Old 03-06-2010, 05:27 PM   #1
camaroincarolina
camaroincarolina's Avatar
Drives: 1SS Aqua Blue Metallic
Brake question drilled/slotted rotors
I just had drilled and slotted rotors installed on my SS. They look great, but they don't stop as well as the OEM ones. I am thinking of getting some of the ceramic brake pads installed. Does anybody know if this will help? Thanks!
camaroincarolina is offline   Reply With Quote
Old 03-06-2010, 05:38 PM   #2
Wizzer
Drives: 2010 Cyber Grey
Something went wrong then. What brand did you buy and is there possibly air in the system. How odd.
Wizzer is offline   Reply With Quote
Old 03-06-2010, 06:12 PM   #3
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Did you bed them in properly?? How new are they? They won't feel like they will stop you at all until they're bedded and broken in. You really sure have put on new pads at the same time...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 03-06-2010, 06:52 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Im guessing you won't like ceramic as they need heat to work, id bet the problem is like already said, you didn't bed them in proper.
Why did Isay that about the ceramic?, as if you drive & brake the way they will need you to get heat into them to work their best, yours would be bedded already.
2ndgenz28 is offline   Reply With Quote
Old 03-06-2010, 07:00 PM   #5
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Someone else recently installed slotted rotors and accidentally put the front ones on backward. Are you sure you put the left ones on the correct side? It does matter.
He did use ceramic brake pads and, after installing the rotors correctly, said they work great.
Old 03-06-2010, 07:01 PM   #6
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Try this, tear everything back down and pull off the pads and rotors. Get some emery cloth (fine works best cause your not trying to remove much) and buff your pads just enough to knock off the glazed look. Then buff your rotors too (front and back). Put it all back together and drive it get up to about 30 and stop normally sit at a stop for about 30 seconds (do this 5+ times) then do a few harder stops(3-5) from alittle higher speed(40-50). Always allow about 30 seconds between stops. That should help
side note, did you disconnect the brake line from the caliper at anytime? If so please bleed the brakes before you do any more driving.
P.S. as 2ndgen said you probably wont like ceramics they need to be way to hot to "really work"
Superman09 is offline   Reply With Quote
Old 03-06-2010, 07:57 PM   #7
camaroincarolina
Ok, thanks so much for all the advice. They are 2 weeks old. I didn't do them myself. A shop did it and they painted my calipers at the same time. They did not take the calipers off. Everything looks like it's on correctly. Maybe I need to give them some more time to break in? It's been a couple hundred miles so far.
Old 03-06-2010, 08:07 PM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
That sounds goofy, how do ya do all that without removing the rotors?
And / or maybe while painting stuff got on the rotors, they didn't clean it off well.
Id ride the brakes some but at low speeds so it just break the surface if maybe its over spray, I do that after a long sit to break the rust off that forms.
Old 03-07-2010, 12:51 AM   #9
Superman09
Account SNAFU
Superman09's Avatar
if its been a couple hundred miles you are well beyond break in for brakes. They should have pulled your calipers off to paint them. I would take your car back to the same shop and have them rebleed your brakes and make sure they do it at no charge (their mistake) or do the cleaning I mentioned above but more than likely they didn't bleed it correctly/completely
Old 03-07-2010, 05:21 PM   #10
1 RD JEWL
1 RD JEWL's Avatar
Drives: 2010 Camaro 2SS_RS- RJT
Brake Issues
OK,
I just did a total break overhaul on mine last week. I have dimpled and slotted disks, hawk ceramic pads and goodrige stainless g-stop lines with motul rbf 600 fluid.
First the brakes should work comparably at first without "Burnishing" also refered to as "Seating", "Seasoning", etc. My ceramics needed no "heating up" to work well. I did burnish them shortly after putting them all in. This process is 5-6 HARD stops from 55-60 MPH to 5-10 MPH. This heats up the rotors and transfers some of the ceramic pad onto the rotors. Once done it is a one time per lifetime of the bad deal. Make sure you don't come to a complete stop though, you do not want to warp the rotors thus down to 5-10 MPH so the rotors are still turning. I did this and they have much better stopping power than the OEM in my opinion. Some of this will be due to the break lines too.
I agree with one reader here that said to have your lines checked again i.e. bleeding them properly. Most issues with poor stopping is not due to teh pad or the rotors but teh bleeding of the lines. If they feel "mushy" it is most likely air in your line. The key to this is to have a steady flow of fluid into a bottle without ever running he resevoir dry. If this happened it could be a bigger problem with air in your master celinoid (sp) or the ABS unit. Bottom line is you don't know if this happened if you didn't do it. I would recommend having the whole system purged by a competant shop. I would not want to wonder if they will stop me.
You should still Burnish your rotors adn pads once you have good stopping power again.
I love my rotors and ceramic pads so far.
Delivered 25 Aug 2009:
2SS/RS LS3
1 RD JEWL is offline   Reply With Quote
Old 03-07-2010, 05:38 PM   #11
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
You may think they work well, but if they are real ceramic pads used in racing, they don't beging to even work good till warm.
you must not driving the car like someone who really needs cermaic's and you will never know how well they really do work when heated.
ceramic brakes pads on dailys is a waste of money fad which is fine its your money but seem to be folks just like to say I got ceramics but don't need them.
Old 03-08-2010, 09:34 AM   #12
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Ceramic pads are a common fix to reduce brake dust; quite common in street applications.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 03-08-2010, 12:02 PM   #13
Chris_B
Chris_B's Avatar
Drives: Several
Correct. I don't know of any ceramic pads being used in racing. They just won't hold up to the heat. Basically, a "ceramic" pad is a semi-metallic pad compound to which at least 7% of "ceramic" material (usually beach sand) has been added. What you get as a result depends heavily on what compound was started with before doctoring, which is why you can't easily compare one brand of ceramics to another.
Normally, you give up 10-15% of stopping power going with a good ceramic pad over a good semi-metallic pad. And, normally, the dust given off is much lighter in color. But using garbage pads may yield all sorts of undesirable effects! I have found that getting a good deal on quality pads is great, but trying to save a bit more with the low-grade stuff is usually a big mistake.
Chris
Chris_B is offline   Reply With Quote
Old 03-08-2010, 12:42 PM   #14
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
brake dust?
That hasn't been a problem for years, unless you use cheap organic pads.
Only down side to good carbon metalics is they chew up rotors fast.
Brembo 2SS Brake rotors Front and Rear Complete with Pads 55Designs Suspension / Chassis / Brakes 4 06-07-2011 02:58 PM
Consolidated Toyota Recall/Safety thread Rallysport General Automotive + Other Cars Discussion 382 03-01-2010 05:42 PM
Red & Orange Brake Lights Mystery!?! Jake 5th Gen Camaro SS LS LT General Discussions 14 02-17-2010 08:32 AM
2010 Camaro SS Brembo Heavy Duty Cross Drilled Brake Rotors In Stock Ready To Ship Tim@Lingenfelter Suspension / Chassis / Brakes 4 12-07-2009 08:26 PM
Painted brake caliper question. alfie43 Suspension / Brakes / Chassis 2 11-28-2009 11:09 AM
