Jason 98 TA
Old 03-08-2010, 09:42 PM   #1
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
OEM Spoiler Install
Anyone have directions for installing the GM spoiler? I have a friend buying a used one. Is there a template?
Thanks!
rjcamaro is offline   Reply With Quote
Old 03-09-2010, 11:33 AM   #2
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
No directions but here is a hint:
If you install one of these spoilers you need to remember it may not come predrilled for the bumpers two mtg bolts under the car. You may need to drill out the accesse holes which are marked on the new spoiler. These access holes are needed so that you can get to the two stock mtg bolts that connect the bumper under the car.
Tools: In case you need to remove the bumper. - may not be required in your case.
1/8" socket rench shown with a 10mm socket and extention needs to pivot!
7 tools including the beer opener - also included in photo is my 2 cents!
itsadryheat79 is offline   Reply With Quote
Old 03-09-2010, 04:36 PM   #3
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
Thanks! Sorry I should have been more specific, I meant the rear trunk spoiler.
Old 03-09-2010, 08:36 PM   #4
xpanda305x
Banned
Drives: Dark Knight
well. if you dont have the holes in the trunk. then you will need to take it to a shop to have them drill the spolier holes..
xpanda305x is offline   Reply With Quote
Old 03-10-2010, 07:27 AM   #5
dirtydogg
Drives: .
you were right calling it a spoiler the other is a rear diffuser. i sold my factory spoiler to someone else, they made a timplate with cardboard using the underside of the spoiler. or if you know someone with a spoiler on their car they come off real easy and you can use the holes on that car to make a timplate. there is 6 studs and 1 plastic clip that you have to drill holes for. you could also call your local chevy dealer they may have a timplate. remember when you are installing the spoiler that you use some type of thread locker on the studs/nuts. chevy had a problem with them coming loose and rattling. too bad you don't live near me i would gladly do it at no charge. if you have the nerve you don't need a shop to do it.
dirtydogg is offline   Reply With Quote
Old 03-10-2010, 05:37 PM   #6
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
Thanks! Good idea!
Old 03-10-2010, 05:53 PM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
No need to do any of that, get you a step drill bit, and take off the 4 round black plugs and the under trunklid pad, you will then see the 6 mounting locations for the spoiler, mark the center of each of the 6 holes, then just use the step drill to drill them out until you get the proper sized holes for the bolts, clean up the holes and use some touch up paint to cover the bare metal. Mount the spoiler and use loctite on the studs. recap the 4 outside holes and replace the under trunklid pad and you are done.
The Bird is the word!
Old 03-10-2010, 07:19 PM   #8
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
Cool! That will work, thanks!
Old 03-10-2010, 07:43 PM   #9
dirtydogg
Drives: .
are the hole positions premarked on the underside? mine came with a spoiler so don't know, but if you look you can see pre marked hole spots for the high wing spoiler that gm was going to offer.
plus i dont think that you can access all of the hole spots from under the trunklid pad the ones on the right or center right are at an angle.
Old 03-11-2010, 08:27 AM   #10
Angrybird 12
I put a OEM Style spoiler on and had no problem accessing the holes where it goes, I am not sure what holes you are talking about I don;t see why they would be any different from the 4 outter holes, But I didn't use the 2 center holes on mine, I didn't think they were necessary on a small spoiler like the OEM. The holes were not premarked but you just need to drill in the center of the access holes that already exist.. It took me about 30 minutes to install mine..
Old 03-12-2010, 08:24 PM   #11
dirtydogg
Drives: .
the ones i was talking about are the two that are beside each other, one is a stud the other is the plastic clip
Old 03-13-2010, 08:36 AM   #12
Angrybird 12
Mine didn't have any plastic clip... must be something used at the factory, You can probably do away with it if you wanted to....
But if you still want to use it, In that case just forget my instructions, sorry...
Old 03-14-2010, 01:29 PM   #13
LS/V6
LS/V6's Avatar
Drives: 1LT
Here's a picture so you guys can see whats going on....
I think your right on that never noticed them before at least thats what they look like
LS/V6 is offline   Reply With Quote
Old 03-14-2010, 11:14 PM   #14
Red67Stang
Red67Stang's Avatar
Drives: 2010 LS - Victory Red / Jet Blk Int
I just installed my OEM GM Spoiler last weekend. I took a piece of cardboard and cut it to fit the underside of the spoiler and punched out the holes in the cardboard for the studs. I laid it on the trunk and marked my holes. I then drilled the holes. Be careful not to let the drill slide off the shiny paint. I drilled holes larger than the studs to allow for movement before tightening. Then touched up the holes with touch-up paint. I applied a thin layer of clear silicone around each hole to make sure to water leaked. Set the spoiler down, tightened it up, put lock-tite on the threads and DONE! Looks great!
Red67Stang is offline   Reply With Quote
2010 Camaro Pre-Painted CDC Rear Spoiler! All Camaro Colors Available! RPI Designs Exterior Parts & Accessories 42 12-09-2017 12:47 PM
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 69 08-19-2017 11:09 PM
WTB: OEM Front GRX Spoiler SuperTrooper Exterior Parts & Accessories 7 12-04-2009 04:57 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
