Old 03-09-2010, 02:58 PM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Tuning WOT on an LS3 with Knock
I have just gotten done recalibrating my MAF sensor for the RotoFab intake I have and also just installed my Kooks 1 7/8" headers. I have my AEM wideband installed and am tuning based on Lambda for E10 so I have Stoich AFR set at 14.137. I tuned the MAF in Open Loop and have the Lambda Error at +/-2% across the full range of the MAF Sensor. I did all the MAF tuning at Partial throttle never going over 4500 rpms since I had PE disabled. After all the partial throttle work, I put the new MAF mapping into my main tune, extrapolated out past 6000hz to extend the correction trend out into the WOT range and then did a single WOT run to try and see where I was at. The good news is, it looks like the MAF is +/-2% all the way through to redline but there are two things I need to address. The Commanded fuel is a flat line at 0.80 Lambda (11.31 AFR for E10) and I would like to get the car to command 0.85 so I have to richen up the PE Ratio but during the WOT run I noticed a lot of knock throughout the run. It started to knock a little bit at the beginning of the run, maybe 1 degree, and it pulled a bit of timing, then again 1.1 KR at 3700rpms and it pulled a few more degrees but then at 4600rpms the knock sensor read roughly 4 through the end of the pull.
So the question is, where do I go from here, I know I have to pull some fuel to get to 0.85 commanded lambda but if I pull fuel I am assuming it will knock even more. So is it best practice to get rid of the knock first or get the commanded lambda in line first.
Thanks in advance...
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 03-09-2010, 04:10 PM   #2
DSteck
Drives: 2006 Corvette Z06
Get your fueling in line. If you still have your low octane table intact and haven't desensitized your knock sensors, then you have nothing to worry about. Go ahead and put 1.176 in your PE table. I run leaner until about 2000rpm, and by 2500rpm I reach the 1.176 PE ratio. From there, start eliminating the knock by playing with your timing tables. Remember to keep your tables smooth.
DSteck is offline   Reply With Quote
Old 03-09-2010, 04:57 PM   #3
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
I agree completely with DSteck but I recomend paying for some dyno time to more accurately tune these two tables. . . (I'm assuming you are doing this on the road)
A load dyno will allow you to tune your MAF transfer a little more accurately, you could hit each cell in the table with the dyno set to replicate road load, and you can easily do a long 4th gear WOT sweep to get the upper end of the table in line.
When it comes to timing its even more important to use a load dyno. When making changes to the timing you should be watching torque output. . . tuning until the knock sensors read knock then backing it off a little is not a good idea lol
Just my oppinion, hope it helps.
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 03-09-2010, 05:49 PM   #4
DSteck
While I agree about using a dyno, he'll be fine on the street to do fueling although it can take longer. Dynos make everything so much easier, but they are so damn expensive. Buy a dyno... or twin turbo my Z06... hmm....
Old 03-09-2010, 05:52 PM   #5
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Yea I hear you lol
Around here there are a few dynos that let you rent time. . . I just do this now and its probally cheaper than the gas I wasted trying to tune on the street!
www.e85lsx.com
Old 03-09-2010, 07:07 PM   #6
robertway
robertway's Avatar
Thanks guys for the input, I'm glad you folks are willing to help work through this. I would love to be able to do this on a dyno and will probably look into some of the local shops to see if they rent dyno time but have no idea what kind of bill I would be in for. As for tuning on the street, I had a lot of success filling all of my cells during the partial throttle MAF calibration as I have a lot of quiet roads to be able to hit each cell and I also have plenty of room to do 2nd gear WOT runs although I would prefer to be able to do maybe a 3rd gear run on the street and ultimately a 4th gear on on a dyno but I'll have to take what I can get for now.
As for not advancing until I see knock and then backing off a few degrees, I really have no other choice on the street, I know on a dyno I could really hone in on MBT, do some spark hook tests and avoid knock at the same time but the street is all I have right now so if I can tweak out all the knock I will be happy for now while getting my 0.85 Lambda at WOT.
Maybe when I go back to Tune Time in Toms River, NJ to see how much I have improved from my baseline, Matt who owns the shop will have mercy on me and let me rent some dyno time, not sure if he does that though so it looks like I'll be giving him a call.
Old 03-09-2010, 07:52 PM   #7
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Just curious, are you going to tune the VE or just leave it MAF only? Right now I'm running MAF only and am very happy with it.
www.e85lsx.com
Old 03-09-2010, 09:18 PM   #8
robertway
robertway's Avatar
For now I am going to run MAF only. Was thinking about at least scanning to see how far off the VE table is (knowing it is a Virtual Table without direct access via HPTuners and needing the bluecat software) but from what I understand in my reading the VE Table should only need to be addressed if the pumping efficiency of the engine is changed, i.e. a bigger cam, intake manifold, ported heads, etc but correct me if I am wrong in that assumption.
Old 03-09-2010, 10:30 PM   #9
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Your correct, but the exhaust also changes the pumping efficiency, this is where the extra power comes from.
www.e85lsx.com
Old 03-10-2010, 08:56 AM   #10
DSteck
I run MAF only on my Z06, and have done the same with 2010 stuff. I've been very happy with how they turn out. It's just a lot easier.
Old 03-11-2010, 08:08 AM   #11
robertway
robertway's Avatar
Running around yesterday in MAF only, the one thing I noticed is idle is a bit flakey when coming up to a stop light and the car settling down, looking at my Airflow vs frequency it looks like I have to smooth out the bottom end around where idle occurs
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Knock, Knock, Knock, Knock, Knock, Knocking sound. jonm38 5th Gen Camaro SS LS LT General Discussions 22 03-10-2010 02:02 AM
L99 / LS3 Fuse Mod. Why Not Try it? Gen5SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 46 08-27-2009 10:04 PM
