HeadlightArmor
Old 02-26-2010, 06:44 AM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Where to set Stoich for E10 in HPTuners
I'd like to set my Stoich AFR in HPTuners and living in Jersey we are "up to" E10 for pump gas. I know the table that has to be updated and have included it here below, the far left cell gets updated but do I have to update anything to the right of it? Also, for anyone that is doing the same, are you just setting Stoich to 14.137 or going a little bit higher like 14.25 or 14.3 because it is "up to" E10. I know this is being a little picky but so be it...Thanks in advance...
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 02-26-2010, 07:32 AM   #2
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
I believe you are right and only the first cell is referenced by the computer, I just played it safe and updated the entire row though, it doesn't hurt.
Your best bet is to just split the difference and set the stoich to 14.4.
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 02-26-2010, 01:57 PM   #3
robertway
robertway's Avatar
Thanks, this then begs the question, what are all the other cells to the right in that table there for.
As for a WOT target with E10, I have seen the 11.9-12.0 range mentioned for an N/A vehicle as opposed to the 12.4-12-6 based on E0 so I am assuming a split the difference target would be 12.2ish.
Old 02-26-2010, 02:44 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the other parameters to the right are for vehicles that have flex fuel option enabled,, the camaro OS is not a flex fuel file,, but it shares many tables with many gm gen4 engines that do have flex fuel
Stealth Performance--Kooks Headers and Off-Road Pipes--1 set left--Special Installed! Torchdvette USA - Texas 0 09-01-2009 11:33 PM
Alignments and Chassis set up JANNETTYRACING Wheels and Tires Talk Sponsored by The Tire Rack 0 08-30-2009 12:16 PM
Dynatech Supermaxx Headers w/ Cats--1 set left in stock, special install price!! Torchdvette V8 Bolt-Ons & Tunes 0 08-29-2009 03:51 PM
OK...the camaros are being delivered...What's the off set?! NightmareSS Wheels and Tires Talk Sponsored by The Tire Rack 7 04-21-2009 11:17 PM
