HeadlightArmor
Old 02-24-2010, 03:08 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Changing rear end oil and trans oil?
Ok...I know I've seen this addressed before but doing a Search and I come up with a ton of threads on changing engine oil but not rear end oil.
I'm looking to see if anyone has a DYI on changing the rear end oil and/or the trans oil.
I don't know that I'll do the trans oil now but from what I remember someone was recommending changing the rear end oil pretty quick. I'm thinking that I'll use Royal Purple which I'm pretty sure I can get at the local O'Rielly shop. Does anyone know how much oil the rear end holds?
Build Journal
Old 02-24-2010, 04:12 PM   #2
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Manual trans V6--1.9 qts.
Manual trans V8--4.2 qts.
Differential V6 auto--.95 qts.
Differential V6 manual and V8 all-- .975 qts base lube + .079 qts friction modifier
Read you need some sort of pump for the tranny fluid or a funnel and long hose.
Am curious what the torque values are for the drain plugs.
Cheers
K
Moriartii is offline   Reply With Quote
Old 02-24-2010, 04:14 PM   #3
caverman
caverman's Avatar
Cheers
K
So I should only need to buy 1 qt of oil for the rear end?
Anyone know if the Royal Purple comes with the friction modifier included in it?
Build Journal
Old 02-24-2010, 04:54 PM   #4
Moriartii
Moriartii's Avatar
One quart appears to be what you need and yes it has the requisite modifiers in it.
Cheers
K
Old 02-24-2010, 09:36 PM   #5
mmbarberoilman
mmbarberoilman's Avatar
Drives: 2SS, 48 Plymouth, 77 Coup Deville
Forget RP even if its free. Go Amsoil. Research the difference
mmbarberoilman is offline   Reply With Quote
Old 02-27-2010, 09:38 AM   #6
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
Yeah, I would HIGHLY recommend changing them both around the 1500 mile mark.
I did that with mine, here's the write-up:
http://www.camaro5.com/forums/showthread.php?t=51147
Both are a simple drain and fill. I used OEM fluids on my first change. I will most likely use Amsoil the next time I change them out.
FirstLSK is offline   Reply With Quote
Old 02-28-2010, 09:57 PM   #7
RandyB
RandyB's Avatar
Drives: 2010 Camaro 2SS/RS M6 SIM
RP is fine for the rear end but there is a better option for the M6 transmission. Use Mobil1 Synthetic ATF http://www.mobiloil.com/USA-English/...hetic_ATF.aspx. I tried a couple different trans fluids, including RP, but the Mobil1 made the synchros much smoother.
RandyB is offline   Reply With Quote
Old 02-28-2010, 10:48 PM   #8
caverman
caverman's Avatar
So...you can use an Auto Trans oil in a manual trans?
Build Journal
Old 02-28-2010, 10:59 PM   #9
RandyB
RandyB's Avatar
Yes, it gets ATF from the factory. GM uses DEXIII ATF (w/additives). The Mobil1 Synthetic ATF I mentioned above is DEXIII. But, Do not use DEXVI in the M6.
Old 03-01-2010, 08:50 AM   #10
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I used the Mobil 1 Synthetic ATF that Randy is talking about in my 6 speed manual. This Dexron 3 based synthetic ATF did improve the synchronizer functioning. The tranny is now more smooth going into gear. The factory fluid made the tranny feel like the gears were not meshing well when shifting, especially when cold. Buy 4 quarts.
Get yourself a funnell with about 4 feet of tubing so you can fill the tranny easy from the top of the engine compartment. I bought some clear rubber tubing from the hardware store and it was less than $5.
-Mark.
Old 03-01-2010, 11:09 PM   #11
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Anyone else try RP and the Mobil 1 Synthetic ATF? Which one they like better? I just bought the mobil 1 stuff and before i use it i want to know if there are anymore reviews on it
gotpball44 is offline   Reply With Quote
Oil Capacity LS3 Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 77 04-21-2014 11:19 PM
Anyone had their differential fluid changed? Jeanius Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 01-14-2010 01:30 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
