JUICEDMOTORSPORTS
Old 03-07-2010, 03:26 AM   #1
CamaroSA
Drives: 2010 Camaro SS/RS L99
Unhappy i need help quick pls
i got the eibach springs and anti-roll bars
they are being installed now
but the guy at the shop is telling me that the springs are loose
is this normal?
please advise ASAP
tire rack guys help i got the kit from you
CamaroSA is offline   Reply With Quote
Old 03-07-2010, 07:55 AM   #2
WongBob
Dig Race?
WongBob's Avatar
Drives: '13 AGM 2SS/RS 1LE
Have they put the car on the ground yet??? If not that sounds like your problem.
WongBob is offline   Reply With Quote
Old 03-07-2010, 07:56 AM   #3
CamaroSA
no they didnt
Old 03-07-2010, 07:57 AM   #4
CamaroSA
I think i gave my car to stupid dude
Old 03-07-2010, 08:11 AM   #5
WongBob
Dig Race?
WongBob's Avatar
HAHAHAHA have them set the car back down and everything should be fine. Just double check to make sure they are in right.
Old 03-07-2010, 10:53 AM   #6
Camaro21
Drives: SOLD - 2013 M6 ZL1
They will be loose until you put the weight on the car.. Mine was the same way and I haven't had any issues..
Camaro21 is offline   Reply With Quote
Old 03-07-2010, 11:07 AM   #7
CamaroSA
thank you guys
Old 03-07-2010, 12:03 PM   #8
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I have Eibach's springs and bars. Mine were NOT loose after installing on the struts and before installing on the car. I had a small PRELOAD compressing the spring onto the strut. Be sure to get an alignment after you have them installed.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 03-07-2010, 12:29 PM   #9
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Make sure they are seated into the struts when they lower the car and weight is applied to them.... You may hear a knocking sound from the back end every once in awhile if they don't.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 03-07-2010, 12:38 PM   #10
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
+1 Pretty normal.
Just make sure they hand torque the nuts, not air tools, might break something or spin the shock shaft and cause shocks to fail.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 03-07-2010, 01:01 PM   #11
Sack Rat 2SS
You do not want the spring to have any play on the strut when your suspension is full travel extended. Not compressed. After you install on the car, while the car is on the lift and wheels hanging full down, check to see if the spring has ANY travel or is loose. If no travel and spring is in tight then no problem. I would not want the spring to be loose at full travel down. My 2cents. Good Luck
Silver 2SS/RS Man/6
GM 3.91 Rear Gears
Old 03-07-2010, 02:58 PM   #12
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Like the guys said. The strut 'assembly' will be loose in the air. But the springs themselves shouldn't be loose inside the strut assembly. YES you will be able to move it around if you grab it and use a little force, but it shouldn't move inside the assembly.
Here is one of them inside the assembly before I took the old spring out. Spring should not be loose.
Here is the car where the top of the strut seats into the car. This will be loose before you lower the car to the ground.
Old 03-08-2010, 04:00 AM   #13
CamaroSA
Thanks everyone problem solved
thank you very much guys
the dump ass installed them and i rechecked and rechecked again after him
and everything is smooth the car look soooo good and the
handling OMG
now i feel like im driving a sports car
Lexol Premium Protectant Quick Wipes At ProperAutoCare.com Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 02-15-2010 12:32 PM
Lexol Premium 3-in-1 Leather Care Quick Wipes At ProperAutoCare.com Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 02-15-2010 12:30 PM
Quick help pls.. jrboyd_1980 Camaro Price | Ordering | Tracking | Dealers Discussions 1 09-05-2009 04:24 PM
How am i doing on paint care(Pics Inside) and Quick detail or Not? Jferrell88 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 9 06-09-2009 09:16 AM
