JUICEDMOTORSPORTS
Old 03-08-2010, 07:25 PM   #1
traip93
Drives: Ralley Yellow, Black Sripes 2L
How much oil drains w/ ramps (V6)
I'v got my car up on ramps right now, draining out the oil. Will all 6qts of oil drain on the ramp incline? I'll let it drain with the filter off for about 45min.
Should I add 6 quarts no matter what? Or add 5 quarts drive it a tad, check the oil and add as needed?
V6,
Thanks
Chad 2Lt
traip93 is offline   Reply With Quote
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
1SS V-6 OIL PLUG LOCATION ? Brendon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 01-29-2010 01:05 PM
Need Opinion on Oil Change 68blk/yel396 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 22 06-22-2009 12:02 PM
