Old 03-09-2010, 12:51 PM   #1
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Coilover question
Question I have is, I install coilovers and I assume I will need an alignment. I get said alignemt for a 1" drop. I then decide to drop 1.5", would I need another aligment? If I go to 2.0", another alignment? If I go back up to 1.0" another?
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-09-2010, 01:53 PM   #2
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Simply... yes, if you want to maintain the EXACT alignment specs after each drop.
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 03-09-2010, 02:06 PM   #3
Moriartii
Moriartii's Avatar
Thanks RW. Throws a kink into my thought process.
Cheers
K
Old 03-09-2010, 02:12 PM   #4
Circuit Motorsports
Drives: 2005 STi
As stated, yes you will to keep the exact settings.
But the changes will be minor from a 1" to 1.5" drop. So I wouldn't worry too much about it.
Circuit Motorsports is offline   Reply With Quote
Old 03-09-2010, 02:13 PM   #5
RichJ.
Shop Owner
Drives: 1 ton silverado
That is correct. You should have an alignment done to keep the specs right and prevent premature tire wear and optimum performance and handling.
RichJ. is offline   Reply With Quote
KW Suspension V1/V3 Coilover Kits Now Available | FREE S&H!!! AJ@ECSMotorsports Suspension / Chassis / Brakes 69 11-13-2010 04:50 PM
BC Racing Coilovers ~ Affordable Performance Coilover Systems! Best Prices !!! Circuit Motorsports Suspension / Chassis / Brakes 102 05-24-2010 08:29 PM
KW V1/V3 Coilover Kits !!!! SupremacyCustoms Suspension / Chassis / Brakes 38 04-28-2010 11:37 AM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 02:20 PM
