sjm autoprod
Old 03-04-2010, 04:02 PM   #1
toonlovescheryl
Drives: 2010 CAMARO SS
2SS BATTERY UPGRADE
I will be installing a sub and amp package this weekend. I would prefer to upgrade the car's existing battery before adding a secondary battery or capacitor. Does anyone know of a good aftermarket battery to go with?
toonlovescheryl is offline   Reply With Quote
Old 03-04-2010, 11:46 PM   #2
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
Optima Red Top should get the job done.
Back in the Game.
Bear is offline   Reply With Quote
Old 03-05-2010, 12:38 AM   #3
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
red tops, not really-- "These batteries are designed for engine starting applications. They are not recommended or warranted for use in deep cycle applications."
an optima yellow top on the other hand is meant for high drain electrical/audio
http://www.optimabatteries.com/home.php
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 03-05-2010, 10:53 AM   #4
toonlovescheryl
I did also look at the Kinetik and Stinger batteries. From what I have read, they are supposed to be better than Optima or Odyssey batteries. Does anyone have any experience with the Kinetik or Stinger batteries?
Old 03-06-2010, 03:24 PM   #5
squatin0n18s
squatin0n18s's Avatar
Drives: 2011 RJT 2LT/RS A6 Camaro
ive been looking for a yellow top but cant figure out which one to use. any help??
squatin0n18s is offline   Reply With Quote
Old 03-06-2010, 04:54 PM   #6
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
Battery upgrade
IF you as NASA which battery they use in the space shuttle it is Odyssey. I have six of them is my boat, they have the highest discharge cycle life as any battery.
Go Fast Kid is offline   Reply With Quote
Old 03-06-2010, 05:04 PM   #7
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
Odyssey (Sears Platinum is Same)
SRFnSNO is offline   Reply With Quote
Old 03-06-2010, 05:42 PM   #8
Merc
In The Circle
Merc's Avatar
2SS has a 27 series battery in it. Do you think you have to upgrage. There is lots of room to make a nice neat cap installation.
Old 03-06-2010, 11:13 PM   #9
n-shane@hotmail.com
n-shane@hotmail.com's Avatar
Drives: 2010 MAROOOOOO
yellow top
THIS CAR IS AMAZING!!!!!
n-shane@hotmail.com is offline   Reply With Quote
Old 03-06-2010, 11:14 PM   #10
n-shane@hotmail.com
caps are worthless. get a second battery
Old 03-14-2010, 06:18 AM   #11
Hess RS
Drives: 91 Camaro RS
caps are worthless, basically a bad band aid for a crap install. Second batteries are only going to help your play time with the car off. A stock battery is more then capable of putting out 200A+ during peaks. The starter takes 80-90A easily. Make sure you have GOOD power wire, and GOOD grounds, both to the amp, and from the battery to the body of the car. People often overlook ground wires, which is the cause of 90% of the "lights dimming" problems I see. 0ga power wire is pointless on a stock 8ga ground wire. Also, the factory battery has a vent line that vents gas from charging/discharging outside the car. if you do get a second battery, put an ignition controlled (or even a switch controlled) isolator on it, run all the stock wiring to the extra battery (like a yellow top so you can deep cycle it safely), and just use your stock as a backup/starting battery when you kill the yellow top. Car dies, flip switch, start car, drive off. Just my 2 cents.
Hess RS is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Phaste Performance 'Stage 1' upgrade - CAI, shorties, axle-back & tune! Sean@Phastek V8 Bolt-Ons & Tunes 1 03-17-2010 02:21 PM
Trunk mounted battery replacement sting808 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 01-11-2010 06:42 AM
why get an rs package on the 2ss? LS3SSRS 5th Gen Camaro SS LS LT General Discussions 66 08-16-2009 06:14 PM
Chevrolet Volt Urthman General Automotive + Other Cars Discussion 160 09-29-2008 09:17 PM
