Old 03-08-2010, 05:10 PM   #1
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
V8 springs and sways on a v6
I did a search, didnt see anything. Point me in the right direction if there's already a thread.
Is it possible to put a set of springs and sways from a v8 on a v6? I know that the sways will mount up with the proper mounts and bushings but I'm not sure if the SS springs will work with the v6 coilovers. Or should I just go with an aftermarket set? I figure SS take offs would be a low cost upgrade to my suspension.
nak3dsnake is offline   Reply With Quote
Old 03-08-2010, 05:51 PM   #2
bng804
bng804's Avatar
Drives: '10 Victory Red 2LT
Me thinks if it were me, I'd go aftermarket. The Eibach Pro-Plus Kit is pretty reasonable @ just over $400.
bng804 is offline   Reply With Quote
Old 03-08-2010, 05:58 PM   #3
Tecca
Tecca's Avatar
Drives: ...
Why would you want to do that, the V8 springs are around $40 each which you can spend at least another $40-50 and get the eibach springs. The sways are like $100 a piece.
Trust us you are better off going aftermarket.
Tecca is offline   Reply With Quote
Old 03-08-2010, 06:41 PM   #4
nak3dsnake
nak3dsnake's Avatar
Just curious, that's all.
Old 03-08-2010, 07:28 PM   #5
nak3dsnake
nak3dsnake's Avatar
Ok disregard. Got a comparison of the parts from both cars, not much differn't. That's all I wanted.
Old 07-19-2011, 07:24 AM   #6
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
http://www.camaro5.com/forums/showth...=v8+springs+v6
see post #21
Drop vs stiffer ride - I used to do a lot of off roading and one of the tricks we used was taller firmer springs to get more clearance and preserve road driveability. It appears that the V8 swap into the V6 gets you a firmer spring with little change to ride height.
George
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 07-22-2011, 11:19 AM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The SS coils will lower your ride height and will fit the upper and lower spring perches all around on the V6. The sway bars are a bolt up too. You may want to check the for sale section or shops like Lingenfelter for take off parts.
Old 07-22-2011, 11:35 AM   #8
Camaro21
Drives: SOLD - 2013 M6 ZL1
The SS Sway Bars are the same OE Part number as the V6's from what I have been told. I don't know about the springs.
Camaro21 is offline   Reply With Quote
Old 07-22-2011, 11:38 AM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
The sway bars on the FE2 package (V6 cars) and the FE3 package (V8) are both different sizes. V6 owners could potentially see a small increase in handling capability with a set of V8 bars, but it's a VERY small increase.
Old 07-22-2011, 12:55 PM   #10
nak3dsnake
nak3dsnake's Avatar
You would have to swap springs, sways, shocks and struts to feel a difference. Doing springs or sways alone will not do much.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
Old 07-22-2011, 01:02 PM   #11
nak3dsnake
nak3dsnake's Avatar
Wow this thread is old. I'm surprised someone posted something. Swapped for the fe3 package along time ago.
Old 07-22-2011, 02:00 PM   #12
JusticePete
And the results after a few months of use?
Old 08-03-2011, 09:53 PM   #13
nak3dsnake
nak3dsnake's Avatar
Its better than the FE2 setup. Nothing night and day but still better. What made the most improvement was a set of your Street I bushing inserts.
Old 08-03-2011, 10:00 PM   #14
JusticePete
Thank you for the update and good words about Pedders foundational bush kit.
Stock Springs and Sways 2SS/RS Low miles jsharp Suspension / Chassis / Brakes 4 05-02-2010 09:59 PM
Pfadt springs and sways installed rhunley14 Suspension / Brakes / Chassis 18 01-27-2010 09:44 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Pfadt GROUP BUY! Springs / Sways / Mounts IPS Brandon Suspension / Chassis / Brakes 18 11-23-2009 03:46 PM
Seeking Ohio Camaro owners for near Free Pfadt Springs/ Sways Install!ASAP IPS Brandon USA - Great Lakes 0 11-05-2009 11:50 AM
