Old 02-24-2010, 05:00 PM   #1
dect
Drives: None
completely new to sound.. questions
Alright, so the stock sound system for the camaro is not bad... But it could be better! So I am wanting to get a lot better sound. But truthfully, I have no idea how to do this. I know to buy subs and stuff but do I install it? does someone else? what else do I buy? Just general questions.
So, what should I buy to improve the sound? Under 1,000$? WHat kind of subs?
DELIVERED: JUNE 1ST, 2009
dect is offline   Reply With Quote
Old 02-24-2010, 05:11 PM   #2
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
If you are new and want it easy, inexpensive and nice, hit up steve at ********. I think all your needs will be met.
If not then start searching.
Cheers
K
Moriartii is offline   Reply With Quote
Old 02-24-2010, 05:14 PM   #3
dect
Drives: None
Heh. I kind of needed more than that:P like a general basis on what I need, and what brand.
Old 02-24-2010, 05:16 PM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Well, subs will give you more bass, but it sounds like you just want the audio to be a bit cleaner and crisper (is that a word?) so I would recommend upgrading the speakers and possibly replacing the stock Boston Acoustics amp with an aftermarket before you add a sub.
It really just depends on what you listen to and how you want the audio to sound.
Old 02-24-2010, 05:17 PM   #5
2010SSRS
2010SSRS's Avatar
Drives: 2000 Silverado
i know i'll get flamed - but the factory MTX subs w/ 200 watt amp is DESIGNED to BALANCE out the Boston Acoustic system. 200 watts doesn't sound like much, but at the impeadance level it runs it's comparible to a 400 watt amp. it's $780 shipped thru gmpartsdirect.com. little pricey i think, but i've read 6 folks reviews and they ALL raved about it.
your dealer can install it and not only will it not void ur warranty, it will be covered by ur 3/36 bumper to bumper warranty.
if you don't have an SS and the Boston Accoustic system, you need lots more than subs.
my opinion........
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI
2010SSRS is offline   Reply With Quote
Old 02-24-2010, 05:19 PM   #6
dect
Drives: None
I don't have a SS I have a 2LT... I think I have the same sound system as a SS?
Old 02-24-2010, 05:20 PM   #7
CamaroSkooter
Yes, the 2LT has the upgraded Boston Acoustics stereo.
Old 02-24-2010, 05:23 PM   #8
dect
Drives: None
Figured..
So what would be my first step in improving the sound?
Old 02-24-2010, 05:25 PM   #9
Moriartii
Moriartii's Avatar
Well what do you want? Improved sound or bass? What is your end goal?
Cheers
K
Old 02-24-2010, 05:36 PM   #10
dect
Drives: None
Cheers
K
Bass. More than anything. Nothing makes me smile more in my car than hearing the stock bass. I just can't imagine my reaction to an after market system.
Old 02-24-2010, 05:48 PM   #11
dect
Drives: None
Bump
Old 02-24-2010, 05:49 PM   #12
CamaroSkooter
If you like the audio quality and just want some more thump, then Steve@******** is the guy you want to talk to. They make a great drop-in sub box that fits most medium-level subwoofers and tucks into the corner of your trunk. They also provide some excellent step-by-step instructions so it's a pretty straightforward approach for someone new to the game.
Do some searching for the ******** boxes and you'll get a bunch of information
Old 02-24-2010, 06:54 PM   #13
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
About all you need to know is www.JLaudio.com They have done the most engineering on complete audio systems for the Camaro 5
Go Fast Kid is offline   Reply With Quote
Old 02-25-2010, 01:09 PM   #14
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Originally Posted by 2010SSRS View Post
i know i'll get flamed - 200 watts doesn't sound like much, but at the impeadance level it runs it's comparible to a 400 watt amp.
The only thing you'll get flamed for is that statment. 200 watts is 200 watts, regardless of what impedance it generates it. Meaning a 200 wrms @ 4ohm amp is the same as a 200wrms @ 2ohm, only difference is the 4 ohm amp will be easier on your car.
Impedance is only used to match subs to power supply to get the most out of the power suplly, safely. What does that mean? Take the 200 wrms @ 4ohm example, throw a 2 ohm load on it. In theory, if you have the current to keep it happy, it will develop 400 wrms. At what cost? Again, higher current draw, excessive heat in the power supply and possibly faliure.
Impedance does not alter how an amp sounds like it's making power, it will change how an amp makes it power.
What? Seriously? If that was the case, wouldn't the drop in factory system be JL and not MTX? They do indeed invest R & D for their stealthboxes and such, and their products are good. Yet, too some, like myself, they are overpriced, underperforming being sold on their name only to fanboys products. There are products out there that outperform them, for less money and are just as durable, but you won't have JL written anywhere on it. BTW, I haven't heard a Stealthbox I like yet, and you pay a pretty penny for them!
PacMan
mrray13 is offline   Reply With Quote
Wind Tunnel Sound Steve Dallas 5th Gen Camaro SS LS LT General Discussions 1 12-26-2009 09:51 AM
Need feedback before I do headers regarding sound levels w SOLO Mach X. 55Designs Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 12-20-2009 05:46 PM
Chevy Volt: Safe Sound Alert for the blind Mr. Wyndham General Automotive + Other Cars Discussion 11 11-29-2009 07:36 PM
V6 Exhaust Sound - other factors kellertxgen5 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 7 07-21-2009 09:14 PM
Sound check MustangKillr 4th Generation Camaros 8 10-08-2008 10:54 AM
