Old 02-25-2010, 08:47 AM   #1
Sales @ ECS
Sales @ ECS's Avatar
Drives: 2011 CG 2SS
TTPerformance/TTP Motorsports 2010 Camaro Specials!
These specials will be good through the month of March !
Putting together a few specials on the new 5th Gen Camaros! This is available for all Camaro5 forum members:
Street/Strip/RR - Custom 4 Wheel Alignment: Normally $105 - $90 Special.
Bolt-On (Non internal engine modified or forced induction) Dyno Tune: Normally $250 - $200 Special.
Internal Engine Mod/Forced Induction Dyno Tune: Normally $525 - $450 Special.
TTP Installed Camshaft Packages
TTP Equalizer/Punisher Cam Only Packages
# TTP "Equalizer V.2/V.3" OR "Punisher V.4" Camshaft (Can replace with ANY Comp Cams Custom Grind)
# Patriot Gold Dual Spring Package with Titanium Retainers, Hardened Spring Seats, Hardened Keepers, & Valve Seals.
# Trick Flow Custom C/M Hardened Pushrods
# Royal Purple Synthetic Oil/Filter Change
# All gaskets/bolts necessary
# Full Installation of Camshaft + Valve Springs
# Custom Full Dyno Tune Includes Dyno Time
$2499.95 For 5th Gen Camaros -- $2200 SPECIAL
Add $165 Melling Select Oil Pump
Add $275 Powerbond Underdrive Pulley with Main & AC Serpentine Belts
Magnacharger TVS2300 Installations
Magnacharger TVS2300 System w/ A-W Intercooler
- 60# Injectors + Fuel Upgrades
- Cast Aluminum Intake
- 160* Thermostat
- NGK TR6 Spark Plugs
- Installation
- Complete Dyno Tune
Black-Non Polished $7600.00 TURN KEY
Procharger P1SC Installations
Procharger P1SC Tuner Kit
- 6-Rib Kit
- Installation
Add $230 for D1SC Upgrade
Add $100 for helical gear (Quiet) Upgrade
Satin Brackets/Satin Charger $7550 TURN KEY
SPECIAL PRICING ON ALL TTP SINGLE TURBO CAMARO KITS. PLEASE CALL FOR PRICING
973 256 1234
Sales @ ECS is offline   Reply With Quote
Old 02-28-2010, 12:00 PM   #2
NinoSS
Drives: 2SS/RS CGM LS3
See you guys in a few weeks...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 02-28-2010, 01:37 PM   #3
flyby
Drives: 2010 Silver SS
Can you guys do a pedders xa drag package install and alignment???
flyby is offline   Reply With Quote
Old 02-28-2010, 05:24 PM   #4
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
its about time someone from jersey offering packages for us. Just need to add more levels of upgrades. More like a supercharge kit, then a supercharge kit with cam and a final kit with supercharge and cam and some internal work.
We like more options.
SSTony is offline   Reply With Quote
Old 02-28-2010, 05:27 PM   #5
SSTony
SSTony's Avatar
Drives: SS Camaro
any idea what HP gain is from your cam option? Do you offer a cam package for someone who wants a supercharger down the road? I guess I mean a supercharger cam that can add a supercharger down the road?
Old 03-02-2010, 06:58 AM   #6
Sales @ ECS
Drives: 2011 CG 2SS
flyby: We are working on some packages right now for suspension goodies. We do all scale corner balancing + camera alignments in-house so its a specialty of ours!
Sure, I'll put together some Procharger & Magnacharger installed packages also.
SSTony: You can refer to this post for our cam packages.
http://www.camaro5.com/forums/showthread.php?t=67720 .. And yes as far as cam selection, we do a lot of cam only installs that are prepared for further forced induction mods !! We like to customize every package per customer, so after a discussion with the client we go forward and make a cam recommendation.
Vortech Supercharger Systems for 2010 Camaro Official Release Brian@Vortech Forced Induction - V8 98 02-20-2010 12:04 AM
