Billet Custom
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-04-2010, 11:47 AM   #1
Mark-HD
Mark-HD's Avatar
Drives: 2010 Inferno Orange SS
Tuning Question HP Tuners vs EFI Live
I have an LS3 with Magnuson SC running basically a stock magnuson HPT tune. I bought HPT and the Tuning School to learn but I'm not there yet. Carried the car to a tuner in Atlanta to get the car properly tuned since adding Kook's LT's and CAI. Got a call today telling me that they use EFI Live and if they do the tune it will no longer be able to be tuned or read using HPT. Thus rendering my HP tuner software unusable. ??? I can't understand this. I would think the software used would wouldn't matter what goes into the ecm and the ecm could then be read or tuned later with something else....
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
Mark-HD is offline   Reply With Quote
Old 03-04-2010, 12:19 PM   #2
DSteck
Drives: 2006 Corvette Z06
The only way EFI Live would render HPT unable to do anything is if they use a custom operating system. There's a guy in Atlanta that goes by RWTD on boards... he's an avid HP Tuners user. You might want to see if you can find his contact information.
DSteck is offline   Reply With Quote
Old 03-04-2010, 03:22 PM   #3
Mark-HD
Mark-HD's Avatar
RWTD you out there?
Old 03-04-2010, 03:46 PM   #4
Mike@DS
Drives: 99 Z28
He is in Alabama as far as I knew...
You need to ask them why this is the case.
My guess is they are planning to do a 2 bar SD tune, which would be a custom OS, which would keep you from being able to use HPt later on...
Mike@DS is offline   Reply With Quote
Old 03-04-2010, 03:59 PM   #5
DSteck
Wow, you're right. Mobile, Alabama. I guess I got confused.
Old 03-04-2010, 05:37 PM   #6
Mark-HD
Mark-HD's Avatar
Yea I ask, they are using a custom os....I had a dyno pull done while it was there...563.05 HP and 547.94 lbs torque...
afr was pretty straight line at 12.5-13.3......I need to add fuel....
Old 03-04-2010, 07:46 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
find someone to tune it with hp tuners,, hp tuners also has a 2.5 bar(with or without maf) OS for the camaro, i have it in my tune,, very nice to be able to control the cooling fan at all temps and to have an actual VE table to tune, and keep your maf if you want to
Old 03-04-2010, 09:16 PM   #8
06x6spdGTO
06x6spdGTO's Avatar
Drives: 06 S/C GTO, 01 H/C/I Z06
WOW!! I would say you need fuel! was the Wideband reading a tailpipe sniffer?? You are REALLY Pushing the Danger Zone with the AFR's. Id be bitting my lip seeing 13.3 AFR on my N/A setup let alone a boosted Application.
06 GTO - Maggie 112H (Stock Pullies), LPE CAI, SLP LMII Catback, suspension and Drivetrain STuff, Monster Stg 3 clutch, ETMC Stg II Cam, 60lb inj, IW 8" Lower, PRC .650 Springs, Trickflow Pushrods, Kooks 1 7/8 LTs, AIS WasherFluid inj, 530whp/537wtq SAE. Self Tuned via HPTpro
01 Z06 - Forged 347ci LS6 - H/C/I 460RWHP / 418 RWTQ (Self TUNED via HPTpro)
06x6spdGTO is offline   Reply With Quote
Old 03-05-2010, 08:09 AM   #9
DSteck
Only certain OS IDs have an enhanced version.
Old 03-06-2010, 08:59 PM   #10
Failsafe Performance
Drives: 2008 350Z
Just curious, what are you running in terms of a fuel system?
Failsafe Performance is offline   Reply With Quote
Old 03-08-2010, 08:58 AM   #11
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Mark I can tune your car from here and you will be able to continue using HP tuners without Issue.
Your Numbers are right on what they should be, but lean and I have a custom MAF curve to correct that.
Send me your tune file.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-10-2010, 09:38 PM   #12
Mark-HD
Mark-HD's Avatar
Ted,
I added 6% to the MAF curve as recommended by MTI Racing. I also followed the procedure of logging Fuel Trims up to 4500 rpm and adjusting until I got the trims real close to 0 with PE turned off. I need to get it back to the dyno to check the WOT AFR. I'll e-mail the tune for you to take a look at it if you want. I have done nothing with spark. The KR is not bad. The only knock trouble I see is at cruising at say 1500-1800 and accelerate you get knock up to about 2200. I've read there is too much spark in this area. My main concern was the lean condition in PE.
Old 03-29-2010, 03:05 PM   #13
Mark-HD
Mark-HD's Avatar
Ted.
Thanks for the tune, Ted...car is running great......
Old 03-29-2010, 03:15 PM   #14
JANNETTYRACING
Great, Thanks for the Feedback.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
question for tuners out here mr_desmo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 07-17-2010 08:37 PM
Shorty Header / Tuning Question rauhaus camaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 12-15-2009 09:33 PM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 09:38 PM
Technical question for the tuners out there GMRULZ Tuning / Diagnostics -- engine and transmission 5 08-30-2009 08:34 PM
HP Tuners fullthrottle Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 08-27-2008 01:47 PM
