Cold Air Inductions
Old 09-17-2008, 06:38 PM   #1
13F20
Drives: Soon to be 2010 Camaro SS
5th gen drive shaft area of concern.
found this one LS1 TECH.
Dont forget the 2 piece driveshaft which may twist/break easier needing replacement for a 1 pc like in the modded GT500's and modded Mustang GT's.
It will ride smooth though with less vibration into the cabin.
The 5th gen will be getting a 2 pc DS???
05 Mustang GT + 2.3 twin screw
yep, you can see it here
http://gm.wieck.com/forms/gm/previewpage?048183
really not a suprise. just one more thing to swap that will pick up 10 hp and a tenth
The base engine for the 2010 Chevrolet Camaro includes a 3.6L SIDI engine producing 304 bhp and 270 lb. ft. of torque. Standard transmission is an Aisan Warner, six-speed manual. A six-speed Hydra-Matic 6L50 automatic may be ordered. All models feature an independent rear suspension system as standard equipment. X10AR_CH012 (United States)
Yea. The new GT's have 2 pc DS from the factory also, and have seen some pretty good RWHP improvements by going to an aftermarket 1 pc DS. But for someone looking to stay stock or close to stock, the 2 pc unit does make for a really smooth quiet ride.
Well back when I had my V6 Camaro a lot of them came with 2 piece ones. They either had a 1 piece steel or 2 peace steel. If you had the 2 peace steel you could change to the 1 piece steel and lose some weight and if you wanted to spend some money you could go with the 1 piece aluminum out of an ls1 car to save even more weight.
http://forum.camaro*******/showthread.php?t=9906
I cannot really say how much my lt1 driveshaft helped my times since I did a rear axle swap and got 3.42s and lsd at the same time. but either way it is lighter then a stock 2 piece one, usually only costs like $25, AND most important, is likely not to have a center bearing go bad, and cause problems(like mine did)
here are some pics for comparison same years:
2 piece steel
13F20 is offline   Reply With Quote
Old 09-17-2008, 07:24 PM   #2
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Yes yes yes, we will have a 2 peice drive shaft. YES it will hold up to mods, NO it wont hold on outrageous amounts of HP.
PS - the replacements for the GT's are bad because they don't allow for rear passengers (too much weight in the rear and the ds contacts the body/frame). That's for the 4" shafts that are the most common. You can get a 3.5 that doesn't but they are more expensive because they are generally custom made.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 09-17-2008, 08:44 PM   #3
Silverghost
Silverghost's Avatar
Drives: Z28
I'd rather replace a broken driveshaft than a broken rear-end, I've seen some of the Goats break their rears after doing the swap. Just have to wait and see if GM has beefed any of the components up with the 5th Gen.
Speed Kills - Drive a Ford and live forever!
www.rivercityperformance.com
Silverghost is offline   Reply With Quote
I'm not sure if I'll buy a 5th Gen. Camaro Moose 5th Gen Camaro SS LS LT General Discussions 68 06-13-2009 06:18 PM
Put ideas of a 5th gen on hold. mxkx250 5th Gen Camaro SS LS LT General Discussions 2 08-10-2008 01:11 PM
Past Camaro reliability and Future 5th Gen JMROD 5th Gen Camaro SS LS LT General Discussions 52 04-13-2008 03:15 AM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 11:17 AM
5th gen and winter driving rray200 5th Gen Camaro SS LS LT General Discussions 28 03-08-2007 02:55 PM
