Cold Air Inductions
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 09-17-2008, 07:25 PM   #1
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Maintenance reference
For all of us that do our own maintenance... Here is some reference info for ya...
LS3 Oil Filters -
Mfr. - Part # - MSRP
K&N - HP1017 - $11.99
Mobile one - M1113 - $10.99
Fram - PH10060 - $6.49
GM Part PF48 - 89017524 - $4.98
LS3 Oil Capacity - 8.9 quarts (10W30)
Amsoil -ATMQT-EA - $80.10 (8.90/quart)
Mobile One (synth) - 98HC65 - $59.31 (6.59/quart)
Royal Purple - 1130 - $71.01 (7.98/quart)
Valvoline (syth) - 296 - $43.11 (4.79/quart)
Quaker State (synth) - 5062626 - $53.91 (5.99/quart)
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
The_Stache is offline   Reply With Quote
Old 09-17-2008, 07:57 PM   #2
gunslinger
Drives: 1998 Z28 M6
Are you sure about 9 Qts?
The LS1 only used 6 for street use and almost 7 quarts for Road Racing...
gunslinger is offline   Reply With Quote
Old 09-17-2008, 08:02 PM   #3
96CAMaro
96CAMaro's Avatar
Drives: '02 Impreza 2.5RS
8.9 quarts
96CAMaro is offline   Reply With Quote
Old 09-17-2008, 08:04 PM   #4
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Thats what the spec sheet says... although the vette guys are hitting the full mark at 6 quarts... as soon as its official (one way or another) I will change it accordingly...
Old 09-17-2008, 08:10 PM   #5
Jak
Jak's Avatar
Drives: 03 Dodge Dakota
I see the L99 takes 8.5 quarts. Why so much oil?
Jak is offline   Reply With Quote
Old 09-17-2008, 08:55 PM   #6
13F20
Drives: Soon to be 2010 Camaro SS
On the maintenance issue. I was told by a former GM mechanic that when you are breaking in the motor on a new car. Use regular engine oil for the first 500 miles then switch to synthetic. Reason being that if you use regular oil it causes the pistons to rub the inside walls and knock off the excess metal partials and smooth out the area to make the pistons move smother when you switch over to synthetic. Also place an oil filter magnet in the oil filter that will collect the metal partials that the pistons will knock off. Just remember to tell the maintenance personnel to NOT throw the magnet away when you do your first change. All you do is rinse off the magnet and place it back in the oil filter.
13F20 is offline   Reply With Quote
Old 09-17-2008, 08:59 PM   #7
Zieke
Camaro Deprived
Zieke's Avatar
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt
Send a message via MSN to Zieke
i havent looked at too many spec sheets or computer drawings of the camaros systems.
but how much of this car can we NOT work on, at all.
i do a lot of my own maintenance. weve never taken a vehicle in for an oil change or stuff like that.
so what can i do with the camaro, or not do?
thanks.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it.
Joined Active Navy: 10-28-08
Zieke is offline   Reply With Quote
Old 09-17-2008, 09:01 PM   #8
13F20
The best thing I can say is to ask you local Chevrolet dealer. They would know better than any one.
Old 09-17-2008, 09:10 PM   #9
Zieke
Camaro Deprived
Zieke's Avatar
the dealers ive talked to dont know a darn thing.
1 of them actually didnt know the camaro was coming back. i refused to talk to him.
but the guys in the maintenance dep. do know a lot. just not much at the moment. im sure they will no more the closer we get to being able to buy one.
Old 09-17-2008, 09:11 PM   #10
ucla1ove3
ucla1ove3's Avatar
Drives: soon to be 2010 CAMARO :]
13f20.. when you were talking about the magnet. do you mean for the initial five hundred miles/break in period or what?
ucla1ove3 is offline   Reply With Quote
Old 09-17-2008, 09:18 PM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
The Camaro's LS3 takes more oil due primarily to a larger oil pan and oil cooler.
Two items which the Corvette's LS3 does not have.
http://www.camarohomepage.com/ls3/index.htm
"Keep the faith." - - Read Before You Post.
Old 09-17-2008, 09:23 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
WTF?! I missed that!!! Huh...
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 09-17-2008, 09:24 PM   #13
13F20
No,no,no. Keep the magnate in there for a while. Even after 500 miles there is no grantee that all the metal will be gotten. Plus over the life of the engine, metal will continue to filter threw the oil circulation. Thus the more partials you gather over the life of the car extends the life of the engine.
Old 09-17-2008, 09:25 PM   #14
ucla1ove3
ucla1ove3's Avatar
gracias senor.
Old 09-17-2008, 09:29 PM   #15
13F20
check at the bottom of the page.
The oil pan used on the Camaro LS3 is quite a bit different than the one used on LS1s in the 4 Gen cars and it's different from the one used by the LS3 when it was introduced on the Corvette for 2008. The Camaro pan is a bit bigger inside holding a additional two quarts of oil compared to the Vette LS3. Otherwise, the pan is similar in concept to other Gen 3/4 oil pans in that, besides holding all the oil, it acts as a sound insulator and add some rigidity to the bottom of the block. In addition, the Camaro LS3 has an engine oil cooler because, according to ACE Ron Meegan, "...of the (vehicle) weight and the (reduced) air flow around the engine in this package, some of the more aggressive driving modes required us to use a cooler to meet our oil temperature requirements." The Camaro oil cooler is the same type of oil-to-coolant heat exchanger used by the supercharged LSA in the Cadillac CTS-V and it is mounted in a similar location, on the left side of the oil pan.
Old 09-17-2008, 09:29 PM   #16
Zieke
Camaro Deprived
Zieke's Avatar
Theres a lot of detailed info there. thanks.
Old 09-17-2008, 09:30 PM   #17
13F20
gracias senor.
no prob
Old 09-17-2008, 09:37 PM   #18
Mr. Wyndham
Thank Tom Henry and friends.
...but, you're welcome for posting it!
Old 09-17-2008, 10:34 PM   #19
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I read that article but forgot Thanks for the help though
Old 09-18-2008, 01:35 PM   #20
lalometalik
killer bAnana
lalometalik's Avatar
Drives: 1985 z28
this was on the 'Synthetic?' topic and i found it to be quite informative.
take a look:
Have a look at this site:
http://mototuneusa.com/break_in_secrets.htm
There's a lot of good information and this chap emphasizes NOT using synthetic during break-in. Whether-or-not you agree with everything, I think it has a lot to think about.
"Shut your noise tube, Taco Human!"
lalometalik is offline   Reply With Quote
8 pages of 2010 Camaro Info - Camaro "Salesperson Reference Guide" Txturbo Guides, Manuals, Bulletins, Documentation Archive 185 09-07-2010 09:56 AM
New car maintenance AerospaceGuy General Automotive + Other Cars Discussion 4 04-08-2008 06:44 AM
Maintenance question lafountain 4th Generation Camaros 3 04-04-2008 02:22 PM
