Old 02-27-2010, 06:09 PM   #1
376camaro
Drives: Black on black 2010 camaro 2ss
rear diffuser
Do I have to remove the mufflers in order to take my rear diffuser off???
376camaro is offline   Reply With Quote
Old 02-28-2010, 05:36 PM   #2
SummoneR
Paul
SummoneR's Avatar
NO
Old 02-28-2010, 06:16 PM   #3
376camaro
I removed the 7mm screws that attach the diffuser to a plastic bracket ( under the car ), them I pulled out the two plastic " clips " on each side of the diffuser but it still wont come off. I think there is more clips on the top of the diffuser (attached to the bumper) but I cant see or touch them because of the steel frame. What do I do?????
Old 02-28-2010, 06:28 PM   #4
SummoneR
Paul
SummoneR's Avatar
There are some plastic tabs along the top of the diffuser they can be a pain in the butt to detach, be firm but gentle as to not break them.
Old 04-30-2010, 04:08 PM   #5
l008com
l008com's Avatar
Drives: 2013 1LT Crystal Red/Beige Manual
I'm stuck in the exact same spot. Can you give me a little more info. "firm but gentle"... ok but what exactly are you supposed to do? Pull? Push? In which direction? Should I be prying with something?
l008com is offline   Reply With Quote
Old 04-30-2010, 06:03 PM   #6
67Redux
Drives: 1111
Im stuck here also and cant find any info anywhere on the net.
67Redux is offline   Reply With Quote
Old 04-30-2010, 07:58 PM   #7
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I've gotten mine off and it sucked.if you take the four bolts out
just hope the air bag don't go off.not shore my self about the bolts.
I took all the screws out and started onthe sides pulling on the Diffuser.
I worked my way along the top pulling and prying till fingers hert.
It will pop some easily and some just pop. I broke two tabs butt they
were in the middel . When I re installed the diffuser it didint seam loss or
shaky at all. Lucked out -would of bout a new one if it didnot fit right.
Hope this helps it just sucks to pull on . Maybe some one found a better way.
chevy 3 is offline   Reply With Quote
Old 04-30-2010, 08:46 PM   #8
67Redux
Drives: 1111
I got the Havoc diffuser and the instructions say I got to drop the whole back end. If I disconnect the battery will it disable the airbags?
Old 05-01-2010, 07:09 AM   #9
chevy 3
NEcamaro5
chevy 3's Avatar
Gary from Garyscustomz might know.
Look in the venders section this guy
is good. Garry has taken pritty much
the whole car apart at one time or other.
Old 05-01-2010, 01:10 PM   #10
67Redux
Drives: 1111
OK I found the instructions for my diffuser online with pics.
Installation Instructions-Vehicle Prep and Part Prep
Note: Prior to performing installation, make sure the vehicle surface and diffuser are at least 65º F (18ºC). Also, clean all contact areas of vehicle with 80/20 alcohol/water solution. Make sure all areas are dry and free of all dirt and contaminants.
Note: With ¾” masking tape, tape off the two outside tab locations with masking tape before having part painted. Remove masking tape before applying the 3M adhesive double sided tape. See Picture 1.
1) Wipe down outside tabs with 80/20 alcohol/water mix. Allow to dry.
2) Apply supplied adhesion promoter to tape area. Allow to dry.
3) Apply double sided tape to the outside tabs of the diffuser covering entire surface. 2 pieces of tape are supplied with your kit. It will be necessary to cut each piece to length leaving a 3” tape lead on both. See picture 2.
4) Open trunk lid and remove both plastic corner covers by removing 3 push pins on both sides. See picture 3.
5) Unplug both tail lamp harness connections.
6) Remove 4 fasteners holding each of the rear of the wheel well liners. (Rear 4 fasteners only) (1) 7mm head bolt and 3 screws. See picture 4.
7) Taking caution not to flex the fascia, grab the front of the rear fascia and pull outward to release the tabs. See picture 5.
8) Using two people, pull the rear fascia from the rear and remove. Place the fascia on a soft surface as installation of the new diffuser will be done off car. See Picture 6.
9) From the inside of the fascia, remove the honeycomb EA bracket attached to the OEM diffuser. This can be accomplished by leaving the wire harness attached to the bracket, but unplugging all connections to the lights. You will also need to remove the 4 bolts holding the bracket to the OEM diffuser. See picture 7.
10) Remove the OEM diffuser by sliding the tabs through the slots in the fascia and remove from the front. See Picture 8.
11) Remove the 4 clip nuts from the OEM diffuser as they will be used again in the installation process.
Old 05-01-2010, 05:29 PM   #11
67Redux
Drives: 1111
Pics 3 to 7
Old 05-01-2010, 09:26 PM   #12
l008com
l008com's Avatar
So for those looking to remove it without taking off the bumper... "Firm but gentle" really doesn't work. You just yank the thing as hard as you can and it starts to pop off. I lost maybe 2 or 3 clips, it still stays on very firm.
Old 05-02-2010, 12:27 AM   #13
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
no need.. just slip them through
AlSuwaidi is offline   Reply With Quote
Old 05-02-2010, 06:27 AM   #14
l008com
l008com's Avatar
Revolutions Rear Diffuser is now for sale Indpowr Exterior Parts & Accessories 34 10-25-2010 12:40 AM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 05:58 PM
Leno Camaro rear diffuser available? CamaroDude Cosmetics and Lighting Modification Discussions 1 11-09-2009 03:58 PM
I have a body colored rear diffuser! PQ Camaro Photos | Spyshots | Video | Media Gallery 20 06-10-2009 08:07 PM
