BeckyD@RodgersChevrolet
Old 03-10-2010, 04:03 PM   #1
BlessedChef10
BLESSEDCHEF10
BlessedChef10's Avatar
Drives: 2010 2lt camaro rs
Does anyone know what size belt I need for a powerband 20% underdrive balancer?
Powerbond pulley belt size for V6?
Does anyone have any idea what size belt or part number is needed for this pulley. I bought it from New Era performance and they can't get me a straight answer. Please anyone.....
powerbond's new 20% underdrive balancer for your V6 GM incorporates a number of high-quality features you won’t find on any other aftermarket unit. Chief among them are a pair of extra-tall belt-retention walls that eliminate the belt-slippage issues endemic to other balancers. Other unique design strengths include 100% steel construction (other brands use steel and aluminum), integral timing marks, and built-in puller-mounting threads. Includes detailed installation instructions. FEATURES Extra-tall belt-retention "walls"—no more thrown belts! No aftermarket tensioner required 100% steel construction Lighter than the stock balancer Integral timing marks and puller-mounting threads Keyed for high-rpm or supercharged applications Does not cause false knock retard or erratic power-curve dip
BlessedChef10 is offline   Reply With Quote
Old 03-10-2010, 05:26 PM   #2
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Shouldnt be to hard to compute, what is the diameter of the original and the new one?
ROD1 is offline   Reply With Quote
Old 03-10-2010, 05:45 PM   #3
BlessedChef10
BLESSEDCHEF10
dont know Ill check
Old 03-20-2010, 10:59 AM   #4
BlessedChef10
BLESSEDCHEF10
Ive been told a 75" six rib belt should do the trick.
Old 03-20-2010, 11:30 AM   #5
Mankind
Whats a Millwright?
Mankind's Avatar
Drives: 2LT/RS SIM, 05 Wht Denali
Stock belt is 84. i doubt a 10 inch decrease in belt length will occur. can calculate it for you if you can get the outside diameter of the New Era pully, of where the belt runs that is.
Mankind is offline   Reply With Quote
Old 03-20-2010, 12:32 PM   #6
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
if the stock belt is truly 84"....a drop to 75" sure seems excessive!
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 03-20-2010, 11:45 PM   #7
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
It might be a bit of a pain in the rump, but you can always route a string around the pulleys, cut it off and measure it. I've done it before, mind you the routing was straight forward before everything went serpentine, but it really worked well. It gives you an excellent base starting point anyway.
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 02-26-2011, 08:17 PM   #8
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
you ever git this thing installed?
http://www.camaro5.com/forums/image.php?type=sigpic&userid=23546&dateline=129226  2453
ANY OTHER NITROUS V6's IN TEXAS?
www.elviracamaro.webs.com/
www.lonestarcamaro.com
rhd is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
Powerbond pulley belt size for V6? BlessedChef10 USA - California 3 03-10-2010 04:00 PM
SLP 25% Underdrive Balancer Pulley for 2010 Camaro SS Kris@BMCPerformance V8 Bolt-Ons & Tunes 11 02-18-2010 10:17 PM
SLP's Underdrive Harmonic Balancer - $179.99 tbyrne V8 Bolt-Ons & Tunes 2 11-29-2009 10:03 AM
SLP Underdrive Pulley w/new belts +5hp FS jrpxxii Forced Induction 8 11-17-2009 10:38 AM
