Old 03-02-2010, 10:23 PM   #1
convert
convert's Avatar
Drives: the Camaro as often as possible
iPod menu problem
I have the iPod Touch 3G and I've tried resetting it as well as restoring it, but neither has helped resolve the issues with the iPod interface in the Camaro. My car has the CC hardware and CE software (from the factory).
When I search by artist, the first several artist names show up blank. When I select one, the album names don't show up right -- sometimes they're artist names, sometimes they're track names. When I select an album the track names show up ok.
I know this has been discussed on here before, but I've tried all the suggestions and none helped. I'm just wondering -- do you think this is an issue with the iPod or the PDIM? I assume it's with the PDIM, so what's the word on getting an update to fix it? It's driving me nuts!!!
convert is offline   Reply With Quote
Old 03-02-2010, 10:40 PM   #2
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
Drives: Black 2014 2SS/RS
Maybe you've already checked this, but are you sure the ID3 information in each mp3 is correct in your iTunes software? Garbage in - garbage out, you know. If you're using mp3s with poorly formed tags, the car will simply read the info it's given.
I have a huge library of mp3s (maybe 40,000 tracks) and many of the tags were crap. I found this software called TuneUp ( http://www.tuneupmedia.com/ ) and was astonished at the results. With a little time and patients, I cleaned up almost all my tags. I could accomplish in minutes with this software what would've taken me days or weeks to do by hand.
...Nothing is True, Everything is Permissible...
2Fast4Mu is offline   Reply With Quote
Old 03-03-2010, 04:21 PM   #3
convert
convert's Avatar
Yeah, my tags are clean. I ripped most from my own CD collection using EAC, with a few others purchased form iTunes.
I pretty sure it's software (PDIM, maybe iPod) wigging out because it's not consistent. For example, when I search by artist, the first few entries are blank, but if I click into one it shows the right artist name at the top of the screen, and if I go back then the artist names will show up correctly for a few rows, then back to random mix-ups. The same type of thing happens when clicking into an artist. At first the album names are replaced by artist names. But then when I click into an album and go back the album names are replaced by track names. I'm pretty sure if it was dirty MP3 tags it would at least be consistent...
Thanks for the thought though.
Old 03-03-2010, 04:24 PM   #4
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
try another ipod on the camaro to see if it does the same thing
AdnanHfuda is offline   Reply With Quote
Old 03-03-2010, 11:53 PM   #5
jontejera
Drives: 2LT RS Imperial Blue
Mine does the same crap with my iphone, it drives me nuts and the dealer seems to have no clue what I'm talking about. I have reset, restored, synced, everything you can consider and still the samething. Mine is also CC hardware and CE software, I guess just wait for a PDIM update. Hopefully it will cover ipods and iphones.
jontejera is offline   Reply With Quote
Old 03-03-2010, 11:55 PM   #6
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
and you have CE at the moment?
Maybe it's a hardware issue? Is all of the hardware CC or is there also updated hardware?
Old 03-04-2010, 12:26 AM   #7
Sevn86
Sevn86's Avatar
My car does the same thing...and its sad cuz all the problems with the car the other members talk about my car does too...i think my cars a lemon...
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 03-04-2010, 02:05 AM   #8
convert
convert's Avatar
Mine came with CC hardware and CE software from the factory, so I assume there's no newer hardware, but I could be wrong. Mine was built last September.
Old 03-04-2010, 02:06 AM   #9
convert
convert's Avatar
Yep, I'm waiting on a PDIM update too.
Hint, hint codeman!
Old 03-04-2010, 08:12 AM   #10
codeman71
GM Employee
codeman71's Avatar
Drives: 2006 Pontiac G6
Hey sorry guys! I've been really busy here at work and haven't had as much time to browse the forums as I would like to.
This issue seems to only occur with iPod Touch and iPhone. From what I heard from the software team a while back, the 3.0 firmware really slowed down the iPod Touch's communication over USB. I don't know if that is contributing to the errors in the menus or if there's another issue. This issue has been reported to the PDIM team, but I haven't heard an update from them, so I'll check again and see what I can find.
I think the suggestion from AdnanHfuda is a good one. If you happen to have another iPod, or even a USB stick, you could try those to see if it is any different. I would bet that it would work properly as these issues seem to be around the iPod Touch and iPhone.
I work for GM and I designed the interface for the Camaro USB and Bluetooth audio streaming interface. Feel free to ask me any questions you have about how the USB or Bluetooth works!
Check out my videos on YouTube here. Let me know if you'd like to see any other type of video.
codeman71 is offline   Reply With Quote
Old 03-04-2010, 11:04 AM   #11
jontejera
tell them, fix it, geeettrrrrr dddooooonnnnneeee!!!!!!
thanks
Old 03-04-2010, 08:11 PM   #12
convert
convert's Avatar
Hey, thanks for the update. I don't have another iPod to try it with, but I was using a USB stick before my iPod Touch, and it didn't have the same problem (it had other shortcomings though, which is why I switched). An update would be awesome! I hoped that the new iPod firmware (3.1.3?) would help, but it didn't make a difference.
Old 03-08-2010, 03:21 PM   #13
BalloonPilotCamaroDriver
Drives: 2010 Camaro 2SS/RS
I have the same problem with my iPhone 3G, I tried friends phones and again, the same issue. I did try a regular iPod and of course it worked flawlessly. My iPhone used to work fine, so I would agree with Codeman that it has something to do with the iPhone's firmware update. Now we just need a solution to the problem.
BalloonPilotCamaroDriver is offline   Reply With Quote
Old 03-08-2010, 03:57 PM   #14
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
I have the same problem and it irritates me every single day, sometimes for no reason it just won't even load my iPhone into the CPU, I'd love for this to get resolved soon
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
PDIM Intermittently Fails to Recognize iPod or Zune in USB RandyB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 10-09-2012 08:16 AM
Got A New IPod 160gb Classic For Christmas, Will The USB Port Charge The IPod ? RCPW Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 12-30-2009 02:01 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
