Old 02-25-2010, 12:22 AM   #1
Black LS3
Black LS3's Avatar
Drives: 2010 Black 2SS LS3
Exclamation I Need Verification 1st Can You Pls Verify That The DiabloSport Disables Skip-Shift??
I Need Verification 1st Can You Pls Verify That The DiabloSport Tuners Disable Skip-Shift on a 2010 Camaro 2SS 6M?
I bought myself the SuperChips 2950 Cortex Tuner and after Over a Week of SEVERAL Updates and Calls Plus Emails Back & Forth to the SC Tech Support they couldnt figure out what was wrong with the Programming of the SuperChips Tuner/Programming and Why it wasnt Disabling my Skip-Shift on my 2SS LS3 Camaro.
At the end, It finally came down to either me driving my Car 5 Hours to them for about a week or Wait Several Months To No ETA until they Find/Discover what was Wrong with the Bug that was causing this problem.
My very last option was to Return the SC Tuner back to where I bought it from which wasnt something I wanted to do because I've been a SC Fan for a really long time, Every Vehicle of mine that could use a Chip/Tuner I always used SuperChips, Way back when they didnt have these Fancy Tuners and you only had the Chips back then so I really liked the SuperChips Products and Ever Single Vehicle that I Installed one in to,... I Could Always Tell a Difference Right Away with the Butt Dyno Test but for some reason I couldnt even tell a Difference in the power after installing the Cortex 2950 and since the Skip-Shift wasnt working and I couldnt feel a difference in the power, I just couldnt Trust the Programming so I ended up having to return the Tuner.
My Question Is,...
Could Someone that Owns the DiabloSport Predator Tuner Please Verify for me that the Skip-Shift for the 2SS 6-Speed Manual Transmission Camaro Does In Fact Get Disabled for me? PLEASE....
I Would Really Appreciate Your Help Doing This For Me before I go ahead and purchase another Tuner only to find out that it doesnt work.
Also,... Could Someone with the Trinity Tuner Please take a couple Pictures of it installed in to your Car?
I want to see what the Cable looks like that Runs from the OBD Port up to where you have your Tuner located,... I'm interested in seeing what the Install of it looks like because maybe I'll end up buying that Tuner instead if everything works and it looks good while installed.
Thanks Guys.
Black LS3
A.K.A. Jim
OnlineAutorama.US - A Camaro Parts/Accessories Site for Dealers & Vendors.
Muffler Delete. ( See Videos - Vid 1. - Vid 2. )
Stock Resonators & H-Pipe Removed.
Magnaflow 2.50" Tru-X X-Pipe.
AirAid Cold Air Intake System.
11.21.09 1100 Order Accepted At Dealer - 11.24.09 2000 Accepted At GM - 11.25.09 2500 Preferenced - 12.03.09 3000 Production Control Notes: 01/11/2010 - 12.17.09 3400 Order Broadcast - 01.13.10 3800 Order Produced VIN # 2G1FT1E - 01.25.10 4000 Available to Ship from Rail Yard by Truck - 01.27.10 5000 Delivered to the Dealership - 01-27-10 6000 Delivered to Customer.
Black LS3 is offline   Reply With Quote
Old 02-25-2010, 08:23 AM   #2
06MonteSS
Drives: 2006 Monte Carlo SS
Yes... the diablo Predator and Trinity both disable the CAGs/skip-shift... absolutely...
06MonteSS is offline   Reply With Quote
Old 02-25-2010, 08:56 AM   #3
brtaus
brtaus's Avatar
Drives: None
^^^^^What he said.
Plus, as an owner of a Predator, I can tell you with 100% certainty, it does eliminate the skip shift.
brtaus is offline   Reply With Quote
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
V6 Skip Shift? B.A.Brunswick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 10-08-2010 11:42 AM
Avoid skip shift in the break-in? Vash Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 05-27-2009 11:39 AM
TUNE and Skip shift eliminator SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 05-12-2009 10:15 AM
Performance Numbers - Skip Shift fireresq157 5th Gen Camaro SS LS LT General Discussions 16 03-23-2009 01:59 PM
