Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Suspension / Brakes / Chassis
Old 03-06-2010, 09:05 AM   #1
Drives: Black
Do you or do you not need a shorter RTA with a 1- 1.25 drop?
If you drop the car 1.25" with Eibach, pfat, etc. do you need a shorter rear trailing arm to obtain OEM alignment specs?
Also, what are OEM specs and should they be the same after a drop or changed a little to compensate?
verboten is offline   Reply With Quote
Old 03-06-2010, 04:30 PM   #2
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi verboten,
Thanks for posting your question. Please take a look at our recommended alignment values in this PDF below, it will outline the values you should try to aim for, when using drop springs and/or other components for a variety of uses ranging from full street to dedicated racecar.
You do not need to install aftermarket rear trailing arms to accomplish the "performance street" alignment settings that I have posted below. Take a look and let me know if you have any questions! We are here to help.
min Camber (deg) -0.9
max Camber (deg) -1.1
min Caster (deg) 7.5
min Caster (deg) 8.5
min Toe -1/16"
max Toe 0
min Camber (deg) -0.7
max Camber (deg) -0.9
min Toe -1/16"
max Toe 0
These settings will provide good performance and good tire wear
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 09:31 PM
Help With Drop spring seddon Suspension / Brakes / Chassis 15 12-27-2009 02:03 PM
Who Has Drop Springs in stock 1.5" Min drop Atomic Autosports Suspension / Chassis / Brakes 12 10-30-2009 05:24 AM
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! Suspension / Chassis / Brakes 25 08-03-2009 10:45 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 12:14 AM
