03-04-2010, 06:45 PM | #1 | |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
DIY-Removing Dealer emblems!
Really quite simple, however there have been some random thread replies lately that have spurred me to start whipping up some more DIY Threads.
Even if they are simple..... So, here we go! Let's stop the free advertising. Tools needed: Hair dryer (or heat gun with a low heat setting) fine Dental floss(or sewing thread) "Goof Off" or non-acetone nail polish remover Initiative First thing Id recommend doing is cleaning up the area around your emblem that you are planning to remove. The last thing we wanna do is put some scratches in your clearcoat with all the working around the dirt stuff. Besides, she'll appreciate a good wash! Next thing we'll do is heat up the adhesive that is holding on the hideous emblem that we are about to remove. (Note: Most all of the emblems are different but the one thing that they all share is that the adhesive (or glue) that holds them on is at it's weakest when it is fresh and/or when it is heated. The sooner you decide to remove it, the better.) Apply even heat about 6-8 inches away from the surface with a sweeping motion so that you don't focus all the heat on one area. After we've heated it for a good 30 seconds with the wifes blowdryer....er...heat gun....the emblem may be able to come loose with a fingernail and slight pull. Give this a try first. If not, take your string (or floss) and gently work it between the emblem and surface of the car. Just like flossing your teeth, gently work it back and forth "sawing" the emblem away from the surface. (Note: If you don't floss your teeth, or don't have teeth to floss and have never done it....it's revolutionary. I highly reccommend it!) Dig it... Ok....getting back to it. If it doesn't come easy stop and reheat again as chances are the glue has returned to room temp and isn't giving. It should come easy. Once you have successfully removed the emblem from your whip, you might still find that some of the adhesive is still stuck to the car. No sweat! The last thing you want to do is take a blade to it. This would be BAD. Instead, use some non-acetone based nail polish remover or the sorts and it will come right off without harming your paints surface. Once done, go ahead and take a minute to clean your newly debaged area with your car cleaner/polish/wax of choice and take her for a spin! You are no DEBADGED and not working for "The Man." Enjoy! Ivan |
03-04-2010, 07:20 PM | #2 |
Nice DIY for those who's dealers did the dirty deed -
03-04-2010, 07:24 PM | #3 |
2SS RJT OWNER/OPERATOR
Drives: 2010 2SS LS3 RJT Join Date: Jan 2010
Nice write up. I personally hate dealer emblems on my cars. And I make it perfectly clear. That the car I am purchasing will not have any dealer emblems, stickers and/or plate frames. I have owned quite a few vehicles in my life. And I have yet to be told they won't sell me the car if they can't have they logo on it. lol
Fly low and Avoid the radar!
03-04-2010, 07:41 PM | #4 |
Nice write-up. I recommend Isopropyl Alcohol on a soft cloth for the removal of any adhesive that is left on the surface of the car. It won’t damage the paint but you will need to reapply a fresh coat of wax once all of the adhesive is removed.
03-04-2010, 08:37 PM | #5 |
Thanks guys!!
Isopropyl is another great method. Less intrusive for sure! I watched my car roll off the trailer.....told em "no dealer emblems" and they still put one on. Effers. I saw it, mentioned that I was unhappy about it, but I was making sure that all the other more important things were in order. But yes, the scumbags can and still do it!! -Ivan |
03-04-2010, 09:33 PM | #6 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I told my dealer NO decals and do not put frony plate holer on. Problemed solved. Let put rear licience plate holder on.
03-13-2010, 01:33 AM | #7 |
03-13-2010, 07:25 AM | #8 |
03-13-2010, 11:22 PM | #9 |
03-14-2010, 12:02 AM | #10 |
Next is SS camaro.....
Drives: 2010 Camaro LS, Rally yellow Join Date: Feb 2010
Luckily my dealer just put on the back of my trunk b4 i left and its was magnetic. so when i got home i took it off right the way with no marks left ^_^.
03-14-2010, 12:27 AM | #11 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
thanks for the writeup.
03-22-2010, 08:22 AM | #12 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I require any dealer to take that crap off before I drive away. That way I don't have to do it. They put that stuff on. They can take it off.
03-22-2010, 08:39 AM | #13 |
Drives: 2010 Camaro 2SS/RS M6 BLK/BLK, Join Date: Nov 2009
Darth, I agree with you!!! None of my cars have the dealer stuff on them. The only exception is a tag frame (which I can change)!!!
Artful Dodger 2010 Camaro 2SS/RS M6 BLK - 2015 Maserati Ghibli Q4 BLK (dd) - 2004 MB C240 BLK (wife's) - 1996 BMW 328i BLK
08-25-2010, 07:16 PM | #14 |
Drives: 2010 SS Camaro Aqua Blue Metallic Join Date: Jan 2010
I'm quite a few months late on this thread lol but I was looking through all the DIY's and stumbled across it. I was at the dealership when my ABM arrived (after waiting 4 months for my order) and there were no dealer decals on it. I specifically told the dealer 3 times that they were not to put the dealer decals on. After the paperwork was done a few hours later I found BRAVO stickered to the rear of the car and had them pull it off immidiately! I can't stand dealer emblems on a car!! lol
Thread Tools | |
Similar Threads | ||||
Help!!! - Paint issue not being resolved by a local dealer | c0rsa180 | 5th Gen Camaro SS LS LT General Discussions | 29 | 04-23-2010 12:20 AM |
"my dealer is sticking me with all of these extra dealer charges" | KILLER74Z28 | Camaro Price | Ordering | Tracking | Dealers Discussions | 93 | 08-22-2009 03:24 PM |
Absolutely.. cannot... do.. MSRP (dealer words) | Shadowmind | Camaro Price | Ordering | Tracking | Dealers Discussions | 22 | 06-13-2009 10:54 AM |
Some Dealer Info..... | KarlChev | Camaro Price | Ordering | Tracking | Dealers Discussions | 82 | 04-23-2009 08:16 AM |
Removing Dealer sticker/decal from the Camaro? | VictoryRed08 | 5th Gen Camaro SS LS LT General Discussions | 25 | 04-13-2009 10:08 PM |
