JUICEDMOTORSPORTS
Old 02-23-2010, 03:22 PM   #1
JCSSCamaro
Campbell Motorsports
JCSSCamaro's Avatar
Drives: 2017 SS Fifty
Power door Locks how to turn off
I hate driving away and the doors locking? I have tried several settings to stop this, but have yet to find a way?
I want total control of when the doors lock and when they UNLOCK
anyone?
Campbell Motorsports Vancouver USA
JCSSCamaro is offline   Reply With Quote
Old 02-23-2010, 03:24 PM   #2
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
You're out of luck here.
The doors are going to lock every time you put the car in drive or reverse. I don't think there's a setting to change this.
Old 02-23-2010, 03:51 PM   #3
Maro99
Maro99's Avatar
Drives: Heel toe express..
Im with you on that.. I dont like it either
Maro99 is offline   Reply With Quote
Old 02-23-2010, 04:05 PM   #4
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I guess it's a personal thing. I have no issue with that. What I dislike is shutting off the ignition and the doors unlock! Glad that was programmable!!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 02-23-2010, 05:21 PM   #5
venice17517
venice17517's Avatar
Drives: 2010 Camaro
This might help with your door locks
The audio system controls are used to access the personalization menus for customizing vehicle features.
CONFIG (Configuration): Press to access the Configuration Settings Menu.
MENU / SELECT Knob: Press the center of this knob to enter the menus and select menu items. Turn the knob to scroll through the menus.
BACK: Press to exit or move backwards in a menu.
Entering the Personalization Menus
  1. <LI type=1>Press the CONFIG button to access the Configuration Settings menu. <LI type=1>Turn the MENU / SELECT knob to highlight Vehicle Settings.
  2. Press the center of the MENU / SELECT knob to select the Vehicle Settings menu.
The following list of menu items will be available:
• Climate and Air Quality
• Comfort and Convenience
• Collision/Detection Systems
• Language
• Lighting
• Power Door Locks
• Remote Lock/Unlock/Start
• Return to Factory Settings
Turn the MENU / SELECT knob to highlight the menu. Press the knob to select it. Each of the menus is detailed in the following information.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss1-2171761">Climate and Air Quality
Select the Climate and Air Quality menu and the following will be displayed:
• Remote Start Heated Seats
When on, this feature will turn the heated seats on when using remote start.
Press the MENU / SELECT knob when Remote Start Heated Seats is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss2-2171761">Comfort and Convenience
Select the Comfort and Convenience menu and the following will be displayed:
• Chime Volume
• Personalization by Driver
Chime Volume
This allows the selection of the chime volume level.
Press the MENU / SELECT knob when Chime Volume is highlighted. Turn the knob to select Normal or High. Press the knob to confirm and go back to the last menu.
This allows the selection of if the personalization settings are specific to each driver or the same no matter which key was used to enter and start the vehicle.
Press the MENU / SELECT knob when Personalization by Driver is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss3-2171761">Collision/Detection Systems
Select the Collision/Detection Systems menu and the following will be displayed:
• Park Assist
Park Assist
This allows the Ultrasonic Parking Assist feature to be turned on or off.
Press the MENU / SELECT knob when Park Assist is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss4-2171761">Language
Select the Language menu and the following will be displayed:
• English
• French
• Spanish
Turn the MENU / SELECT knob to select the language. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss5-2171761">Lighting
Select the Lighting menu and the following will be displayed:
• Exit Lighting
• Vehicle Locator Lights
Exit Lighting
This allows the selection of how long the exterior lamps stay on when leaving the vehicle when it is dark outside.
Press the MENU / SELECT knob when Exit Lighting is highlighted. Turn the knob to select Off, 30 Seconds, 1 Minute, or 2 Minutes. Press the knob to confirm and go back to the last menu.
This allows the vehicle locator lights to be turned on or off.
Press the MENU / SELECT knob when Vehicle Locator Lights is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss6-2171761">Power Door Locks
Select Power Door Locks and the following will be displayed:
• Unlocked Door Anti Lock Out
• Auto Door Unlock
• Delayed Door Lock
When on, this feature will keep the driver's door from locking when the door is open. If off is selected, the Delayed Door Lock menu will be available.
Press the MENU / SELECT knob when Auto Door Unlock is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
Auto Door Unlock
This allows selection of which of the doors will automatically unlock when the vehicle is shifted into P (Park) (automatic transmission) or when the key is removed from the ignition (manual transmission).
Press the MENU / SELECT knob when Auto Door Unlock is highlighted. Turn the knob to select All Doors, Driver Door, or Off. Press the knob to confirm and go back to the last menu.
Delayed Door Lock
When on, this feature will delay the locking of the doors. If you want to override the delay you can press the power door lock on the driver's door.
Press the MENU / SELECT knob when Delayed Door Lock is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss7-2171761">Remote Lock/Unlock/Start
Select Remote Lock/Unlock/Start and the following will be displayed:
• Unlock Feedback (Lights)
• Locking Feedback
• Door Unlock Options
• Remote Vehicle Start
When on, the exterior lamps will flash when unlocking the vehicle with the RKE transmitter.
Press the MENU / SELECT knob when Unlock Feedback (Lights) is highlighted. Turn the knob to select Flash Lights or Off. Press the knob to confirm and go back to the last menu.
Locking Feedback
This allows selection of what type of feedback is given when unlocking the vehicle with the RKE transmitter.
Press the MENU / SELECT knob when Locking Feedback is highlighted. Turn the knob to select Lights and Horn, Lights Only, Horn Only, or Off. Press the knob to confirm and go back to the last menu.
Door Unlock Options
This allows selection of which doors will unlock when pressing the unlock button on the RKE transmitter.
Press the MENU / SELECT knob when Door Unlock Options is highlighted. Turn the knob to select All Doors or Driver Door Only. Press the knob to confirm and go back to the last menu.
This allows the Remote Vehicle Start to be turned on or off, if the vehicle has this feature.
Press the MENU / SELECT knob when Remote Vehicle Start is highlighted. Turn the knob to select On or Off. Press the knob to confirm and go back to the last menu.
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=183231&refDoc=2171182&from=s m#ss8-2171761">Return to Factory Settings
Select Return to Factory Settings to return all of the vehicle personalization to the default settings. Turn the knob to select Yes or No. Press the knob to confirm and go back to the last menu
venice17517 is offline   Reply With Quote
Old 02-23-2010, 05:43 PM   #6
Michael_Js
Michael_Js's Avatar
Yup, read through that 1st and there's no way to turn off the locking when driving off Safety first...I guess.
Old 02-23-2010, 07:42 PM   #7
glambert1
HOMER
glambert1's Avatar
Drives: 2010 camaro 2LT RS SIM
i like the feature car jacking u know
....do it yourself and be proud when you brag about your mods...
glambert1 is offline   Reply With Quote
Hypertech Max Energy Power Programmer ~ Tune For POWER! Circuit Motorsports V8 Bolt-Ons & Tunes 22 02-09-2010 02:59 PM
Kenne Bell Vs. Whipple Who Wins? thalilbear02 Forced Induction - V8 132 01-28-2010 08:23 PM
starter gets no power... please help zebra General Automotive + Other Cars Discussion 16 11-12-2009 11:37 PM
