sjm autoprod
Old 03-08-2010, 09:00 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
AAC HID power source?
I just bought an HID conversion kit from AAC. No real instructions or videos that come with this. There is a wiring diagram but it’s pretty much useless to me……everything is supposed to be plug and play.
I have ballasts and wiring laid out and now I’m down to getting the power source of the ballast. My assumption was to use the Positive point in the engine compartment. I pulled off the top and I have no clue as to how I can get this wired in here. I tried to un-screw the positive point to maybe see if I could some out work the positive wire in but I felt like I was going to break or bend something.
Anyone have an idea on where/how I can pick up positive source here?
Build Journal
Old 03-08-2010, 07:06 PM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I bought my first HID package and it had the same small ring connector that is suppose to connect to the positive post as shown in your picture. Obviously not plug and play. The second HID set from BFxenon came with the proper connector. You should hook directly to the positive post even if it means changing the connector. Too many people out there with flickering headlights due to improper powering and/or grounding of the ballast. Do yourself a favor and change the connector !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 03-08-2010, 07:09 PM   #3
Ravirn
Account Unaccounted for
Ravirn's Avatar
Drives: Black SS
Did you e-mail/call AAC on this? What was their response?
WARLOCK (Black 2SSRS LS3) - A work in progress.
Ravirn is offline   Reply With Quote
Old 03-09-2010, 10:07 AM   #4
caverman
caverman's Avatar
Finished it.
http://www.camaro5.com/forums/showthread.php?t=69917
Build Journal
How-To: Install BFxenon HID Headlights (Non-RS) BFxenon.com Camaro DIY & HOW-TO instructions & discussions 73 10-07-2016 03:03 PM
DIY - Install BFxenon HID Fog Light kit - RS and non-RS package BFxenon.com Camaro DIY & HOW-TO instructions & discussions 46 04-25-2011 12:04 PM
starter gets no power... please help zebra General Automotive + Other Cars Discussion 16 11-12-2009 11:37 PM
JD Power survey: Younger Buyers Avoiding Domestics Scotsman General Automotive + Other Cars Discussion 6 12-04-2007 02:31 AM
