Gen5DIY
Old 09-24-2008, 09:32 PM   #15
gunslinger
Drives: 1998 Z28 M6
How much does all of that weigh? and how durable are the motors?
The infamous 4th Gen Electric cutouts had a tendency to fail after driving on the streets (water/dirt) and having the actuator switch held too long after the butterfly made contact with the flange...
gunslinger is offline
Old 09-24-2008, 10:15 PM   #16
Jak
Jak's Avatar
Drives: 03 Dodge Dakota
Hmmm, very good question.
Jak is offline
Old 09-24-2008, 11:02 PM   #17
now
Drives: silverado ss
Good questions.
Each unit weighs 7lbs plus clamps/wiring. We use a 200lb capacity sealed screw drive linear actuator that holds its position at any stopping point during its travel. The actuator also has internal limit switches @ fully extended and retracted positions so there is no possibility of end of travel over torque or burn out. We have been doing this since 2000 and have yet to have an actuator fail due to heat, moisture, cold, ice, dirt, etc.. I'm not saying it won't fail but if it does, we will take care of it. We purposely went overkill on the actuator for durability and ease of use
The extents of our installs go from Canada and New York to southern California- so we feel they are tested.
now is offline
Old 09-24-2008, 11:09 PM   #18
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Originally Posted by noweeds.net View Post
We will be in the $860 range if this is 3" diameter exhaust. $840 if it is 2.5". System includes everything seen in the picture above, and leaves factory system in tact including cats and mufflers.
The measurements I have seen are 3" pipes for the V6 and 3.75 inch pipes for the V8.. Might want to wait until measurements can be made...
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline
Old 09-24-2008, 11:13 PM   #19
now
Cool, Thanks for the update... We can go bigger we just need to lay our hands on one.
now is offline
Old 09-25-2008, 01:41 AM   #20
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
those are the exhaust tip sizes not the actual exhaust sizes.
headpunter is offline
Old 09-25-2008, 08:59 AM   #21
Jak
Jak's Avatar
Hmmmmm, then I'm very intrested. Probably jumping the gun here, but do you have any dealerships in or around Central NY? Oooops, never mind, just checked your web site.
Good questions.
Jak is offline
Old 09-25-2008, 11:09 AM   #22
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
welcome to the site! And a very BIG thanks for the offer for our members!
TAG UR IT is offline
Old 09-25-2008, 12:15 PM   #23
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Wow, I just found the install picks on your website! Now that is bad a$$!
Did you guys see these yet? http://www.noweeds.net/page/n4zy/Installation.html
I would say it's about time we start putting together a parts vendor link on the home page.......hint....hint.....
Robert91RS is offline
Old 09-25-2008, 01:53 PM   #24
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
So you're trying to sell a bolt-in electronic cutout.
What is this, CorvetteForum Lite?
LSxJunkie is offline
Old 09-25-2008, 02:35 PM   #25
now
These are some pics from our first gen diverters - they are now much tighter, smaller, and stainless with updated electronics. Thanks for the compliment!
now is offline
Old 09-25-2008, 03:13 PM   #26
now
This car and our product seem to be a cool match.
So yes- if you need it, we will sell it to ya. Only after we finalize any design changes that may be necessary.
Just for a clarification- this is a diverter not a cutout in the traditional sense. We use 4 butterflies all in sync which would require 4 'cutouts' and an exhaust plumbing master to pull off. This is the industries only self contained dual butterfly piece that gives you infinate range from full stock to full 100% open header/manifold. "Cutouts" just give exhaust an escape path but your exhaust system still receives alot of noise and energy making them less effective. As we open up our system we are progressively closing off the quiet side completely. Believe me, this makes a huge difference!
The "h" design will allow you to leave every factory hanger/bracket untouched and we just shift the loud stuff to the side.
And- with a recip saw and a 9/16" wrench it should only take 10 - 15 minutes per diverter to BOLT-IN YOURSELF IN YOUR GARAGE with NO WELDING plus whatever time it takes to wire the controller.
now is offline
Old 09-25-2008, 03:24 PM   #27
headpunter
headpunter's Avatar
Drives: Man
so it actually closes the muffled side? thats pretty sweet,
Old 09-25-2008, 03:27 PM   #28
now
Sure does.
now is offline
cutout, diverter, electric, exhaust, mufflers
Edmunds: 2010 Ford Mustang First Look Scotsman General Automotive + Other Cars Discussion 32 11-23-2008 10:55 PM
Automobilemag.com: 2010 Chevrolet Camaro - Q&A Scotsman 5th Gen Camaro SS LS LT General Discussions 23 10-12-2008 01:13 AM
Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 AirGoya Chevy Camaro vs... 86 07-24-2008 12:20 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
