same asyou hear. I also don't like leaving my car at the dealer. I'm hoping when I go in I can get a mechanic to ride with me to hear. I don't like leaving my car at the dealer. Hopefully I can get a mechanic to ride with me to hear it. How do you guys feel about leaving your cars?
dpetramale is offline   Reply With Quote
Old 07-24-2010, 09:56 AM   #13
cajun2010
cajun2010's Avatar
Drives: 2010 1LT/RS
My rattling sounds like metal tapping, almost if something is loose, but its a pain in the ass, and kind of embarrasing!
dealership didnt find anything, but i added Flowmaster system and resonated x-pipe, so dont think they are changing my exhaust anytime soon.
2010 1LT/RS Eibachs, Doug Thorleys, Flowmasters, Stillen, hmm a few other things...
cajun2010 is offline   Reply With Quote
Old 07-24-2010, 10:34 AM   #14
jtzako
Drives: 2010 IBM Camaro SS
Take a look under the center of the car, there is a metal cross brace there. Try taking that off and see if the rattle goes away. (in my case my exhaust was hitting/rattleing on that) Dont leave it off of course, since it needs to be there, but it is a good way to test.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
YOUR WARRANTY INFORMATION Kwaz1335 5th Gen Camaro SS LS LT General Discussions 2 11-02-2009 06:23 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
