Old 09-16-2008, 12:09 AM   #1
MustangKillr
MustangKillr's Avatar
Drives: 2002 Z28 Camaro
V6 or V8?
Alright, I'm sure this has been asked countless times before, and we've all realized the potential of the new V6 Camaro. Here's what I want to know, will it be better for me in the long run (in the sense of doing aftermarket changes) to buy the V6 or the V8. When I say V8 I mean LS3 and V6 I mean L99. As a rule of thumb the V8 would be a natural because one would think that a high powered powertrain could only get more powerful. However, the V6 has me thinking twice. From what I've been hearing the V6 is a lot more of wide open sandbox as far as aftermarket changes go, and in the end could ultimately surpass the V8 in performance. Of course, I may just have my fact out of line, and if I do please forgive me, I'm only restating what I've been hearing through the grapevine. Thanks.
MustangKillr is offline   Reply With Quote
Old 09-16-2008, 12:21 AM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Well...first off, there's two things you need to take into account.
#1, the engine 'names' are as follows :
Manual V8 = LS3
Automatic V8 = L99 (basically an LS3 with AFM)
Auto/Manual V6 = LLT
and #2; generally speaking (what you said above, just different words)--If you take V8 and a V6, and pump the same amount of money into both, the V8 will still produce more power. How much more depends on what you actually do to them...
The V6 is equipped with Direct Injection, which opens up new possibilities. Until the aftermarket gets ahold of the car, though -- I wouldn't know what to tell you in regards to potential. What does everyone else think?
Old 09-16-2008, 12:26 AM   #3
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
Depending on the aftermarket compatibility with Direct Injection this could go either way. If you get the LS3, expect immediate (as in months) aftermarket support. If you go with the 3.6L, I would venture to guess you could get a few small mods within the first six months, with much larger stuff the following year as they crack the codes for the D/I engine.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 09-16-2008, 12:50 AM   #4
JiXeR'z DoDgE/FoRd KiLLeR
SSiCk MeMbEr!!!
JiXeR'z DoDgE/FoRd KiLLeR's Avatar
Drives: HeAviLy MoDDeD 2010 SS CaMaRo!
Get the SS LS3 man! If you can afford it it would be wrong if you don't right...
JiXeR'z DoDgE/FoRd KiLLeR is offline   Reply With Quote
Old 09-16-2008, 08:33 AM   #5
MustangKillr
Oh it's an LLT? My mistake I was under the impression that the L99 was for for the V6 as well as the V8, but in retrospect that doesn't make much sense, lol . Hm, but the V8 is multi-port isn't it? Wouldn't the multi-port be a whole lot better in the long run than direct injection? Of course, money isn't an object I just don't want to buy my super sport V8 only to outrun by a petty V6 with humongous amounts of aftermarket tuning that I couldn't otherwise put in mine, know what I mean?
Old 09-16-2008, 09:07 AM   #6
srtclg1007
srtclg1007's Avatar
Drives: 08 C6 NPP, MZ6 436hp
Isnt there a reason they make the V6 and V8 the way that they do. If you mod a v6 that much, wouldnt that cut down on the life of the LLT?
srtclg1007 is offline   Reply With Quote
Old 09-16-2008, 09:32 AM   #7
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
Consider the following;
- your budget
- insurance
- need
The easy answer is, if you can afford it, go for the SS/hence V8. But if cost is an issue, based on what I've seen so far, the V6 is nothing to sneeze at.
I'm sure there will be a market (aftermarket) for both, so decide which works better for you, V8 v. V6, and base your decision on that.
Moose is offline   Reply With Quote
Old 09-16-2008, 10:14 AM   #8
z28collection
waiting for 5th gen
z28collection's Avatar
Drives: 99 z28 6 speed, 81 z28 auto
v8
def. V8
speed kills-drive a ford and live forever
http://www.myspace.com/ashleyjfowlkes
z28collection is offline   Reply With Quote
Old 09-16-2008, 10:28 AM   #9
SS4EVER
Camaro Convert...
Drives: 2006 Cobalt SS Supercharged
V8 ultimately will have the most potential. If your criteria is strictly based off of which engine will have more potential for the price then The Camaro SS is your ride.
Now if you're looking at something more affordable with better fuel efficiency, lower insurance rates, or a more practical daily driver, then the Camaro V6 is probably what you would want to look into.
I'm actually planning on getting a fully loaded Camaro LT (6spd manual) w RS package, just because it's going to be my daily driver, and i'm going to want something that will still get decent mileage but I'm definitely planning on doing some mods to it (like CAI, Headers, Cat-back, tune) if and when those mods eventually become available...
4 life!
Currently Driving: 2006 Cobalt SS Supercharged
SS4EVER is offline   Reply With Quote
Old 09-16-2008, 10:32 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The DI is more efficient than the MPFI because it atomizes the fuel more completely thereby making it easier to combust. What that amounts to is there is more engery produced from that fuel.
IMHO, right now, in terms of aftermarket support, the V8s have the advantage. A lot of what has worked on on past LSX engines can work on this one. The heads and intake are the biggest diversion from the LS1, however, the ports on LS3s are so huge that they rival CNC ported numbers from LS1/2/6 heads. In addition, I'm sure the LS3 is easier to work-on and modify because it's just a simpler design; it's not DOHC like the 3.6. The LS3 will always make better torque which'll move the car better.
I say, given your situation, if you can afford the V8, go with it. It probably wouldn't hurt to check out some LLT sites too if you haven't. I know there's a lot of untapped potential, but I admittedly don't know as much about that engine yet.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 09-16-2008, 08:23 PM   #11
MustangKillr
Alright, that's what I was hoping to hear. I want my Camaro to be as fast as possible, and I wanted to know if that meant the difference between buying a V6 or a V8. Again, money is NOT an object, this car is my first and only priority (I'm about to go to college with tuition and what not covered completely) so I want it to show that I have a powerful car. The main thing that I'm trying to ask is: hypothetically, if I put all that I could possibly cram into a V8 and all I could possibly cram into a V6 regardless of costs, which one would ultimately come out on top? Of course there's no 100% way to know, because it's just speculation and aftermarket could provide a wealth of unknown things for both, but it never hurts to make guesses right ; )?
Old 09-16-2008, 08:59 PM   #12
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
For raw, unadulterated speed, get the V8. For economy and competitive speed, get the V6. Both are ridiculously impressive for what will be charged, and both will look impressive.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 09-16-2008, 11:09 PM   #13
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
get the v12
5th_GEN_SS is offline   Reply With Quote
Old 09-16-2008, 11:45 PM   #14
MB2010CC
Back in Black
MB2010CC's Avatar
Drives: 2010 Black 2LT/RS Camaro
Originally Posted by 5th_GEN_SS View Post
get the v12
YES!!!
Currently Drives: Purple 1996 Chevrolet Beretta. Nicknamed The Purple People Eater NOT ANYMORE!!!(Which is exactly why I am getting a 2010 Chevy Camaro )
MB2010CC is offline   Reply With Quote
