| General Automotive + Other Cars Discussion Come chat about other cars. |
Thread Tools |
![]() Drives: 2008 Holden Commodore SSV Join Date: Oct 2009
Minimum HP for 200mph
I am sure I am opening a can of worms, but I wanted to gather some opinions.
I frequent a few online boards and over the years I have come across some rediculous claims of top speeds for cars. Like a Supra with 500 rwhp claiming a top speed of over 200. Oh yea, he also claimed to do it on a weekly basis on public roads. From a realistic standpoint, what is the minimum HP needed to hit 200MPH? I am sure it will depend on the weight and drag coefficient of the car. So lets just make the playing field simple. Although weight isn't a big contributing factor for top speed runs, 3000lb car street car with a middle of the road drag coefficeint of around .30 to .33.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
I would think that the supra you speak of can do it with no problem. If he has the correct gear 500hp should do the trick in that car. IMO!
LOL at most people here.
Drives: 2005 GTO,2006 M6, 2007 300 Touring Join Date: May 2009
Yeah, that supra could easily do it. Remember the LS3 Vette can hit about 194, now give it a better gearing and it could hit 200 and thats with only 430hp.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1984 Honda Nighthawk 700s Join Date: Sep 2008
As already said above, the 200 mph claim isn't what should be causing disbelief here. The fact that he CLAIMS to be doing 200 regularly on public roads, THAT is a bunch of BS.
Corvette and Camaro lover
Drives: 2010 Camaro...some day... Join Date: Apr 2008
0 horspower. All you need is a lot of distance between the plane and the ground.
#6 |
![]() Drives: 1967 camaroSS Join Date: Mar 2007
all depends on the transmission and rearend
#7 | |
Moderator.ca
Multiply 53.26 by the cubic root of power divided by the product of the drag coefficient and the area. That gives you the top speed for a particular power. Rearranged for power to go 200 mph: hp=Cd*A*(200/53.26)^3 A super aerodynamic Bonneville racer might only need 100 hp to go 200 mph. On the other hand, a semi would need more than 4000. For normal cars, it will be between about 400 and 550 hp. And these are power numbers at the wheel, at that speed. You can't even use peak wheel hp. Power changes with rpms so while a car may peak at 500 rwhp @6000 rpm, odds are it won't be turning 6000 rpm @200 mph. For example, a manual Camaro SS would be turning 4620 rpm with the stock gearing and tire size. So you will need more peak power then you thought, in the case of the Camaro about 650 rwhp @5900 rpm. The story of the guy with the supra being able to hit 200 mph with 500 rwhp is plausible, until he claimed to do it regularly on public roads. He wouldn't be able to find good enough conditions (smooth road, of sufficient length, with no traffic or curves) to attempt it weekly.
__________________ Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP No. Let me repeat that. No. FbodFather __________________ Camaro5 Fest III Information Camaro5 Fest III pre-registration |
#8 |
Good information!
Thanks DGthe3! This wasn't supposed to be about one specific Supra. I have seen the claim in several places. Just wanted to see some math to see how rediculous people were being.
#9 |
Guest
Here's your answer in a nut shell. about 650Hp
The Physics of Racing Part 6: Speed and Horsepower These articles were written by Brian Beckman (brianbec@microsoft.com) physicist, and member of No Bucks Racing Club. ©Copyright 1991, Brian Beckman The title of this month's article consists of two words dear to every racer's heart. This month, we do some ``back of the envelope'' calculations to investigate the basic physics of speed and horsepower (the ``back of the envelope'' style of calculating was covered in part 3 of this series). How much horsepower does it take to go a certain speed? At first blush, a physicist might be tempted to say ``none,'' because he or she remembers Newton's first law, by which an object moving at a constant speed in a straight line continues so moving forever, even to the end of the Universe, unless acted on by an external force. Everyone knows, however, that it is necessary to keep your foot on the gas to keep a car moving at a constant speed. Keeping your foot on the gas means that you are making the engine apply a backward force to the ground, which applies a reaction force forward on the car, to keep the car moving. In fact, we know a few numbers from our car's shop manual. A late model Corvette, for example, has a top speed of about 150 miles per hour and about 240 hp. This means that if you keep your foot all the way down, using up all 240 hp, you can eventually go 150 mph. It takes a while to get there. In this car, you can get to 60 mph in about 6 seconds (if you don't spin the drive wheels), to 100 mph in about 15 seconds, and 150 in about a minute. All this seems to contradict Newton's first law. What is going on? An automobile moving at constant speed in a straight line on level ground is, in fact, acted on by a number of external forces that tend to slow it down. Without these forces, the car would coast forever as guaranteed by Newton's first law. You must counteract these forces with the engine, which indirectly creates a reaction force that keeps the car going. When the car is going at a constant speed, the net force on the car, that is, the speeding-up forces minus the slowing-down forces, is zero. The most important external, slowing-down force is air resistance or drag. The second most important force is friction between the tires and the ground, the so-called rolling resistance. Both these forces are called resistance because they always act to oppose the forward motion of the car in whatever direction it is going. Another physical effect that slows a car down is internal friction in the drive train and wheel bearings. Acting internally, these forces cannot slow the car. However, they push backwards on the tires, which push forward on the ground, which pushes back by Newton's third law, slowing the car down. The internal friction forces are opposed by external reaction forces, which act as slight braking forces, slowing the car. So, Newton and the Universe are safe; everything is working as it should. How big are the resistance forces, and what role does horsepower play? The physics of air resistance is very complex and an area of vigorous research today. Most of this research is done by the aerospace industry, which is technologically very closely related to the automobile industry, especially when it comes to racing. We'll slog through some arithmetic here to come up with a table that shows how much horsepower it takes to sustain speed. Those who don't have the stomach to go through the math can skim the next few paragraphs. We cannot derive equations for air resistance here. We'll just look them up. My source is Fluid Mechanics, by L. D. Landau and E. M. Lifshitz, two eminent Russian physicists. They give the following approximate formula: The factors in this equation are the following: coefficient of friction, a factor depending on the shape of a car and determined by experiment; for a late model Corvette it is about 0.30; frontal area of the car; for a Corvette, it is about 20 square feet; Greek letter rho, density of air, which we calculate below; speed of the car. Let us calculate the density of air using ``back of the envelope'' methods. We know that air is about 79%Nitrogen and 21%Oxygen. We can look up the fact that Nitrogen has a molecular weight of about 28 and Oxygen has a molecular weight of about 32. What is molecular weight? It is the mass (not the weight, despite the name) of 22.4 liters of gas. It is a number of historical convention, just like feet and inches, and doesn't have any real science behind it. So, we figure that air has an average molecular weight of I admit to using a calculator to do this calculation, against the spirit of the ``back of the envelope'' style. So sue me. We need to convert to pounds of mass per cubic foot so that we can do the force calculations in familiar, if not convenient, units. It is worthwhile to note, as an aside, that a great deal of the difficulty of doing calculations in the physics of racing has to do with the traditional units of feet, miles, and pounds we use. The metric system makes all such calculations vastly simpler. Napoleon Bonaparte wanted to convert the world the metric system (mostly so his own soldiers could do artillery calculations quickly in their heads) but it is still not in common use in America nearly 200 years later! Again, we look up the conversion factors. My source is Engineering Formulas by Kurt Gieck, but they can be looked up in almost any encyclopedia or dictionary. There are 1000 liters in a cubic meter, which in turn contains 35.51 cubic feet. Also, a pound-mass contains 453.6 grams. These figures give us, for the density of air This says that a cubic foot of air weighs 8 hundredths of a pound, and so it does! Air is much more massive than it seems, until you are moving quickly through it, that is. Let's finish off our equation for air resistance. We want to fill in all the numbers except for speed, , using the Corvette as an example car so that we can calculate the force of air resistance for a variety of speeds. We get We want, at the end, to have in miles per hour, but we need in feet per seconds for the calculations to come out right. We recall that there are 22 feet per second for every 15 miles per hour, giving us Now (this gets confusing, and it wouldn't be if we were using the metric system), a pound mass is a phony unit. A lb-mass is concocted to have a weight of 1 pound under the action of the Earth's gravity. Pounds are a unit of force or weight, not of mass. We want our force of air resistance in pounds of force, so we have to divide by 32.1, numerically equal to the acceleration of Earth's gravity in , to get pounds of force. You just have to know these things. This was a lot of work, but it's over now. We finally get Let's calculate a few numbers. The following table gives the force of air resistance for a number of interesting speeds: We can see that the force of air resistance goes up rapidly with speed, until we need over 350 pounds of constant force just to overcome drag at 150 miles per hour. We can now show where horsepower comes in. Horsepower is a measure of power, which is a technical term in physics. It measures the amount of work that a force does as it acts over time. Work is another technical term in physics. It measures the actual effect of a force in moving an object over a distance. If we move an object one foot by applying a force of one pound, we are said to be doing one foot-pound of work. If it takes us one second to move the object, we have exerted one foot-pound per second of power. A horsepower is 550 foot-pounds per second. It is another one of those historical units that Napoleon hated and that has no reasonable origin in science. We can expend one horsepower by exerting 550 pounds of force to move an object 1 foot in 1 second, or by exerting 1 pound of force to move an object 550 feet in 1 second, or by exerting 1 pound of force to move an object 1 foot in 0.001818 seconds, and so on. All these actions take the same amount of power. Incidentally, a horsepower happens to be equal also to 745 watts. So, if you burn about 8 light bulbs in your house, someone somewhere is expending at least one horsepower (and probably more like four or five) in electrical forces to keep all that going for you, and you pay for the service at the end of the month!. All this means that to find out how much horsepower it takes to overcome air resistance at any speed, we need to multiply the force of air resistance by speed (in feet per second, converted from miles per hour), and divide by 550, to convert foot-lb/sec to horsepower. The formula is and we get the following numbers from the formula for a few interesting speeds. I put 55 mph and 65 mph in this table to show why some people think that the 55 mph national speed limit saves gasoline. It only requires about 7 hp to overcome drag at 55 mph, while it requires almost 12 hp to overcome drag at 65. Fuel consumption is approximately proportional to horsepower expended. More interesting to the racer is the fact that it takes 145 hp to overcome drag at 150 mph. We know that our Corvette example car has about 240 hp, so about 95 hp must be going into overcoming rolling resistance and the slight braking forces arising from internal friction in the drive train and wheel bearings. Race cars capable of going 200 mph usually have at least 650 hp, about 350 of which goes into overcoming air resistance. It is probably possible to go 200 mph with a car in the 450-500 hp range, but such a car would have very good aerodynamics; expensive, low-friction internal parts; and low rolling resistance tires, which are designed to have the smallest possible contact patch like high performance bicycle tires, and are therefore not good for handling. |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 20TEN SS/RS L99 (SIM) Join Date: Nov 2009
"The terminal velocity of a skydiver in a free-fall position with a semi-closed parachute is about 195 km/h [120 mph]. Higher speeds can be attained if the skydiver pulls in his or her limbs... In this case, the terminal velocity increases to about 320 km/h [200 mph]" http://en.wikipedia.org/wiki/Terminal_velocity
#11 |
Property USMC
My automatic 02 Z28 had a hair less then 500. Had the stock rear and it pulled hard up to 171 with out even breaking a sweat. I let out of it cause I was getting scared. It was done on a closed road too just so everyone knows...
#12 |
![]() Drives: 71 Camaro Join Date: Sep 2010
Yeah, (BS) I strongly agree; I was in a friend's 'supra' on a lonely, flat, straight, smooth section of Az freeway and he opened it up to about 135mph (it took a L-OOOOONNNNN-G time to get up that speed with supposedly modified to almost 400hp), and the car felt: heavy, insecure, it rattled loudly, sluggish, & couldn't seem to stay in one lane. Furthermore, why would someone want to go that fast in a Toyota? It is NOT a muscle car nor especially not any kind of 'supercar'. When we got back into my 71 Camaro w/400sb & modified suspension it seemed much more secure, faster, & lighter.
#13 |
Downright Upright
Drives: Daily Join Date: Apr 2009
"It's what you learn, after you know everything, that's really important" ... Sam Foose . "NOTHING matters...until you CARE" ... and that's a LOWDOWN Truth "GOOD ENOUGH"...NEVER IS - Debbi Fields. "STAY TUNED" |
#14 |
Exiled Speed Junkie
Drives: None Join Date: May 2010
You can get a lot of cars to go 200 MPH like has been said here. However, to get one to go that fast safely and with stability is another story. You need downforce in the right places and a car that is going to be able to handle all the extra stresses, forces and heat that will be generated. You can shred even the best tires real fast at those speeds if the suspension isn't right. Even if you do all the aerodynamics and powered systems correctly, you're butt will be puckering if the car isn't engineered from the start for those kind of speeds.
Look at the huge differences between a Brabus Mercedes and even the AMG Benzes. They put a hell of a lot of modifications on those cars to get them to go fast safely with good stability. There is a reason that the Germans like that 155 MPH governor. It keeps them from having to deal with these types of issues.
#15 |
Seeking Advice
Minimum HP for 180-190+mph? Interesting discussions here guys. (Co-efficiency vs. HP vs. type of Car, etc.)
But does someone know the drag co-efficiencies for older Camaros (& Firebirds/TA's) vs. new(er) ones? (someone please tell me - I need to know...) Here's my situation: My beloved, expensive 4-year project car (71 Camaro) was feloniously stolen & illegally sold by the San Diego Police 19 years ago (Yes, an american Police Dept. actually committed Felony Grand Theft Auto and then covered it up {overt & harrowing police Crimes are not uncommon in San Diego, Ca.) and I'm confident they may finally settle with me - so I finally hope go out and buy something else and start a new project car. But this is what I'm trying to achieve: {apart from knowing drag co-eff's with various older/newer GM cars...}... I need recommendations of some fairly inexpensive used older/newer car(s) with good potential; but in attempts to eventually closely match the Autobahn's Ferarris, Porsches, & Lambos, etc. here in Europe where I live now. I was quite successful at this very same contest in Southern California 19 years ago with my 71 'super' Camaro - I was liked, & disliked, by the super-rich 'oil-familys' youngsters who could not out-drive me nor catch me in my Camaro while they drove their super-expensive, impressive exotic Italian iron back then. But now that 19 years has past I'm not sure if another 70's car has much overall potential against today's exotics. The last time I saw US muscle ripping the Autobahn [here] was when it was popular for a motor-head to have a Banks twin-turbo setup in a 1980's-1990 Trans Am or Firebird (because they supposedly had a favourable drag co-eff's., & Corvette-like handling potential especially with common, easy mods & VR/ZR tyre's). Now, the only American 'muscle'-car I see here is the Corvette - but they are somewhat common, expensive [here], and they only have two seats. Okay GM brothers, & seasoned enthusiasts: What fairly inexpensive car(s) now can be a good start for me here if I intend to use a power-plant based on the common older iron chevy 400 sb (with mods of course)? Also, can someone please tell me if it is easily possible to use the cheaper-available older iron blocks with the (newer?) cars? And, what about the existing trannys & rear-ends in post-1990's GM cars if one is using 450-550 ft.lbs.tq? - or do I now need to shovel a bunch 'o money for a newer, much more expensive engine casting/block (& tranny?) to easily fit into post-'90's cars? Also, 19 years ago I was just getting ready to graduate from Carburetion to more practical fuel-injection exploration, but due to the trauma & unspeakably painful theft of my pride & joy (Camaro) long ago I never owned another muscle car since. Is EFI nowadays pretty easy & relatively inexpensive to run on my (envisioned) 400sb with low-profile mini-blower (or even without the blower)? Should I stick with a Carb if/when using any (cheaper) under-the-hood Blower? Also, does anyone know of any similar GM enthusiasts like myself (or informal/formal GM {not-exclusively Corvette} Clubs/Organisations), but here in Europe that I could also meet & talk to? Lastly for the moment, can an 'experienced' person please constructively critique my envisioned motor-build idea(?); In my next 'sports' car I'd like to easily duplicate/surpass the hp/tq. of a lightly modified 454, but using a 400sb. Yes, I know of the 400's siamese design, & it's 5.65 rod length/rod-angle, etc., however, I built many 400's in the past and I was much happier with them than their 383(350) or 377(350) counter-parts mainly for the increase in inches making up for everything else as long as I didn't rev over 6,000-6500. But(?), are there now (cheap(er) 400sb mods (5.70-6.00" rods, forged crank, etc.) that will make the 400 {or a mild-stroker 420(400)} very usable, reliable & streetable like a 350 or 454, but with the 400sb using (with, or without) a smaller B&M, Weiand, or other 4-71(144cu?) blower? Keep in mind I don't want to spend a ton 'o money just on my engine. In the past I had around 450lbs/tq. for well under $2,000.USD, and I could have simply added a mini-blower (after reducing my compression/r) for another $1,500.USD {used} back then. I think I want to try something similar now here - but I'm wide open for suggestions. Oh: every gas-station [here] has 98 Octane, and I can also very easily buy newer-generation LL-100 AV 'blue' fuel for the same price (or cheaper). Here, high-compression or high-boost are practical. So; being that gas quality and speed limits are not a problem here - what would you do with a somewhat limited budget over a 2-year period? Thanks!
#16 | |
1 n the head,2 n da chest
Drives: 2002 cadillac deville Join Date: Apr 2010
i agree. my 96 turbo 4v can certainly get close. i have yet to run it over 165ish because its no joke on the streets at that speed. it was accelerating like hell as i passed that speed. it was enough. never been close to 200mph. never will be.
rides:2002 Caddy DeVille, 1996 turbo stang gt,1999 jeep wrangler,1999 454 powered GM motorhome,,
2011GT Brembo brake package, RapidSpec 300A, Candy Apple Red, Charcoal interior, 3.73 gears, spoiler delete..1 of 29-E85, offroad X, 82.5mm throttle body, CAI, axleback, E85 TUNE, 420ish rwhp. |
#17 |
one wheelin
ask a street biker how do they hit 200 with as lil as they do hp. theres your answere
#18 |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
#19 |
![]() ![]() ![]() Drives: aqua 2ss l99 Join Date: Jun 2009
my zx10 ninja did the 1/4 mile at 145 mph. with 136 hp. my zx14 had 203 hp, and ill bet you a twinkie no bike will beat 200 mph stock. things start getting real hard above 150.
especially braking, heh. and you cannot trust a bikes speedo, either. my gps said i was going 5-7% slower than the bike said.
May your exhaust note, sing in harmony with your blower.
#20 |
also look at nascar weights and speeds.
#21 |
Moderator.ca
Weight helps determine how long it will take to reach your top speed, not what that speed is. Adding 3000 lbs isn't going to slow you down, it will just take an awful lot longer to get up to speed.
Sport bikes can achieve their speeds because they are so bloody small. A stock car is nearly the same size as a regular car, with a cross section of around 20 square feet. A sport bike is probably close to 1/3 of that.
#22 |
sport bikes are horribly un-aerodynamic. and wieght is important, as there are so many texas miles....
not to mention the torture an engine takes to go wot for the duration of time needed to hit 200.
#23 | |
Moderator.ca
You're right that sport bikes are not aerodynamic (the Cd is around .5). But since a normal car is around a .35 yet 3x the area a sport bike would have a CdA of ~3 while a car would be ~7. Pretty big difference, despite the less aerodynamic shape. I acknowledged the role weight has in acceleration, but speed in and of itself is practically independent of weight (it plays a small role in figuring rolling resistance). So yes, if you have a limited track (ultimately, all tracks are limited ... even Bonneville) then weight could prevent you from achieving what the car is capable of. Durability ... you can build an engine to run WOT all day long if you want to. In fact, the LSA ran WOT for something like 11 days during testing.
#24 |
TRI-COUNTY CAMAROS
Drives: Black SS2/RS LS3 Join Date: Jun 2011
I can tell you my 2011 ss2 rs 6m will run, but at 130 it starts to get very light in the front end. For me to make it stable at speeds above that I know I would have to make sacrifices and add down force which would obviously lower the top speed of what it could run, If I was dumb enough too.
So the question is, what would you sacrifice? I have been 6.36 192 mph in a pro mod designed to be quick and there is no comparison as to what you can do to a street car
spd2612
2011 Black LS3 SS2 RS CAI, Hurst Short Throw,Concept SMD Sidemarker lights, LED Sequential Tail Lights, MSD Digital Shift Light, 1 7/8 Long Tubes, 3 inch Stainless exhaust header back, X Pipe, Cat Delete, Solo J-Pipe Mod, Powder Coated Wheels, FSP Custom Grind Comp Cam's, VMax TB., PFADT TL, TA, SF Bushings. Tri-County Camaro SWFL Chapter |
#25 |
Buy American!
Drives: 2011 Shelby GT500 Join Date: May 2009
I remember an old issue of Super Chevy or Chevy Hi performance from the late 90's and the formula back then was a 3rd gen F body and a 500hp 502cid crate motor could get you there but you needed GTS headlight covers
![]() Any other Chevy die hard's remember that issue?
LS1 powered 79 Toyota Rockcrawler th400, stak 3 speed t-case, dana 60/14 bolt, 42" irok's, coilovers
1972 Monte Carlo 350/350 12 bolt posi 2003 Dodge Ram 3500 6 speed, Cummins Turbo Diesel, 476rwhp/913rwtq ![]() |
| Thread Tools | |
| Lowered Minimum order for 15% off Sale | Chris@glimmerglass | Wash/Wax/Detailing and Cosmetic Maintenance Parts | 0 | 02-26-2010 08:21 PM |
| Laws Protecting Consumers for Aftermarket Parts | strauchpete | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 01-17-2010 08:31 AM |
| Minimum size wheel on SS Brembo Brake | JEFF2010SSMANUAL | Wheels and Tires Talk Sponsored by The Tire Rack | 57 | 10-21-2009 01:04 PM |
| IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
| minimum hp gains from gmpp headers/A.I./catback? | s.norman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 75 | 11-16-2008 02:23 PM |
